Remote Clutch Master Cylinder
Revision as of 22:37, 22 June 2016; view current revision
Category: Clutch
A remote-mounted Hydraulic clutch Master cylinder may also be needed if there is not enough room in the engine compartment.
Mount the clutch master inside the passenger compartment -- under the dash -- and connect it to the gearbox slave cylinder via a hydraulic line.
  1. Fabricate L-shaped bracket, bolt (or weld) to the under-dash steering column brace
  2. Lengthen clutch pedal, attach the master rod ABOVE the fulcrum
  3. Place the filler tube under the dash, connect to master via rubber hose
Not enough room after a big Engine Swap? Move the clutch master under the dash!
album 18812.jpg 18890.jpg 18891.jpg 18892.jpg 18893.jpg 18894.jpg 18895.jpg 18896.jpg 19198.jpg 19199.jpg 19200.jpg
Girling
Under-dash mounted Girling clay pipe master
Girling "claypipe" master cylinder, available in 5/8" and 3/4" bores (about $70 AUD). Threads are 3/8 unc for pipe outlet and 7/16 unc for fluid in
Urvan
https://en.wikipedia.org/wiki/Nissan_Caravan
  • Use with Nissan Urvan remote-fill tops
  • A simple 90-degree bracket is fabricated to mount it to the under-dash steering column brace
Sentra
https://en.wikipedia.org/wiki/Nissan_Sentra
Nissan Sentra Clutch Master Cylinder
Fluid reservoir is connected to the cylinder via a rubber hose.
Lancer
https://en.wikipedia.org/wiki/Mitsubishi_Lancer_(A70)
For ideas, could something like this be used on a 1200?
Cable-to-Hydraulic custom remote clutch m/c found on Mitsubishi LA Lancer
