Stock Wheels
- 12" diameter
- 4-inch wide
| wheels | B10 | B110 | 1977 US B210 A14 | 1980 NA B310 |
| size | 3-1/2 J-12 | 4 J-12 | 4-1/2 J-13 | 4-1/2 J-13 5 J-13 (aluminum) Canada w/A12A: 4J-12 |
| offset | ? | 30 mm | 30mm offset | 30mm 25 mm (aluminum) |
| tire size | ?-12 | 6.00-12 155SR-12 | 155SR-13 | 6.00-12 155SR13 175/70SR13 |
| balance | 10gr or less (0.35 oz) | 11gr or less | 10gr or less | |
| lugnut torque | 8-9kg-m (58-65 ft-lb) | 8-9kg-m | 8-10 |
13" Wheels
Most 13" Datsun steel wheels fit the 1200, for example, 510, 610, B210 however the B310 13" wheels do not clear the front brake calipers.
A particularly stock-looking choice is 510/1600 13" wheels with 510 hubcaps
The 510 has narrow wheels and look very stock on a 1000 or a 1200.
Datsun Option Wheels
Also see: B310_Options#Wheels
40300-N5825 WHEEL SET-ROAD ALUMINIUM, B TYPE (5JX13) 40300-W6625 WHEEL SET-ROAD ALUMINIUM, C TYPE (5JX13)
Also used on 200SX (S10 silvia) 1977-1979
Option B Wheel
First offered Feb 1976 for the GB211
Option C Wheel
New Zealand
Datsun dealer-installed option mag wheels
B310 Wheels
40300-W8300 WHEEL ASSY-ROAD(4 1/2-JX13) (STYLED) 0879-
with 'D' center caps 40343-H5710
NOTE: B310 13" wheels do not fit the B110 front hubs due to the shape of the wheel, particularly the deep well hits the B110 brake caliper.
ホイール
Sunny 1200 Race Wheels
Sports Options Catalog | Sports Options Parts
Race Road Wheel Parts 1 40300-H5021 ROAD WHEEL FR 8Kx14 inch 40300-H5020 ROAD WHEEL FR 9Kx14 inch 40397-N3120 SPACER-Safety Bolt (16) 40398-N3120 SEAL-Rubber (16) 2 40399-H50?? BOLT-Safety (16) 3 40209-A0220 SPACER-Road Wheel (4) for aluminum, t=5 4 40222-A0220 BOLT-Wheel FR (8) M12 x 1.25 x 50 5 40223-A0220 BOLT-Wheel RR (8) M12 x 1.25 x 50 6 40224-H5020 NUT-Wheel (16) (Taper) 7 40224-E7210 NUT-Wheel (16) (Taper) Chrome-plated cap nut
This is 4-spoke 14-inch. Aluminum alloy instead of the magnesium, size 8J and 9J.
Lug Nuts
M12x1.25 thread
- B210: 13/16" lug nuts
See main article Wheel Studs
Torque
- 8.0-9.0 kg/m (58-65 ft-lb)
Wheel Balance
Also See: Vibration
Wheel Offset
STOCK = 30 mm offset
Scrub Radius
Largest Sizes to Fit 1200
- Front: 3.25" is the maximum backspace (which is used by the stock 4" wheel). So if going wider, the Offset must be reduced from +30.
- Rear: +30 Offset works best with Datsun 1200, allowing the largest width tyres (205-width tyres).
Rear
Ute Rear
Weights
Stock Datsun 1200 Wheels (12 x 4) weigh 11 pounds each. Virtually all aftermarket alloy wheels are heavier, except for very expensive magnesium wheels.
See main article: Wheel Weights
Wheel Adapters
Wheel Spacers
See main article: Wheel Spacers
If the wheel offset is too negative, they will fit the fenders (guards) and there is nothing you can do except cut out the bodywork, perhaps fitting large flares.
Suppliers
See Rims
Aftermarket Wheels
See Rims
Compatible Wheels
- Rear-wheel drive #Toyota
- 1960s Ford Falcon and Mustang 4-lugᴵ (6-cylinder models)
- 1960-1964 Chevrolet Corvairᴵ (5.5 x 13 +25.4 with 61.1mm hub center)
- perfect for the rear
- may work with 1/4" spacer on fronts to clear the hub center & the brake caliper
- Some #FWD Rims. NOTE: The offset on most front-wheel drive wheels are too much to fit without spacers
- Rear-wheel-drive #Nissan-Datsun wheels
- Datsun B310 styled steel wheels fit the rear, but do not fit the front of Datsun 1200
- Datsun Z Rims 14"
- Uni-lug alloy wheels
- Rear-wheel-drive Mitsubishi e.g. #Sigma Rims
- Some #Saab
Many RWD 4-lug on 4.5 inch bolt centers fit. These are equivalent to "114.3 PCD" in metric conversion terms.
What WONT work:
- early Honda
- Isuzu/Holden Gemini
- Ford Escort/Cortina
- early Mazda
- Subaru
- some SAAB
- Ford Escort/Pinto/Mustang II/Mustang Fox 4-on-4.25 (PCD 4x108 mm)
- Chevrolet Vega/Monza 4-on-4" (PCD 4x101.6 mm)
FWD Rims
FWD rims are typically a high offset (+35 or more), and may require a spacer if used on a 1200. Stock 1200 wheels are +30, however if going wider than the stock 4" wide, less offset may be required.
- Acura Vigor 1991-1994
- Acura TC 1992-1995
- Ford Laser (KA to KH)
- Hyundai Excel
- Kia 2001- (67.1 center)
Saab Wheels
- Offset: 40 or 45 mm
- 1979-1983 SAAB 900
Sigma Rims
Australia * Chrysler Sigma 1978-1980 * Mitsubishi Sigma from 1981
1977-1980 #GE Sigma SE 14x5.5 with 195/65R14
1982 GH #Sigma Turbo rims 15 x 6 inch
GE Sigma SE
- 1977-1980 Australia GE Sigma SE
- 1976-1979 Japan Galant Lamba
- 1978-1983 USA Plymouth Sapporo
Sigma Turbo
1982 GH Sigma Turbo rims 15 x 6 inch 4x114.3 (Sigma Turbo was a limited run on 500 cars)
Toyota
All Corolla RWD rims are candidates for Datsun 1200, as are all Celica RWD (including Supra).
Nissan-Datsun Wheels
Bakkie Deluxe Wheels
B140 Champ with deluxe option wheels
Bakkie White-spoke Wheels
B140 Champ wheels (trail duster style aka white-spoke steels)
A-LINE "Spoke White" of the Steel Outback Range (8-spoke)
