Gearbox Mount
(Redirected from Rear Engine Crossmember)
Categories: Transmission | Transmission Modifications
The Rear Engine Crossmember is more commonly called the gearbox crossmember. Nissan calls it the "Rear Engine Mounting Member". This transmission crossmember holds the rear engine insulator (rubber transmission mount). The crossmember matches the car, while the insulator matches the transmission type.
The rear gearbox mount crossmember bolts to brackets welded into the transmission tunnel
4648.jpgAlbum 4648 2133.jpgAlbum 2133 884.jpgAlbum 884
15430.jpgAlbum 15430
Crossmember
Transmission Swaps
See:
* 60-Series Transmission Swap Notes
* 63-Series Transmission Swap Notes
* 71 Swap (CA18, SR20, L20B engine swaps etc.)
* Wide gearbox crossmember
Manual Transmission
Buy from Pitroad
B10
The same crossmember is used by all Datsun 1000 1966-1970. Only the insulator varies between automatic transmission and manual transmission
24987.jpgAlbum 24987
Applied Model Codes
180     designed for Datsun B10 introduction (1966)
203     designed for B10-DA Deluxe Automatic
258     designed for KB10 Coupe introduction (1968)
ENGINE MOUNTING [REAR]
28811.jpgAlbum 28811
7 Complete rear mount
  11320-18000 Manual transmission
  11320-20300 Automatic transmission sedan,van,truck
  11320-25820 Automatic transmission Coupe
Fixing insulator to member (4 each required)
  10 08110-61410 M6 x 14mm BOLT
  11 08915-13610 M6 medium spring LOCK WASHER
  12 08911-10610 M6 NUT
8 11321-18000 Insulator for manual transmission
  11321-20300 Insulator for auto transmission (except Coupe)
  11321-25820 Insulator for auto transmission Coupe
  9 11322-18000 Rear engine mounting member
  Fixing member to body (2 each required)
    13 08153-82510 M8 x 25mm BOLT [9.8?]
       08150-82510 M8 x 25mm BOLT [10.9?] (from Engine # A10-5960)
    14 08915-13810 M8 medium spring LOCK WASHER
    15 08915-43810 M8 PLAIN WASHER
  Fixing insulator to transmission extension housing
    (2 each required)
    16 11335-18000 BOLT Manual cars
       11335-20300 BOLT Automatic cars
    17 08915-14010 M10 medium spring LOCK WASHER
    18 08911-14010 M10 NUT
Reference:  DATSUN SUNNY B10/B20 1966-1970 parts catalog 1969.10 pages 19-2 to 19-3
B110
24988.jpgAlbum 24988
11322-H1002 MEMBER-engine mounting, rear 3-speed, 4-speed
4648.jpgAlbum 4648
B110 5-speed
  • The 5-speed crossmember has a deeper dip, but is otherwise the same
  • Both crossmembers use the same rubber insulator
11322-H7200 MEMBER-engine mounting, rear 5-speed < 11322-H7201 from '72-10
23293.jpgAlbum 23293 4647.jpgAlbum 4647
When fitting a GX5 gearbox, you may use the 4-speed crossmember with spacers:
H72 5-speed
B120
1200 Sunny Truck
11322-H1002 LB
11322-H1002 SB (up to '73-8)
11322-G1000 SB 7309-8503
11322-H1001 LB -8503
11322-G1900 SB 8504- > 11322-G1000
11322-G1910 LB 8504-
B140
B140 bakkie has the A14 engine, so it uses a 60-series gearbox and #60-series rubber insulator.
