Front Combination Lamp
(Redirected from Front Lamp)
<-- back to Lighting_System
All 1200 body style use the same Front Combination Light Assembly (Coupe/Sedan/Van/Truck). But the specific type varies by country and by year. USA has single-bulb, Japan has dual-bulb. Sunny Truck after 1973 has dual-reflector type.
Datsun 1200 was fitted with four or five different Front Combination Lamps, depending on the year and country. USA and Japan got all-Red, while other countries got Orange+White lamps.
Australia      Indicators (orange) + Clear Parking Lamp
Japan      I   Indicators (orange) + Orange small Lamp
North America  Indicators (orange) + Orange large Running Lamp
ANZAC/Europe - dual color lens
20749.jpgAlbum 20749
Japan/USA - single color lens
20752.jpgAlbum 20752
Body Style
11526.jpgAlbum 11526 2003.jpgAlbum 2003 14018.jpgAlbum 14018 14437.jpgAlbum 14437
Early Versus Late
Sunny Truck 1200 after September 1973 use a dual-reflector lens. Earlier 1200 Trucks use the standard 1200 single-reflector lens (same as Coupe/Sedan/Van).
1970-1973 - single reflector
1974+ dual reflector (starting September 1973)
The dual-relector lamp uses the same lenses as B210, but the housings are different in that 1200 has bullet connectors, while B210 has multi-connector. Interchange 1200 with B210: Probable, but requires wiring connector change. This likely uses the same casting molds as EUR/AUS lenses just in a single color.
Bulbs
Main: Bulbs
Japan single-reflector
26717-89920 inner 23/8 watt
26261-89900 outer (small) 3 watt
Japan dual-reflector
26717-89900 inner 23 watt
26715-89920 outer 8/3.4 watt
North America single-bulb
26717-89920 23/8 watt
Wiring Differences
Connectors
1200 bullet connectors (B110 or B120)
B210 multi-connector
20750.jpgAlbum 20750
2-wire Versus 3-wire
3-wire bullet connectors - Japan
2-wire bullet connectors - North America
18092.jpgAlbum 18092
Market Differences
Front running light lenses are either all-orange or white + orange. Reportedly the lamp housings are different so that you cannot simply swap lenses.
Europe, Australia (two-color)
4220.jpgAlbum 4220 2094.jpgAlbum 2094 17257.jpgAlbum 17257 17217.jpgAlbum 17217
Japan, America (single-color, but differ slightly)
2003.jpgAlbum 2003 19862.jpgAlbum 19862 21151.jpgAlbum 21151
Japan - Single Reflector (early) 3-wire Large + small bulb
20754.jpgAlbum 20754
Japan - Twin Reflector (late model) 3-wire 2-large-bulb
20757.jpgAlbum 20757
USA - 2-wire 1-bulb
H16 Export
Two-color lenses for export 1200s except North America: Europe and Australia
17217.jpgAlbum 17217 30037.jpgAlbum 30037
13093.jpgAlbum 13093 17257.jpgAlbum 17257
marked 'IKI 3002L' and 'IKI 3002R'
30640.jpgAlbum 30640 20751.jpgAlbum 20751
26121-H1600 LENS-FRONT COMB
26126-H1600 LENS-FRONT COMB
30641.jpgAlbum 30641 30642.jpgAlbum 30642
H10 Japan Car
19862.jpgAlbum 19862 28374.jpgAlbum 28374
Orange, single reflector, 3-wire, 1-1/2 bulb
20752.jpgAlbum 20752 20754.jpgAlbum 20754
  • 26120-H1010 LAMP ASS'Y-front combination (R.H.)
    • 23/7W bulb
    • 3W bulb
  • 26121-H1010 LENS (R.H.)
  • 26123-H1010 PACKING (R.H.)
    20712.jpgAlbum 20712
28375.jpgAlbum 28375
28373.jpgAlbum 28373
IKI 8008 (?) MADE IN JAPAN
21417.jpgAlbum 21417
サニーB110 フロントレンズ フロントウインカーレンズ フロントマーカー
G10 Japan Sunny Truck
From September 1973 3-wire, 2-reflector, 2-bulb Orange
20757.jpgAlbum 20757 20755.jpgAlbum 20755
  • 26120-G1000 LAMP ASSY-FRONT COMBINATION, RH
    • 23W bulb
    • 8/3.4W bulb
  • 26121-H5000 LENS, RH
  • 26123-H5000 PACKING, RH -8910
  • 26123-G1000 PACKING, RH 8910-
  • 08310-44020 SCREW (2 per side)
This uses the same lenses as B210, but the housings are different in that 1200 has bullet connectors, while B210 has multi-connector. Interchange 1200 with B210: Probable, but requires wiring connector change.
