Interior
From Datsun 1200 Club
Category: Body
Datsun 1200 standard interior was elk-pattern black vinyl. Blue, Yellow, Ivory and Brown were also available in some markets, as well as fabric patterns.
Interior Trim Colors
See also: Colors
See also: Upholstery
  • Black was the original interior trim color.
  • Regardless of exterior/interior color, blue vinyl floor mats were standard.
  • In most countries black interior was most common.
STD: Black vinyl leather
DX:  Black, gray or yellow vinyl leather
GL:  Tricot cloth
G cloth (GL models)
D (黒) Black Vinyl
K (黄) Yellow Vinyl
  (ベージュ) beige Vinyl
  (灰) Gray Vinyl
  (緑) Green Vinyl
27503.jpgAlbum 27503
Japan - gray only came with certain colors
Gray (with 820 Red body color)
Gray (with 645 Blue body color)
GX black striped fabric
   brown striped fabric
GL black tricot
   blue tricot
DX black vinyl leather
7724.jpgbrochure
USA 1971-1972
Black
Grey to 1970.11
Yellow
USA 1973 (starting 1972.7)
* Fire-retardant materials
Blue interior
Beige (optional with 940 Yellow Green exterior)
Black (optional after January 1973)
USA grey
20677_57601c138c408.jpgPost 479254
Flammability of Interior Materials
1973 Blue USA (fire-retardant materials)
7566.jpgAlbum 7566
MVSS: 302
September 1, 1972 Interior materials must be tested as to their flammability...
FR Seat
RR Seat
Head Lining
Sun Visor
Head Restraint
Door Finish
Body Side Finish
Pillar Trim
Pillar Pad Trim (urethane)
Floor Side Trim
RR Wheel House Trim
Tonneau Cover
7664.jpgAlbum 7664
EQUIPMENT VARIATION
4. FLAMMABILITY OF INTERIOR MATERIALS
MVSS: 302
Applicable to: Passenger cars and trucks manufactured on or after September 1, 1972.
Requirements: Interior materials must be tested as to their flammability. The test sample of material must be burnt in a test apparatus under the conditions as required by regulations.
The rate of transmission of burning flame should not exceed 4 in/min.
1. In compliance with the requirements, the following materials have been modified:
Interior material leather number list,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
Parts modifiedSedanCoupe
FR SEAT COMP. (DRIVER, ASSIST)
Seat GoreEB-211, LH-202(Opt)LB-211, LH-202 (Opt)
Seat MainI.B-213, LH-203 (Opt)LB-212, LH-203 (Opt)
RR SEAT COMP. (CUSHION, BACK)
Seat Gore""""
Seat Main"'"'
HEAD LININGLH-206LH-207
SUN VISORLH-206LH-207
HEAD RESTRAINTLB 211, LH-202 (Opt)<-
FINISH DOORLB-211, LH-202 (Opt)<-
FINISH BODY SIDELB-211, 1H-202 (Opt)<-
PILLAR TRIMLB-211, 1H-202 (Opt)<-
PILLAR PAD TRIM (Urethane)--
FLOOR SIDE TRIMLB-211<-
RR WHEEL HOUSE TRIMLB-211, LH-202 (Opt)<-
TONNEAU COVER (Coupe option)-LB-211
L: Vinyl leather B: Blue H: Beige
Australia
Locally assembled sedans often came with brown, red, or white interiors.
Black Deluxe
6457.jpgAlbum 6457
White Deluxe
10456.jpgAlbum 10456
Red Standard
11145.jpgAlbum 11145 11179.jpgAlbum 11179 11178.jpgAlbum 11178
Truck
Black was exclusively used for Ute 1971-1978
11149.jpgAlbum 11149 18747.jpgAlbum 18747
Brown (Code C) was exclusively used 1978-1989
20835.jpgAlbum 20835 15947.jpgAlbum 15947
Gray (Code K) was exclusively used 1989-1994, along with black vinyl floor mats
16653.jpgAlbum 16653 17143.jpgAlbum 17143
1978-1989 Brown
14160.jpgAlbum 14160 16664.jpgAlbum 16664
2005 bakkie with Bench Seat
22420.jpgAlbum 22420
Sunvisors
See also: Visors
Door Trim
Door
80510-H1000 ESCUTCHEON-REMOTE CONTROL RH NLA
80511-H1000 ESCUTCHEON-REMOTE CONTROL LH NLA
Window Trim
Front window - 2-dr sedan
* 80260-H1000 Handle-vent R $19.67
* 80261-H1000 Handle-vent L $19.67
* 80760-H1000 Handle-regulatr $24.00
Rear window - 2-dr sedan
* 76828-H1200 Cover-hinge [rear window] $1.02 USD
* 76870-H1200 Handle-window RR $39.17 USD
* 76871-H1200 Handle-window RL $40.62 USD
** 80234-H1000 WASHER-BRACKET PIVOT $5.83 USD
* 76832-H1201 HINGE-SIDE WINDOW (4) NLA
Hinge Covers
9931.jpgAlbum 9931 9988.jpgAlbum 9988 9990.jpgAlbum 9990
Also consider B210 gray part:
76828-H5300, 76828-H5301 COVER-SIDE WINDOW HINGE B210 [GRAY]
22110.jpgAlbum 22110
Head Liner
The head lining covers and insulates the roof panel.
See also: Headliner
Kick Panel
Kick panel is the front side panel, in front of door, under dash.
Package Tray
The package tray is the under-dash compartment a.k.a. parcel shelf
Coin trays
The seat riser trim is the little plastic pockets next to the doors.
Below-door Trim
This trim covers the floor pan sides, below the doors.
floor side, front
Parcel Shelf
Parcel shelf is the area above the rear seat, under that rear window.
Also See
See also: Carpet
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Interior"
This page has been accessed 33,037 times. This page was last modified 17:51, 21 March 2025. Content is available under Datsun 1200 Club.
