Datsun model series B210 was marketed in various countries as Datsun Sunny (Japan), Datsun B210 (North America) or Datsun 120Y/140Y/160Y (worldwide). For the Japan market, the minor update to the Sedan & Coupe was numbered B211 (DEC 1975).
Index
badge photo searchᴵ | auction searchᴳ | closed searchᴳ
Main Forum discussion: POST B210/120Y badges
post your photos!
Early is 1973-1975 Late is 1976-1977
#JDM Early Sedan![]()
#JDM Early Coupe![]()
#JDM Van![]()
#JDM Late Sedan (B211)![]()
#JDM Late Coupe (KB211)![]()
Early Sedan
#Radiator Grille #C-Pillar #Rear
Radiator Grille
back to #Early Sedan
The early sedan grille used 'S' mark, chrome with color-painted inlay. Approximately 6cm wide. Early Japan 'S' Badge DX, GL, GX all differ "S".
Similar: * (gold) #Late B210 sedan Radiator Grille badge * (various) Early B210 sedan Radiator Grille badge * (white) PB210 Radiator Grille badge
Japan ORNAMENT KIT-grille (Sedan, Van) [intertwined 'S' mark] #white 62312-H5025 Van STD #green 62312-H5026 S-DX, Van-DX (緑) #yellow 62312-H5125 S-GL, Van Super-DX (黄) #red 62312-H5225 S-GX (赤)
white
62312-H5025 ORNAMENT KIT-grille Van STD
green
62312-H5026 ORNAMENT KIT-grille S-DX, Van-DX (緑)
yellow
62312-H5125 ORNAMENT KIT-grille S-GL, Van Super-DX
yellow GL - Sedan S-mark (user-fitted to a coupe grille)
Red
62312-H5225 ORNAMENT KIT-grille S-GX
C-Pillar
back to #Early Sedan * One piece 'Sunny' + icon (Coupe uses two-piece emblems) Tie-clasp style
C-pillar 'Sunny'
Early catalog 76854-H5000 EMBLEM-body side (R.H.) 'Sunny' S-T 76855-H5000 EMBLEM-body side (L.H.) 'Sunny' S-T
Late catalog 76854-H5300 EMBLEM SIDE REAR RH 'Sunny' =STR 76855-H5300 EMBLEM SIDE REAR LH 'Sunny' =STR
EMBLEM SIDE REAR 76854-H5300 RH 'Sunny' 2S-STD
C-pillar 'Sunny Deluxe'
early catalog 76854-H5310 EMBLEM-body side (R.H.) 'Sunny DX' 2-DX 76855-H5310 EMBLEM-body side (L.H.) 'Sunny DX' 2-DX 76854-H5010 EMBLEM-body side (R.H.) 'Sunny DX' 4-DX 76855-H5010 EMBLEM-body side (L.H.) 'Sunny DX' 4-DX
late catalog 76854-H5010 RH 'Sunny DX' =T 76855-H5010 LH 'Sunny DX' =T 76854-H5310 RH 'Sunny Deluxe' =GT 76855-H5310 LH 'Sunny Deluxe' =GT
C-Pillar 'Sunny GL'
early catalog 76854-H5400 EMBLEM-body side (R.H.) 'Sunny GL' 2-GL 76855-H5400 EMBLEM-body side (L.H.) 'Sunny GL' 2-GL 76854-H5100 EMBLEM-body side (R.H.) 'Sunny GL' 4-GL 76855-H5100 EMBLEM-body side (L.H.) 'Sunny GL' 4-GL
late catalog 76854-H5100 RH 'Sunny GL' A12,A14.GL 76855-H5100 LH 'Sunny GL' A12,A14.GL
C-Pillar 'Sunny GX'
early catalog 76854-H5200 EMBLEM-body side (R.H.) 'Sunny GX' 76855-H5200 EMBLEM-body side (L.H.) 'Sunny GX'
late catalog 76854-H5200 RH 'Sunny GX' S.A14.GX 76855-H5200 LH 'Sunny GX' S.A14.GX 76854-H5400 RH 'Sunny GL' H=GT 76855-H5400 LH 'Sunny GL' H=GT
Rear
Left side trunk lid (Early only) #'NISSAN FULL AUTO MATIC' #'5 SPEED'
Center trim badges - also used by #late sedan #Rear 'SUNNY' SEMI-DX #Rear 'SUNNY deLuxe' #Rear 'SUNNY GL' #Rear 'SUNNY GX'
84811-H5020 EMBLEM-trunk lid 'NISSAN FULL AUTO MATIC'
