PB110 Sunny Excellent was fitted with L-series OHC engine L14. This L14 engine was the third L-series design after the L13 (Aug 1967), L20 (Nov 1967) & L16. At 1428 cc, it was essentially a de-stroked L16, having the same bore, but a new reduced crankshaft stroke, which was longer than the L13 but shorter than the L16.
The Sunny Excellent PB110 was fitted with 1400cc L14 engine, a smaller-displacement version of the L16 fitted to the Datsun 1600. This is an overhead camᵂ engine. Both a single carb and dual-carb engine was available. Top speed was 155kmh, up 5km from the Datsun 1200.
DX and GL models had a single-carb engine, while the GX had dual sidedraft carburetors (GX originally meant GL with Twin Carbs).
PB110 was fitted with L14S (single carburetor engine).
- 85 HP
GX models used L14T (twin carburetor engine).
- 95 HP
GX engine with Twin Hitachi carburetors
1972 Orange air cleaner | 1971 Blue air cleaner
L14 engine with aftermarket dual sidedraft carburetors
Dellorto DLHA| (Mikuni PHH)
These engines were pulled from the Datsun Bluebird 510 parts bin, with some modifications.
510: L13 engine (1967) Applied Model Codes 210-218 N510: L14 engine A86,A88-A89 P510: L16 engine 219-222 H510: L18 engine A87,A94
Nissan Part Numbers Applied Model Codes: 122: SP310 210: 510-S 219: P510 220: P510-TK 230: PL510 A08: 510 ('69) A35: P510 ('69) A49: P510S ('70) A51: P510TK ('70) A87: H510TK A89: N510T A92: 510 2-dr Automatic H23: B110GTK (GX 4-speed Sedan) H25: KPB110 ('71) H27: KPB110GR ('71) N04: (K)P510(A)TK ('71)
Nissan Factory Rotary Engine
Under the bonnet of this Excellent is the rotary engine used to advance the development of NISSAN's new rotary.
Rocker Cover
'Datsun OHC'
13264-A4900 COVER ASS'Y-rocker L14S [breather tube pointing back]
* Same as 510 L14, L16 except SSS [per 1970.8 catalog]
* Same as later L13 cover, differs from early L13 cover
13264-A5100 COVER ASS'Y-rocker L14T [right angle breather tube]
* Same as 510 L16 SSS [per 1970.8 catalog]
Cylinder Head
Single Carb
- 11041-H2510 HEAD ASS'Y-cylinder L14
- 11041-H2511 HEAD ASS'Y-cylinder (from '73-4) L14
- 11041-H2512 HEAD ASS'Y-cylinder (from '73-7) L14
Twin Carb A87 = H510TK
- 11041-21901 HEAD ASS'Y-cylinder L14T
- Same as 510 L16 SSS, CSS
- 11041-A8712 HEAD ASS'Y-cylinder (from E# L14-098246) L14T
- Same as 510 L16 (from '72) which replaced all former L16 heads
- 11041-A8713 HEAD ASS'Y-cylinder (from '73-5) L14T
- 11041-A8714 HEAD ASS'Y-cylinder (from '73-7) L14T
Camshaft
- 13001-21000 CAMSHAFT L14S
- Same as 510 L14
- 13001-H2700 CAMSHAFT L14T
- Same as all later 510 L16S single carb (except LPG) [1974.3 catalog]
Intake Manifold
Single Carb
- 14002-A8901 MANIFOLD ASS'Y-intake
- 14002-A8903 MANIFOLD ASS'Y-intake
- 14002-A8925 MANIFOLD ASS'Y-intake
Twin Carb
- 14002-22026 MANIFOLD ASS'Y-intake
- 14002-N0400 MANIFOLD ASS'Y-intake
Exhaust Manifold
Single Carb
- 14004-A3500 MANIFOLD-exhaust
- Same as 510 L14
- Same as later 510 L13 (from E#/L13-187492)
- Same as later 510 L16 (from E#/L16-95967)
Twin Carb
- Same as single carb engine
Carburetor
Single Carb
* 16010-A8900 CARBURETOR ASS'Y-auto choke (213282-211) L14S (M/T) * 16010-A9200 CARBURETOR ASS'Y-auto choke (213282-231) L14S (A/T)
Hitachi Twin Carb dome-tops
- 16010-H2710 CARBURETOR ASS'Y-twin (HJL 38W-5) L14T
- 16554-H2710 JET-needle L14T
- 16346-12210 SPRING-suction L14T
Air Cleaner
Single Carb
- 16510-A0800 AIR CLEANER KIT
- 16500-A8901 AIR CLEANER ASS'Y
- 16500-H2306 AIR CLEANER ASS'Y
- 16500-H2500 AIR CLEANER ASS'Y (from '72-6)
- 16500-H2505 AIR CLEANER ASS'Y (from '72-6)
Twin Carb
- 16500-H2700 AIR CLEANER ASS'Y (up to '71-9) [thin oval (blue)]
- 16500-H2710 AIR CLEANER ASS'Y (from '71-10) [fat oval (orange)]