20150607210844987.jpg 20150607210845063.jpg 20150607210845129.jpg 20150607210845196.jpg 20150607210845262.jpg 20150607210845329.jpg 20150607210845479.jpg 21940.jpgAlbum 21940 21941.jpgAlbum 21941
H19 North America
18092.jpgAlbum 18092 11720.jpgAlbum 11720
2-wire, single-bulb, single-reflector, orange
  • 26120-H1901 ASSY-LAMP,FRONT COMBINATION R.H
  • 26120-H7000 ASSY-LAMP,FRONT COMBINATION R.H 0772-
  • 26121-H1000 LENS RH AMBER(ICHIKHO)
  • 26121-H1901 LENS RH AMBER(ICHIKHO)
  • 26123-H1000 PACKING RH(ICHIKHO)
  • 26717-89920 BULB 12V-23-8W(ICHIKHO)
  • 08310-44020 SCREW TO FIX LENS(ICHIKHO) (M4X0.7)
North America
H25 Sunny Excellent
The PB110 Sunny Excellent 1400 front lamp is for indicators only. It has a single element for the Turn Signals.
South Africa
The B140 bakkie has the front combination lamp in the front bumper.
26051.jpgAlbum 26051
484381754_2.jpg 16945.jpgAlbum 16945
It looks similar to the Datsun 1000 late sedan lamp.
1263.jpgAlbum 1263
G08 Cherry Cab
From C20 Nissan Cherry Cab チェリーキャブ
400px-Nissan_Cherry_Cab_Truck.jpgWIKI click for photo
G0800 outwardly looks the same as H19 (Single-bulb, two wire, bullet connectors)
Variations
  • one reflector Orange (B110 Japan, USA)
    20752.jpgAlbum click to view
  • two reflector Orange (B120, B210)
    20755.jpgAlbum click to view
  • two reflector Orange-White (Australia)
    20756.jpgAlbum click to view
  • B110 - Bayonet connector wires
  •  ??? - square connector
  • B210 - Multi-pin connector
  • Centered single-reflector (Japan, USA)
  • Offset single-reflector (source: ???)
    20753.jpgAlbum click to view
20749.jpgAlbum click to view 20750.jpgAlbum click to view 20756.jpgAlbum click to view
B210 uses same twin-reflector lenses as 1974-up Sunny Truck, but uses a different connector -- a rectangle-shape multi-connector
20703.jpgAlbum 20703 9305.jpgAlbum 9305 20750.jpgAlbum 20750 20756.jpgAlbum 20756
Australia/Europe 120Y
510 Lamps
Do not confuse 1200 front lamps with 510 laps. They look very similar but the 1200 unit is more rounded.
23008.jpgAlbum 23008
For Japan & USA (all orange), the position of the reflector differs:
510 Offset Reflector | 1200 Centered Reflector
20753.jpgAlbum 20753 20752.jpgAlbum 20752
Clear Lenses
20381.jpgAlbum 20381
Get the right kind of aftermarket lenses for your lamp assembly
  • Euro/Aussie
  • Japan single-reflector
  • Japan dual-reflector
  • USA single-bulb, single-reflector
1849.jpgAlbum 1849 20378.jpgAlbum 20378 24440.jpgAlbum 24440 25580.jpgAlbum 25580 25581.jpgAlbum 25581
Gasket
25614.jpgAlbum 25614 25615.jpgAlbum 25615
ウインカー パッキンゴム
Lens
JAPAN all-orange
26121-H1000 1-reflector lens -7308 ICHIKO 市光 <> 26121-H1010 KOITO
26121-H5000 2-reflector lens 7309- [same as B210]
AUS/EUR orange & white
NORTH AMERICA all-orange
26121-H1000 <> 26121-H1901
Assembly
JAPAN all-orange, dual bulb, 3 male bullet wires
26120-H1000 single reflector -7308 small & large bulbs <> 26120-H1010 KOITO
26120-G1000 dual reflector, two large bulbs 7309-
NORTH AMERICA all-orange, single bulb, 2 male bullet wires
26120-H1900 <> 26120-H1901 <> 26120-H7000
Japan B210
multi-pin connector, 2-reflector, 2-bulb Orange
  • 26120-H5000 LAMP ASS'Y-front combination lamp (R.H.)
    • 23W bulb
    • 8/3.4W bulb
  • 01411-00101 SCREW
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Front_Combination_Lamp"
This page has been accessed 24,731 times. This page was last modified 05:12, 26 September 2025. Content is available under Datsun 1200 Club.