Similar: * PB210_Badges#Sedan_Rear 84811-H5050 EMBLEM-trunk lid (NISSAN FULL AUTO MATIC) * Export_B210_badges#Rear 84811-H6220 EMBLEM-TRUNK LID 'NISSAN AUTOMATIC' 79855-N2200 MARK 'NISSAN AUTOMATIC' * Sedan_badges#Automatic 84821-U0300 'Nissan Matic' blue 79200-H2820 "Full Matic" 79200-H3200 79200-H1020 "Full Automatic"
'5 SPEED'
84811-H5210 EMBLEM-trunk lid '5 SPEED'
84811-H5210 (PB210 shown; badge is same as B210)
Rear Center Trim Badge
Center trim badges and finisher - also used by #late sedan
EMBLEM-rear panel 79805-H5000 #Rear 'SUNNY' SEMI-DX 79805-H5010 #Rear 'SUNNY deLuxe' 79805-H5100 #Rear 'SUNNY GL' 79805-H5200 #Rear 'SUNNY GX' 01352-00011 WASHER-sealing (2) 01221-00011 NUT-flange (2)
REAR PANEL FITTING 79801-H5100 FINISHER-rear GL,GX 79806-H5100 SPACER-rear finisher GL,GX (2) 1973-1975 26558-H5000 WASHER-PLAIN 1976-1977 01221-00011 NUT GL,GX (4) 1973-1975 01221-00071 NUT 1976-1977
Japan REAR PANEL FITTING (center of back panel finisher, between taillights)
Rear 'SUNNY'
79805-H5000 EMBLEM-REAR 'SUNNY' STR, SMDX
Rear 'SUNNY deLuxe'
79805-H5010 EMBLEM-REAR 'SUNNY deLuxe'
Rear 'SUNNY GL'
79805-H5100 EMBLEM-REAR 'SUNNY GL' * white background
Rear 'SUNNY GX'
79805-H5200 EMBLEM-REAR 'SUNNY GX' * approximately 105mm wide
Late Sedan
#Grille #Hood/Bonnet #C-pillar #Rear
B211 Sedan Front & Side Emblems | Rear Emblems
Radiator Grille
back to #Late_Sedan
62311 08510-51212 SCREW 62312-H7425 JDM ORNAMENT-FRONT SEDAN, VAN [gold 'S' intertwined mark]
#LATE #EARLY PB210 gold various white Deeper slant Slant Slantiest flat face raised face flat face single screw long stud two posts
62312-H7425
Hood/Bonnet
back to #Late_Sedan
For the B211, GX twin carb (GX-T) had hood badge. GX single carb (GX) did not.
Japan 65852 MARK-HOOD 65800-H7510 A14T 'GX-T' Sedan, Coupe
65800-H7510
This badge is used by both sedan and coupe, as the hood (bonnet) is identical for both.
similar to: #Side badge, which has two fastening pins
65800-H7510 MARK-HOOD A14T フード マーク
appears to have 3 fastening pins, while the coupe side badge has only two
C-Pillar
back to #Late_Sedan
all dates (also used by early sedan) #C-pillar 'Sunny' #C-pillar 'Sunny Deluxe'
1976 tie-bar style badge (also used by early sedan) #C-pillar 'Sunny GL' #C-pillar 'Sunny GX' #1976 'Sunny GX-T'
1977 Medallion type emblems #1977 GL #1977 GX #1977 GX-T
C-pillar 'Sunny GX'
1976 'Sunny GX-T'
-7701 A14T Twin carb 76854-H5710 RH MARK-SIDE REAR 'Sunny GX-T' S.A14.GX
1977 GL
7702- [round emblem] 76854-H7511 EMBLEM-SIDE REAR RH 'Sunny GL' =GTR [2-door] 76855-H7511 EMBLEM-SIDE REAR LH 'Sunny GL' =GTR [2-door] 76854-H7512 EMBLEM-SIDE REAR RH 'Sunny GL' S.A12,A14.GL [4-dr] 76855-H7512 EMBLEM-SIDE REAR LH 'Sunny GL' S.A12,A14.GL [4-dr]
1200 (H74) * GTR GL 4-speed 2-dr * GT GL 4-speed 4-dr 1400 (H75) * H=GT GL 4-speed 4-dr * H=GF GL 5-speed 4-dr * H=GA GL Automatic 4-dr
2D Photos needed of 2-door GL
1977 GX
76854-H7514 EMBLEM-SIDE REAR RH 'Sunny GX' S.A14.GX 7702- 76855-H7514 EMBLEM-SIDE REAR LH 'Sunny GX' S.A14.GX 7702-
1977 GX-T
76854-H7517 'Sunny GX-T' S.14T.GX 76855-H7517 'Sunny GX-T' S.14T.GX
About GX-T: Twin debut JUL 1976HB211/HKB211 1400 (H75) * H=JTK A14 GX 4-speed Twin * H=JFK A14 GX 5-speed Twin
Rear
back to #Late_Sedan
