The 3-speed used a column shifter attached to the steering column. 4-speeds and 5-speeds use floor shift mechanism that is integral to the transmission itself.
Also see: Automatic Shifter
By POST government decree the shift pattern must be displayed in view of driver. This is normally printed on the shifter knob.
You can also print it out and tape it to the dash "in view of the driver".
Shift Knobs
クシフト ノブ
8mm x 1.25 threads
If you want just the pattern on top, you can buy those from Autobarn and other similar stores as a badge with sticky back.
BProjects Wood shift knob with various patterns
B110
Also see Transmission Control Part Numbers
STD: Column shift DX: Black plastic GL: Wood GX: Leather-like GX-5: Wood with dogleg pattern
32865-H1000 <> 32865-27700 <> 32865-V2400
The stock Datsun 1200 4-speed knob is black.
3-speed column-mounted shifter:
32865-H2001 KNOB-control lever (wood) GL
similar: 32865-H2000, C2865-Hxxxx, 32865-H9300, 32865-78601, C2865-25800
32865-H2300 KNOB-control lever GX [Leather-like]
similar to this
32865-H7200 GX-5 Shift Knob
Non-stock leatherlike (GL-type) knob for 5-speed
32865-Vxxxx, 32865-N5102, 32865-N5112
Datsun 1200 Options
Datsun 1000
32865-27700 > 32865-24901 <> 32856-24900 32865-25800 wood OPTION 32865-78602 wood GL
4-SPEED 32865-H1000 Van PLASTIC 32865-H5100 GL WOODLIKE 32865-H5110 32865-78601 OPTION WOOD 32865-H5200 OPTION LEATHERLIKE 32865-H5210
5-SPEED 32865-N5010 GL.F5 WOODLIKE 7702- 32865-N5102 GX.F5 GL.OPTION LEATHERLIKE 32865-N5112 32865-N5103 OPTION WOOD
HB210
B310
KNOB-CONTROL LEVER * Black * Brown * Leatherlike Black * Leatherlike Brown * Woodlike 4-speed 32865-W2000 * Woodlike 5-speed 32865-W2100
32865-H8800 B310 PLASTIC 4F BLACK 7812-8010
32865-H8802 B310 PLASTIC 4F BROWN
Custom
Shifter Bushes
The bushings become dry rotted,broken. New ones restore your shifter for tight, precise shifting again.
I got tired of the shifter in my 1200 flopping around, so I changed the bushings --it took about 5 minutes. I don't know what happened to the old bushings, I didn't see any in there at all. It was nice and tight last year, but one day it just started flopping. I reckon the old ones shattered into a million pieces. Anyways, for 5 minutes and 5 dollars, it sure works better now.
About $10 USD from Nissan | with new rubber boots
"Head" bush at the end, regular bushes on the side of the hole
If you have carpeted tunnel, pull it out, to prevent grease from getting on it.
If you have a console, remove it. Two Phillips screws on each side, 4 total
Floor boot -- pull the boot up
Transmission boot -- pull the small boot up
Using a small screwdriver, snap the E-clip off the pin. Some transmissions have a 10mm nut instead.
Disintegrated Shifter Bushings -- looks like sludge, but is actually the remains of the plastic bushings, mixed with gear lube.
Wipe off the shifter and push the new bushings into place;
Metal Bushes
Stock type plastic bushes VS Racing aluminum bushings for better control (but they transmit vibration)
Short-throw Shifter
A short-throw shifter is longer below the fulcrum, so you only need the move the shifter a little to move the gears a lot.
Of course if the fulcrum is higher up on the shifter, you need to move the fulcrum mount point on the transmission up higher to match.
Discussion: How to make a short shifter
Simple Method
Lengthen the shifter bottom section: cut just below the fulcrum pin in the round part. Then just weld in a piece of 3-4mm steam pipe 1 - 1.5 inches long then weld the fulcrum back on top. On the stick cut the bottom off and exten it the same amount and then weld the ball back on.
