Stock Wheels
- 12" diameter
- 4-inch wide
| wheels | B10 | B110 | 1977 US B210 A14 | 1980 NA B310 |
| size | 3-1/2 J-12 | 4 J-12 | 4-1/2 J-13 | 4-1/2 J-13 5 J-13 (aluminum) Canada w/A12A: 4J-12 |
| offset | ? | 30 mm | 30mm offset | 30mm 25 mm (aluminum) |
| tire size | ?-12 | 6.00-12 155SR-12 | 155SR-13 | 6.00-12 155SR13 175/70SR13 |
| balance | 10gr or less (0.35 oz) | 11gr or less | 10gr or less | |
| lugnut torque | 8-9kg-m (58-65 ft-lb) | 8-9kg-m | 8-10 |
Datsun Option Wheels
Also see: B310_Options#Wheels
40300-N5825 WHEEL SET-ROAD ALUMINIUM, B TYPE (5JX13) 40300-W6625 WHEEL SET-ROAD ALUMINIUM, C TYPE (5JX13)
Also used on 200SX (S10 silvia) 1977-1979
Option B Wheel
Option C Wheel
B310 Wheels
ホイール
Sunny 1200 Race Wheels
Sports Options CatalogRace Road Wheel Parts 1 40300-H5021 ROAD WHEEL FR 8Kx14 inch 40300-H5020 ROAD WHEEL FR 9Kx14 inch 40397-N3120 SPACER-Safety Bolt (16) 40398-N3120 SEAL-Rubber (16) 2 40399-H50?? BOLT-Safety (16) 3 40209-A0220 SPACER-Road Wheel (4) for aluminum, t=5 4 40222-A0220 BOLT-Wheel FR (8) M12 x 1.25 x 50 5 40223-A0220 BOLT-Wheel RR (8) M12 x 1.25 x 50 6 40224-H5020 NUT-Wheel (16) (Taper) 7 40224-E7210 NUT-Wheel (16) (Taper) Chrome-plated cap nut
Sports Options Parts![]()
Lug Nuts
M12x1.25 thread
- B210: 13/16" lug nuts
See main article Wheel Studs
Torque
- 8.0-9.0 kg/m (58-65 ft-lb)
Wheel Balance
Also See: Vibration
Wheel Offset
STOCK = 30 mm offset
Scrub Radius
Largest Sizes to Fit 1200
- Front: 3.25" is the maximum backspace (which is used by the stock 4" wheel). So if going wider, the Offset must be reduced from +30.
- Rear: +30 Offset works best with Datsun 1200, allowing the largest width tyres (205-width tyres).
Rear
- 9": 13 x 9 zero offset, tire 215/50r13
Ute Rear
Weights
Stock Datsun 1200 Wheels (12 x 4) weigh 11 pounds each. Virtually all aftermarket alloy wheels are heavier, except for very expensive magnesium wheels.
See main article: Wheel Weights
Wheel Adapters
Wheel Spacers
See main article: Wheel Spacers
If the wheel offset is too negative, they will fit the fenders (guards) and there is nothing you can do except cut out the bodywork, perhaps fitting large flares.
Suppliers
See Rims
Aftermarket Wheels
See Rims
Compatible Wheels
- Rear-wheel drive Toyota
- Chevrolet Corvair (5 x 13)
- pefect for the rear
- may need a 1/4 inch spacer on fronts to clear the brake caliper
- Datsun 240Z wheels -- 14"
- Uni-lug alloy wheels
- Rear-wheel-drive Mitsubishi
What WONT work:
- early Honda
- Isuzu/Holden Gemini
- Ford Escort/Cortina
- early Mazda
- Subaru
- some SAAB
FWD Rims
- Acura Vigor 1991-1994
- Acura TC 1992-1995
- Ford Laser (KA to KH)
- Hyundai Excel
- Kia 2001- (67.1 center)
Saab Wheels
- 1979-1983 SAAB 900
Sigma Rims
Australia * Chrysler Sigma 1978-1980 * Mitsubishi Sigma from 1981
1977-1980 #GE Sigma SE 14x5.5 with 195/65R14
1982 GH #Sigma Turbo rims 15 x 6 inch
GE Sigma SE
- 1977-1980 Australia GE Sigma SE
- 1976-1979 Japan Galant Lamba
- 1978-1983 USA Plymouth Sapporo
Sigma Turbo
1982 GH Sigma Turbo rims 15 x 6 inch 4x114.3 (Sigma Turbo was a limited run on 500 cars)
Toyota
Celica
A40 Celica 1978-1981
Corolla RWD
E30 1974-1979 E70 1979-1983
Supra
A60 Celica XX 1981-1986/Z10 Soarer
Nissan-Datsun Wheels
Bakkie White-spoke Wheels
B140 Champ wheels (trail duster style aka white-spoke steels)
A-LINE "Spoke White" of the Steel Outback Range (8-spoke)
