B210 Lights
From Datsun 1200 Club
Categories: Datsun B210 | Body Electrical System
Front Lights
Japan B210 used twin-reflector front lamps, similar to late B120.
20150607210845329.jpg 5296.jpgAlbum 5296
Worldwide B210 had front combination lights similar to 1974-up ute:
322338478.jpg 18103_54afab67e76d9.jpgPost 462595
For more details, see: Front_Combination_Lamp#B210
B110: single reflector, spade connectors
B210: double reflector, square connector
B120: double reflector, spade connectors (1974-up)
Worldwide B210 front combination lights were below the B210 Bumpers, with cutouts in the bumper for clearance.
1956.jpgAlbum 1956 7431.jpgAlbum 7431
North America B210 had front combination lights in the grille.
H58 PB210/GB610
Japan: All red with two bulbs
* type 1073 bulb 26717-89900 (23W) for turn signal
* 26715-89920 (8/3.2W)
Australia: Amber and clear
26126-H6100 LH [Ever Wing PL-4646E]
26121-H6100 RH [Ever Wing PL-4645E]
Europe: Amber and clear
North America: All amber with single bulb
* Single type 1034 bulb (26717-89920, 12V-23/8W)
Fog Lamps
Worldwide also offered Fog Lamps options (not available in North America where the combo lamps were in the grille)
14242.jpgAlbum 14242 20639.jpgAlbum 20639
Side Lights
H50 vertical style
H58 parallelogram style (PB210 & GB211)
A55 Export horizontal style (amber lens, H62/H72 assy)
A55 North America rear reflector (red lens) (H69 coupe/H72 sedan)
H50 Japan market Datsun B210 Flasher lamp
H58 Sunny Excellent style
Export B210 Side Lamp uses the 240Z pointed-rectangular lenses & trim. Same as late 510 in USA. North America models did not flash, only used as running lamps/reflector.
Australia
15483.jpgAlbum 15483 B210_side-marker-lamp_AUS.jpg 24061.jpgAlbum 24061
North America rear side reflector
20762_.jpg generic.jpg 12838.jpgAlbum 12838 20762.jpgAlbum 20762
Tail Lights
B210 SEDAN
3282.jpgAlbum 3282 4252.jpgAlbum 4252 5140.jpgAlbum 5140
26551-H6200 USA (perhaps a different reflective standard?)
26551-H5000 JDM (looks the same as USA)
Sedan with rear-mounted number plate
B210 L-16 powered SEDAN
3885.jpgAlbum 3885 8167.jpgAlbum 8167
B210 COUPE
6346.jpgAlbum 6346 11709.jpgAlbum 11709
KB210 L-engine-powered COUPE
4950.jpgAlbum 4950 11374.jpgAlbum 11374 11463.jpgAlbum 11463 19007.jpgAlbum click to view 16123.jpgAlbum click to view 13127.jpgAlbum click to view 22314.jpgAlbum 22314 22315.jpgAlbum 22315
VB210 Van (Wagon)
17005.jpgAlbum 17005 vb210_TL.jpg vb210_TL_.jpg IKI_4071-1.jpg IKI_4071-2.jpg VB20_lens-a.jpg VB20_lens-b.jpg VB20_lens-c.jpg
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=B210_Lights"
This page has been accessed 1,636 times. This page was last modified 19:00, 1 February 2024. Content is available under Datsun 1200 Club.
