PB110 Engine
From Datsun 1200 Club
Category: PB110
PB110 Sunny Excellent was fitted with L-series OHC engine L14. This L14 engine was the third L-series design after the L13 (Aug 1967), L20 (Nov 1967) & L16. At 1428 cc, it was essentially a de-stroked L16, having the same bore, but a new reduced crankshaft stroke, which was longer than the L13 but shorter than the L16.
The Sunny Excellent PB110 was fitted with 1400cc L14 engine, a smaller-displacement version of the L16 fitted to the Datsun 1600. This is an O.H.C. (overhead cam) engine design. Both a single carb and dual-carb engine was available. Top speed was 155kmh, up 5km from the Datsun 1200.
See also: L-series Engine
DX and GL models had a single-carb engine, while the GX had dual sidedraft carburetors (GX originally meant GL with Twin Carbs).
7714.jpgbrochure
PB110 was fitted with L14S (single carburetor engine).
  • 85 HP
GX models used L14T (twin carburetor engine).
  • 95 HP
85 hp single carb L14 engine
851.jpgAlbum 851 26271.jpgAlbum 26271
GX 95 hp twin carb L14 engine
174_65af59a396c41.jpgPost 498207 174_65af5988a0a40.jpgPost 498207
GX engine with Twin Hitachi carburetors
1972 Orange air cleaner | 1971 Blue air cleaner
10318.jpgAlbum 10318 174_5d50d9287d540.jpgPost 492213
L14 engine with aftermarket dual sidedraft carburetors
Dellorto DLHA| (Mikuni PHH)
1534.jpgAlbum 1534 18719.jpgAlbum 18719
These engines were pulled from the Datsun Bluebird 510 parts bin, with some modifications.
 510: L13 engine (1967) Applied Model Codes 210-218
N510: L14 engine A86,A88-A89
P510: L16 engine 219-222
H510: L18 engine A87,A94
Nissan Part Numbers Applied Model Codes:
122: SP310
210: 510-S
219: P510
220: P510-TK
230: PL510
A08: 510 ('69)
A35: P510 ('69)
A49: P510S ('70)
A51: P510TK ('70)
A87: H510TK
A89: N510T
A92: 510 2-dr Automatic
H23: B110GTK (GX 4-speed Sedan)
H25: KPB110 ('71)
H27: KPB110GR ('71)
N04: (K)P510(A)TK ('71)
30547.jpgAlbum 30547 30548.jpgAlbum 30548 30549.jpgAlbum 30549 30550.jpgAlbum 30550 30551.jpgAlbum 30551
Nissan Factory Rotary Engine
Under the bonnet of this Excellent is the rotary engine used to advance the development of NISSAN's new rotary.
Rocker Cover
'Datsun OHC'
13264-A4900 COVER ASS'Y-rocker L14S [breather tube pointing back]
* Same as 510 L14, L16 except SSS [per 1970.8 catalog]
* Same as later L13 cover, differs from early L13 cover
30541.jpgAlbum 30541
13264-A5100 COVER ASS'Y-rocker L14T [right angle breather tube]
* Same as 510 L16 SSS [per 1970.8 catalog]
30542.jpgAlbum 30542
Cylinder Head
Single Carb
11041-H2510 HEAD ASS'Y-cylinder L14
11041-H2511 HEAD ASS'Y-cylinder (from '73-4) L14
11041-H2512 HEAD ASS'Y-cylinder (from '73-7) L14
Twin Carb A87 = H510TK
11041-21901 HEAD ASS'Y-cylinder L14T
* Datsun 510 L16 SSS, CSS
11041-A8712 HEAD ASS'Y-cylinder (from E# L14-098246) L14T
* Datsun 510 L16 (from '72) also replaced L16T heads
11041-A8713 HEAD ASS'Y-cylinder (from '73-5) L14T
11041-A8714 HEAD ASS'Y-cylinder (from '73-7) L14T
Camshaft
  • 13001-21000 CAMSHAFT L14S
    • Same as 510 L14
  • 13001-H2700 CAMSHAFT L14T
    • Same as all later 510 L16S single carb (except LPG) [1974.3 catalog]
Intake Manifold
Single Carb
  • 14002-A8901 MANIFOLD ASS'Y-intake
  • 14002-A8903 MANIFOLD ASS'Y-intake
  • 14002-A8925 MANIFOLD ASS'Y-intake
Twin Carb
  • 14002-22026 MANIFOLD ASS'Y-intake
  • 14002-N0400 MANIFOLD ASS'Y-intake
Exhaust Manifold
Single Carb
  • 14004-A3500 MANIFOLD-exhaust
    • Same as 510 L14
    • Same as later 510 L13 (from E#/L13-187492)
    • Same as later 510 L16 (from E#/L16-95967)
22595.jpgAlbum 22595
Twin Carb
    • Same as single carb engine
Carburetor
Single Carb
* 16010-A8900 CARBURETOR ASS'Y-auto choke (213282-211) L14S (M/T)
* 16010-A9200 CARBURETOR ASS'Y-auto choke (213282-231) L14S (A/T)
174_65ae3bd42f3c0.jpgfeature
Hitachi Twin Carb dome-tops
  • 16010-H2710 CARBURETOR ASS'Y-twin (HJL 38W-5) L14T
  • 16554-H2710 JET-needle L14T
  • 16346-12210 SPRING-suction L14T
Air Cleaner
Single Carb
  • 16510-A0800 AIR CLEANER KIT
  • 16500-A8901 AIR CLEANER ASS'Y
  • 16500-H2306 AIR CLEANER ASS'Y
  • 16500-H2500 AIR CLEANER ASS'Y (from '72-6)
  • 16500-H2505 AIR CLEANER ASS'Y (from '72-6)
    30540.jpgbrochure
Twin Carb
  • 16500-H2700 AIR CLEANER ASS'Y (up to '71-9) [thin oval (blue)]
    30539.jpgbrochure
  • 16500-H2710 AIR CLEANER ASS'Y (from '71-10) [fat oval (orange)]
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=PB110_Engine"
This page has been accessed 10,156 times. This page was last modified 00:57, 2 September 2025. Content is available under Datsun 1200 Club.
