Carburetor Parts
From Datsun 1200 Club
These are important parts, oftentimes overlooked, but can have a large effect on how well the carburetor works.
Remanufactured Carburetor
http://www.rockauto.com
* TOMCO 10002A AT w/Electric Choke $200.79,
  MT w/Electric Choke
  $204.79 USD Carburetor (remanufactured)
Miscellaneous Carburetor Parts
Float
Plastic float
e72109816kojiya_2006-img600x504-119.jpg e72109816kojiya_2006-img600x476-119.jpg e72109816kojiya_2006-img600x392-119.jpg
Fuel Inlet Valve
16101-H1000 VALVE-NEEDLE
* DCG306/DCH306
* Hitachi Twin Carb
26312.jpgAlbum 26312
Choke Pull Off
Hitachi DCH choke pull-off
There are several variations, so get the right one for your carburetor.
Choke Pull Off
* Nissan 16011-H3910
* Tomco 7248, Carter 202-854
  19995.jpgAlbum 19995
* TOMCO 7211 (Type HI-2), A12A 1981-1982 (strait fitting) $9
* TOMCO 7213 A14 1978-1981 (80-degree fitting)
  19997.jpgAlbum 19997
* 7281 1978-1980
  19996.jpgAlbum 19996
* TOMCO 7386 A12A 1980 (90-degree fitting)
* TOMCO 7390 A14 1975-1978 (90-degree fitting) $8
Fuel-cut Valve
Anti-Diesel valve
* TOMCO 8134 $36
  * Chevy Luv Truck 1975-1980
  * Ford Courier Truck 1979-1980
  * Honda 1973-1976
  * Mazda 1975-1978
  * Datsun 1973-1983
  * Subaru 1974-1980
Insulator
The bakelite insulator isolates the carb from the hot engine parts, resulting in more consistent jetting
22231.jpgAlbum 22231
1972 added this metal bore extension for the primary bore to improve off idle-performance
For sidedraft manifolds without a heat source, you can use this factory A-series heat plate, connect it to the coolant pipes
30365.jpgAlbum 30365
Heat Shield
19113.jpgAlbum 19113
18239.jpgAlbum 18239
Throttle Chamber
23301.jpgAlbum 23301
Gaskets
Also see: Carburetor Part Numbers
Repair Kit
A kit usually contains:
* new accelerator pump
* gaskets and o-rings
* new inlet valve
* parts breakdown diagram
* brief instructions
  • Some kits contain new jets but be careful they are the correct ones for your engine.
  • Some gasket kits contain more than one style of top gasket.
  • Kits do not contain the auto-#Choke Pull Off, one of the most prone to break parts
* H16 (B110, early B210)
* H88 (early B310)
* H8805 (late B310, B120 1981-1989)
26811.jpgAlbum click to view
26814.jpgAlbum 26814 26813.jpgAlbum 26813 26812.jpgAlbum 26812
New piston comes with the more complete kits (with attached rubber or leather skirt), but was also sold separately by Datsun
16151-18010 PISTON
29912.jpgAlbum 29912
Gasket Set
Contains gaskets only. Fits all B110 and early B120.
Nissan 16455-H6201 GASKET KIT contains 1) top gasket 2) throttle chamber gasket 3) pump cover
16701.jpgAlbum 16701 16702.jpgAlbum 16702 16744.jpgAlbum 16744
Top gasket = choke chamber gasket
Throttle Chamber Gasket
1970-1974 without the extra hole
25781.jpgAlbum 25781
Manifold gaskets
Two needed, one for each side of spacer. They can usually be re-used.
8765.jpgAlbum 8765
Late Model A12 (8910-) manifold/insulator gasket 16174-19B00
22375.jpgAlbum 22375
16154.jpgAlbum 16154
Part Numbers, B110
See Index#Fuel
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Carburetor_Parts"
This page has been accessed 23,966 times. This page was last modified 04:58, 27 April 2025. Content is available under Datsun 1200 Club.
