Sedan badges
Revision as of 21:37, 21 July 2021; view current revision
Category: Body
Grille #Center Ornament
Grille #Left Side Badge (trim badge)
Side #C-pillar trim badge
Side #Rear Quarter name badge
Rear #Model badge (Datsun or Sunny)
Rear #Trim badge (Deluxe, GL or GX)
Rear #Transmission badge (Sports or Automatic)
16673.jpgAlbum 16673 16134.jpgAlbum 16134 17765.jpgAlbum 17765 9928.jpgAlbum 9928 758.jpgAlbum 758 20863.jpgAlbum 20863 20862.jpgAlbum 20862
South Africa GX badges
10248.jpgAlbum 10248
Grille
20869.jpgAlbum 20869
Center Ornament
#Early Center Ornament 62312-H1626 ('D') and 62312-H1026 ('S')
11318.jpgAlbum 11318
#1972 Center Ornament
22828.jpgAlbum 22828
Early center ornament 62312-H1626 ('D') and 62312-H1026 ('S')
24321.jpgAlbum 24321 11318.jpgAlbum 11318
19527.jpgAlbum 19527 11793_4a2f681382129.jpgPost click for topic 21120.jpgAlbum 21120 737.jpgAlbum 737 24563.jpgAlbum 24563
Facelift grille 62312-H3125 ornament Late JDM intricate "S"
62312-H3100 cast mark
752.jpgAlbum 752 22828.jpgAlbum 22828 7522.jpgAlbum 7522 13057.jpgAlbum 13057 bfsjq597-img600x450-1293012459v70sxm12525.jpg S_badge_reverse.jpg bfsjq597-img600x450-1293012459yvrlgd12525.jpg bfsjq597-img600x450-1293012459er55u512525.jpg
457.jpgAlbum 457
retrofitted to early grille
23190.jpgAlbum 23190
Grille Left Side Badge
DX early - no trim badge on grille
DX 1972 #62330-H3125 EMBLEM SET-radiator grille "DELUXE"
GL early #62330-H2026
GL 1972 #62330-H3325 EMBLEM SET-radiator grille "GL"
GX early #62330-H2325 COUPE, SEDAN
GX 1972 #62330-H3425 EMBLEM SET-radiator grille "GX"
1972 GX5 62330-H7225 EMBLEM SET-radiator grille "GX 5 SPEED"
62330-H2325
GX early COUPE, SEDAN grille badge| CONTRAST to rear see-through badge
grille badge has long studs for mounting through the grille
contrast with rear sedan badge which has flush-mount pins
GX-grille-badge-2.jpg GX-grille-badge-1.jpg yunakiti-img600x450-1277628693ok47g777311.jpg yunakiti-img600x450-1277628693ybadxo77311.jpg yunakiti-img600x450-1277628693qqw7ym77311.jpg 62330-H2225.jpg 62330-H2225_reverse.jpg gx_grille_badge-1.jpg gx_grille_badge-2.jpg gx_grille_badge-3.jpg 27477.jpgAlbum 27477
If the mounting bracket is lost, a length of plumbers tape will do the job (metal strapping tape)
62330-H2026
62330-H2026 EMBLEM-'GL' (early coupe + early sedan)
20864.jpgAlbum 20864 27822.jpgAlbum 27822
screw-on type (rear GL badge is push-in type)
62330-H3125
EMBLEM SET-radiator grille "DELUXE" [1972]
7522.jpgAlbum 7522 25974.jpgAlbum 25974
compare to rear badge 84823-H1000
22513.jpgAlbum 22513
62330-H3325
GL 1972 - 62330-H3325 EMBLEM SET-radiator grille "GL" (1972 sedan, coupe) has long studs for mounting through the grille
compare to early rectangular GL badge #62330-H2026
Cast mark "62330-H3300"
62330-H3425
GX 1972 62330-H3425 EMBLEM SET-radiator grille "GX"
25658.jpgAlbum 25658
compare to 1970-1971 'GL' expanded font
16719.jpgAlbum 16719
Side
20868.jpgAlbum 20868
Rear Quarter
#76854-H1600 EMBLEM-'DATSUN' BODY SIDE Sedan, Coupe Export
#76854-H1000 EMBLEM-body side "Sunny" (early '71) Sedan, Wagon
20867.jpgAlbum 20867
Location
14093.jpgAlbum 14093 14094.jpgAlbum 14094
76854-H1000
174_5d5270a05de0e.jpgPost 492238 174_5d5270c9e99cd.jpgPost 492238
Similar:
PB110_Badges#Sunny_Quarter_Badge
9998_4d9ca51941ed4.jpgPost 362773
76854-H1600
76854-H1600 EMBLEM-'Datsun' BODY SIDE Sedan, Coupe Export
10578.jpgAlbum 10578
3973.jpgCoupe 20843.jpg#Sedan
'Datsun' badge has same three pins as '#Sunny' badge, so it is interchangeable
24320.jpgAlbum 24320 24323.jpgAlbum 24323
C-pillar
C-pillar Emblems: DX, GL, GX
20866.jpgAlbum 20866
DX: 80mm wide? , GX: 99mm wide?, GL 109mm wide?
#76852-H1000 BADGE-"Deluxe" SEDAN-DX
20848.jpgAlbum 20848
#76852-H2001 BADGE-"GL" SEDAN-GL
23133.jpgAlbum 23133
#76852-H2300/76853-H2300 BADGE-"GX" SEDAN-GX RH & LH
5204.jpgAlbum 5204
C-pillar Badge Location
1977 GX
15399.jpgAlbum 15399
1973 DX
6576.jpgAlbum click to view
1970? press photos
751.jpgAlbum 751 5271.jpgAlbum 5271
C-pillar Badge 2-dr Sedan
The C-pillar badges seem to have been put in two different places:
* 1970-1971 - down low
* l972-1973 - a bit higher up
The rear fenders are the same part number, so that's not the difference.
