Remote Clutch Master Cylinder
From Datsun 1200 Club
Category: Clutch
A remote-mounted Hydraulic clutch Master cylinder may also be needed if there is not enough room in the engine compartment.
Mount the clutch master inside the passenger compartment -- under the dash -- and connect it to the gearbox slave cylinder via a hydraulic line.
  1. Fabricate L-shaped bracket, bolt (or weld) to the under-dash steering column brace
  2. Lengthen clutch pedal, attach the master rod ABOVE the fulcrum
  3. Place the filler tube under the dash, connect to master via rubber hose
24294.jpgAlbum 24294
Not enough room after a big Engine Swap? Move the clutch master under the dash!
18813.jpgAlbum 18813 18812.jpgAlbum 18812
PIGDOG
PIGDOG used a A20 Celica (1970-1977) master cylinder and replaced the Reservior with a banjo fitting
18890.jpgAlbum 18890 18891.jpgAlbum 18891 18893.jpgAlbum 18893 19198.jpgAlbum 19198 19199.jpgAlbum 19199 19200.jpgAlbum 19200
Celica first generation A20 (A21, A22, A25, A27, etc.)
Banjo fittings are available at auto parts stores in generic metric sizes. PIGDOG used one off a Nissan Skyline#R33 power steering pump.
HiAce brake reservoir with one of the outlets blocked off was mounted in the engine bay. Big hose is just the feed from the reservoir so no pressure in there....same clamp that was on there stock
Extended pedal
18892.jpgAlbum 18892
Old setup - 2nd pedal box
18894.jpgAlbum 18894 18895.jpgAlbum 18895 18896.jpgAlbum 18896
Girling
Under-dash mounted Girling clay pipe master
4859.jpgAlbum 4859
Girling "claypipe" master cylinder, available in 5/8" and 3/4" bores (about $70 AUD). Threads are 3/8 unc for pipe outlet and 7/16 unc for fluid in
Reservoir in engine by tucked into the corner. A quick perusal at the auto wrecking yard will find many similar reservoirs on FWD cars
4856.jpgAlbum 4856
Urvan
http://en.wikipedia.org/wiki/Nissan_Caravan
  • Use with Nissan Urvan remote-fill tops
  • A simple 90-degree bracket is fabricated to mount it to the under-dash steering column brace
1851.jpgAlbum 1851
Sentra
http://en.wikipedia.org/wiki/Nissan_Sentra (Nissan Sunny FWD)
Nissan Sentra Clutch Master Cylinder
9524.jpgAlbum 9524 9525.jpgAlbum 9525 9668.jpgAlbum 9668
Fluid reservoir is connected to the cylinder via a rubber hose.
9526.jpgAlbum 9526
Similar to Sentra B15U clutch master 30610-5M007 (top outlet)
Lancer
http://en.wikipedia.org/wiki/Mitsubishi_Lancer_(A70)
For ideas, could something like this be used on a 1200?
Cable-to-Hydraulic custom remote clutch m/c found on Mitsubishi LA Lancer
7656.jpgAlbum 7656
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Remote_Clutch_Master_Cylinder"
This page has been accessed 10,751 times. This page was last modified 06:38, 30 January 2017. Content is available under Datsun 1200 Club.