Or instead of modifying the 56/60-series shifter, use an L-series shifter (which has a higher fulcrum).
To modify the transmission, bolt extension plate on the shifter brackets:
Pro Bracket
Angelo made the adapter and stick to move the fulcrum point up about 1.25"/32mm. The stock shifter moved about 6-7" from 1st to 2nd, now it moves only 3". Side to side movement is still the same as before. It has taken me a few days to get used to. The throw is so short, it's difficult to go from second to third and from fourth to fifth. Tap the original holes for the fulcrum pin with an M10x1.5 and used short flathead/countersunk M10 screws to mount it.
Maddat
Product No SSRA-S Short Throw Shifter (A-Series Gearbox). Reduce the distance between gear changes and do away with your old floppy shifter. Bolt-on application includes new chromed shifter, adapter, bolts and new bushes. Comes with instructions.
63/71 Shifter
63-series and 71 series already have a higher fulcrum point. Some later 71-series are adjustable for low- or high- fulcrum.
1984 adjustable shifter re-bent similar to 1200 shifter:
Comparo
Pictures thanks to DatzenMike.
Adjustable, just reverse the plastic insert to fit different transmissions:
There is a difference in pin heights on the FS5W71B transmissions.
4-speed & 5-speed up to 1980
Some FS5W71B shifters from 720/S110 in multiple lengths
The two plastic bushings and the spring inside can be swapped upside down to move the pin hole higher up to move the fulcrum point up.
Shifter Bushings
Nissan 32855-H1010 - manual transmission. The original part number was 32855-24900. (2 required).
These bushings fit: * 1967-1970 B10 * 1971-1973 B110 * 1974-1978 B210 * 1969-1973 510 * 1977-1980 810 * 1973-1979 620 * 1980-1985 720 * 1977-1983 200SX * 1969-1973 Patrol
Shifter End Bush * Nissan 32861-24900 BUSH-CONTROL LEVER HEAD * rarely needs replacing
Boots
Also see: Console
Large Boot
Also see: Console
Interior shift boot (large boot)
74963-20900 BOOT-CONTROL LEVER $11 USD
108mm overall diameter
13mm hole
74963-H5000 $30 USD
110mm diameter overall
15mm: lever hole diameter
85mm: floor opening diameter
Compare with 510/620 boot, which is for a larger opening
137mm diameter overall
99mm: floor opening diameter
Small Boot
32862-G1200 BOOT RUBBER C/L $4 USD * replaces: ** JAPAN 32865-H1000 ** USA To 0373: 32862-24900 BOOT-RUBBER CONTROL LEVER ** USA From 0473: 32865-H1000 BOOT-LEVER CONTROL LEVER
These all interchange. Bends/length differ.
- 56-series shifter
- 60-series shifter (both 4 & 5-speeds)
The 63-series 5-speed shifter fits deeper into the transmission, so does not interchange. CONVERSELY, the 60-series shifter does not work well with the 63-series 5-speed, as the length of the shifter from the crossbolt to the plastic pivot point at the end of the shifter is about 10mm shorter. But 60-into-63 might work in a pinch.
The B310 floor boot is different:
32862-H7300 BOOT-RUBBER CONTROL 4-speed,5-speed, 56,60-series $4.87 USD
75950-H8510 BOOT-CONTROL LEVER [Floor hole] COUPE OP.SEDAN $28.55 USD
75951-H9100 HOLDER-BOOT SEDAN.DX $6.30 USD
* 75950-H9100 BOOT-CONTROL LEVER SEDAN.DX (BROWN) $63.52 USD
* 75950-H9101 BOOT-CONTROL LEVER SEDAN.DX (BLUE) -0779 $57.12 USD
* 75950-H9103 BOOT-CONTROL LEVER SEDAN.DX (BLUE) 0879- $63.52 USD
* 75950-H9102 BOOT-CONTROL LEVER SEDAN.DX (BLACK) $63.83 USD