#'NISSAN' rectangle badge #'NAPS' 84890-F2000 #Rear center Trim badge #'1400' badge
84814-H7401 MARK-REAR 'NISSAN' diagram IDS: 84815,84819 location: rear left
* B211 JAPAN Sedan * #KB211 JAPAN Coupe * B210 JAPAN #Van OCT 1975- * B310 rear left * S130 280ZX/Fairlady Z hatch * S110 Sylvia/200SX
Similar: * 'NISSAN' over plain rectangle Truck_Badges#Rear 8910- 62311 62392-G1265 'NISSAN' 8910-
84890-F2000
Badge for NAPS (Nissan Anti-Pollution System)
- GB211 Rear
- B211 Sedan #Rear
- KB211 Coupe #Rear
- VB210 Van #Rear
84890-F2000 MARK-REAR 'NAPS' [blue/green]
EMBLEM-REAR - single-piece (Coupe uses two-piece emblems)
84815 - same as early sedan 79805-H5000 #Rear 'SUNNY' STR, SMDX 79805-H5010 #Rear 'SUNNY deLuxe' 79805-H5100 #Rear 'SUNNY GL' 79805-H5200 #Rear 'SUNNY GX'
84819 - 1976-1977 79805-H751x #Rear 'SUNNY GX-T' Sedan
Rear 'SUNNY GX-T'
79805-H7510 ? 'SUNNY GX-T' *S.14S.GX [or 79805-H7515] 79805-H751x EMBLEM-REAR 'SUNNY GX-T' Sedan
'1400' badge
diagram ID 84819 84812-H7500 MARK-REAR '1400' A14S,A14T * B211 rear, right side * KB211 rear, right side
GX-T Badges
GX-T sedan badges
- #Bonnet GX-T badge (same as coupe)
- #C-pillar GX-T badge
- #Rear GX-T badge
- GX-T steering wheel medallion
Early Coupe
Radiator Grille
ORNAMENT KIT-radiator grille 62312-H5525 JAPAN K-all ['S' shield-shaped mark] 62312-H5526 Export ['D' shield-shaped mark] USA KIT-ORNAMENT RADIATOR GRILLE -0776
62312-H5525 JDM ORNAMENT KIT-radiator grille
Side
DX 'Sunny' + diamond badge GL 'Sunny' + 'GL' GX 'Sunny' + 'GX'
76855-H5500 EMBLEM-body side (L.H.) K-all 76854-H5500 EMBLEM-body side (R.H.) K-all
Rear
Japan Early Coupe rear center 79843-H5600 EMBLEM-rear finisher 'GL' 79843-H5700 EMBLEM-rear finisher 'GX' Early Coupe rear right side 79842-H5500 EMBLEM-rear finisher 'Sunny' Early Coupe left trunk lid 98042-H5700 BADGE '5 SPEED' 98042-H5600 MARK 'NISSAN FULL AUTO MATIC'
Late Coupe
Van
All vans in the Japan market were VB210 -- there was no VB211.
Late Van Badges (1976-1977 from October 1975)
Front
Van uses Sedan radiator grille emblems.
* Early![]()
* Late![]()
Side
Japan Early (to SEP 1975) 98811-H6500 EMBLEM-body side 'Sunny' (2)
Japan Late Van (from OCT 1975) Side EMBLEM SIDE REAR 98811-H6500 4V [same as early] 98811-H6700 *V-VA=T
Rear
JAPAN right side early/late van * Looks like early sedan badges but part numbers differ 98821-H6500 'Sunny' V.SMDX, V.STD 98821-H6501 'Sunny DELUXE' V.DX 98821-H6600 'Sunny SUPER DELUXE' V.SPDX
98821-H6600 (reverse side is marked '98821H6600')
left side lower 96905-18100 LABEL-loading capacity (400kg) Van
left side upper #84814-H7401 V.SMDX 'NISSAN' (84815) #84890-F2000 'NAPS' (84819)
Option
1973 B210 Options Catalog G8840-H5000 Badge (10 piece 1 set) 1,000 yen バッジ (10ケ1セット) B210, PB210 Option Parts C-203 page C3 G8840-H5000 Badge Star Mark バッジ スターマーク入
Please feel free to install it. Accent parts that add personality to your car.
Rear
Late B210 sedan & coupe shares some rear badges
Left side of trunk lid 84814-H7401 MARK-REAR 'NISSAN' Sedan,Coupe,Van 84890-F2000 MARK-REAR 'NAPS' Sedan,Coupe,Van![]()
Right side of trunk lid 84814-H7401 MARK-REAR '1400' Sedan, Coupe
エンブレム バッジ マーク