1970 DX Press Photo - below the corner
748.jpgAlbum 748
1971 - below the corner
1973 at the corner
76852-H1000
13484.jpgAlbum 13484 20848.jpgAlbum 20848 24325.jpgAlbum 24325 24324.jpgAlbum 24324
Portugal version
26892.jpgAlbum 26892
76852-H2001
23133.jpgAlbum 23133 CGL.jpg CGL_.jpg GL-c_pillar_badge_reverse.jpg m73760119scoresnewyork-img600x450-1264925423zpizbt91579.jpg m73760119scoresnewyork-img600x450-1264925429gqm2ek91663.jpg
76852-H2300
76852-H2300 BADGE-"GX" (R.H.) SEDAN-GX
76853-H2300 BADGE-"GX" (L.H.) SEDAN-GX
5204.jpgAlbum 5204 15399.jpgAlbum 15399 18264.jpgAlbum 18264 gxg1.jpg gxg2.jpg
Rear
#Model
#Trim
#Transmission
20870.jpgAlbum 20870 14189.jpgAlbum 14189 750.jpgAlbum 750 25995.jpgAlbum 25995
Model
  • Japan domestic models had 'Sunny' badges as they were sold by Sunny Shop
  • Export models had 'Datsun' badges
20894.jpgAlbum 20894
Left Rear Sunny - UK???
84822-H1000
Sunny 1200 - Right Rear
23991.jpgAlbum 23991
84822-H1600
84822-H1600 EMBLEM-'DATSUN 1200' TRUNK LID SEDAN
Datsun 1200 - Right Rear signature
21715.jpgAlbum 21715 15650.jpgAlbum 15650 16745.jpgAlbum 16745 19425.jpgAlbum 19425 24319.jpgAlbum 24319 12129.jpgAlbum 12129 datsun_1200_emblem_1_73.jpg 18640.gifAlbum 18640
9998_4d9ce1b0c1d77.jpgPost 362773 9998_4d9ce1c1e0afe.jpgPost 362773 9998_4d9ce1cb3f975.jpgPost 362773 9998_4d9ce1d957c51.jpgPost 362773 9998_4d9ce1e3104c6.jpgPost 362773 9998_4d9ce1ec91375.jpgPost 362773
Trim
Left Rear
Deluxe #84823-H1000 Left Rear
GL early #84823-H2001 Left Rear
GL 1972 #84823-H3300 Left Rear
non-1200 GL
GX #84823-H2300 Left Rear
GX 5-Speed 84823-H7200
Deluxe Rear
Deluxe 84823-H1000 Left Rear sedan attaches to boot lid
Deluxe_trunk_badge_B110.jpg 26891.jpgAlbum 26891
differs from similar looking front facelift badge
* #DELUXE grille badge: long studs for mounting through grille
*  DELUXE trunk badge: small pins for surface mount
21439.jpgAlbum 21439 16172.jpgAlbum 16172 14817.jpgAlbum 14817 24335.jpgAlbum 24335
GL Rear 1970-1971
GL early 84823-H2001 Left Rear sedan & coupe
25776.jpgAlbum 25776 25777.jpgAlbum 25777 25660.jpgAlbum 25660 20864.jpgAlbum 20864 174_5d79542f7af02.jpgPost 492571
GL Rear 1972
GL 1972 84823-H3300 Left Rear Facelift sedan & coupe
174_5d775d43af58d.jpgPost 492555 174_5d7954674ae37.jpgPost 492571
174_5b348e2e94666.jpgPost 488731
GX Rear
Rear GX "see-through" script. Used in Japan and South Africa markets.
174_5d756dcaab01a.jpgPost 492517 174_5d756dd73c003.jpgPost click for topic
84823-H2300 trim badge GX MARK 'GX'
* 1970-1972 Japan
* 1974-1976 South Africa
Used by coupe on Right Side
174_5d74ccd7de40e.jpgPost 492514 11785.jpgAlbum 11785
Used by sedan on Left Side
17111.jpgAlbum 17111 2305.jpgAlbum 2305 25662.jpgAlbum 25662 174_5d756dc157e69.jpgPost 492517
compare to #front GX badge which is not see-through but has a solid background attached
18053.jpgAlbum 18053
approximately 10cm wide
9930.jpgAlbum 9930 174_5d756dac67030.jpgPost 492517
Make your own GX badge
23911.jpgAlbum 23911 23912.jpgAlbum 23912 23913.jpgAlbum 23913 23914.jpgAlbum 23914
Transmission
  • 3-speed cars did not have a gearbox badge
  • 4-speed cars were badged "Sports"
Sports
79200-H1020 MARK-"Sports" sedan 4-speed
79200-H1060 MARK-"Sports", with sealing washer
"Sports" badge - 4-speed Center Rear (left of license plate)
sports_badge.jpg 20865.jpgAlbum 20865 27820.jpgAlbum 27820
"Sports" 4-speed - to right of license plate - 1972 GL Sedan rear
25977.jpgAlbum 25977 755.jpgAlbum 755
Automatic
#79200-H1020 Early "Full Automatic"
9784.jpgAlbum click to view
79200-H2820 Late "Full Matic" from '71 April (also used by coupe), 79200-H3200 1972
fullmatic.jpgAlbum click to view 26202.jpgAlbum 26202
N22 Coupe badge on sedan ('Nissan Automatic')
26079.jpgAlbum 26079
79200-H1020
Used on sedan
174_5d744a228ad84.jpgPost 492502 9784.jpgAlbum 9784
Used on early Coupe