B140 has a unique crossmember
31356.jpgAlbum 31356 31357.jpgAlbum 31357
11322-H5000 3-speed, 4-speed (56-series)
11322-H7400 from 7510 Van (also replaces 11322-H5000)
11322-H7500 A14 B210 60-series 4-speed
11322-H5700 MEMBER-engine mounting, rear A12 5-speed F5C56
11341-H7500 MEMBER-engine mounting, rear A14 B210 5-speed 63-series
H50 56-series gearbox xmember
26650.jpgAlbum 26650 26651.jpgAlbum 26651 26652.jpgAlbum 26652 8209.jpgAlbum 8209
11322-H7500 60-series [3-bolt type]
23282.jpgAlbum 23282 1976_b210_x.jpg 23283.jpgAlbum 23283 23284.jpgAlbum 23284
MANUAL, MEMBER-ENGINE MOUNTING REAR
11322-H6200 F4W56A <5> 11322-H6200 0973-0874
11322-H7300 F4W60L 0974-
11341-H7310 FSW63A 5-speed from April 1976
H731 63A
24986.jpgAlbum 24986 24985.jpgAlbum 24985
B310
60L 5-speed and all 60-series 4-speeds use the same crossmember and rubber insulator. The later 60A 5-speed uses a slightly different crossmember and insulator.
B310 Sunny | A10 Stanza
6946.jpgAlbum 6946 27086.jpgAlbum 27086
11340 MEMBER ASSY-ENGINE MOUNTING REAR
11340-H8500 B310 56-series 4-speed [2-bolt]
(spacers needed for 5-speed, leave off for 4-speed)
* 11321-H1000 INSULATOR-ENGINE MOUNTING REAR
11340-H8600 B310 60-series 4-speed & 60L 5-speed [4-bolt]
* 11320-W5000 INSULATOR-ENGINE MOUNTING REAR
24064.jpgAlbum 24064 25672.jpgAlbum 25672 23285.jpgAlbum 23285 23287.jpgAlbum 23287 mount60L.jpg
11340-H8610 60A 5-speed <x> 11340-H8600
* 11320-H9100 INSULATOR-ENGINE MOUNTING REAR
60L vs 60A
11340-H8700 AUTOMATIC
* 11320-W5800 INSULATOR-ENGINE MOUNTING REAR
B310 has several holes in the body for the 4 crossmember types.
  • Auto, 60L, and 60A all look similar and are 4-bolt. It is assymetrical
  • 56-series looks different and is 2-bolt
  • 3 holes on left side are 39.6 and 43.2 mm apart (front to back)
  • 3 holes on right side are 43.6 and 40 mm apart
24055.jpgAlbum 24055
B210 vs B310 comparisons
23288.jpgAlbum 23288 23289.jpgAlbum 23289
56-series 4-speed
11341-H9110 A12.(CAN.1278- , USA.0879-)
* INSULATOR 11321-H6201
60-series F4W60/FS5W60L
11341-H8600 <> 11341-H9100
 11341-H8600 MT    intr-0779
 11341-H9100 MT    intr-0779.(FED+CAN)
 11341-H9100 MT.F4 0879-1079.(FED+CAN)
 11341-H8600 MT.F4 0879-exit.(CAL)
* INSULATOR 11320-H9100
60-series 5-speed FS5W60A
11340-H8610 MT.FS5W60A 0879- CAL
11340-H9700 MT.FS5W60A 0879- FED+CAN
* both use INSULATOR 11320-H9100
With a B310, custom crossmember are relatively easy to make, as there are three holes on each side of the B310 tunnel. For example, this long-tail 71-series crossmember is fabricated out of 3 strips of metal and uses the stock rubber insulator:
5-speed
5-speeds have their own gearbox crossmember. If you can't find the right crossmember, you can use a 4-speed crosssmember with 20 mm spacers.
Buy from Pitroad 20mm spacers
* 5S5W60L no spacers needed, use F4W60L xmember
* F5C56A  20 mm spacers on B110 crossmember
* FS5W60A 20mm spacers on F4W60L xmember
* FS5W63A use B110 automatic crossmember
B310.A12 4-speed crossmember adapted for 56-series 5-speed
B110 4-speed crossmember adapter for 56-series 5-speed
B310 56 4-speed crossmember adapter for 56-series 5-speed
Automatic Transmission
  • 11322-H1020 MEMBER-engine mounting, rear Automatic B110
  • 11322-H5200 MEMBER-engine mounting, rear Automatic early B210
  • 11340-H7500 MEMBER-engine mounting, rear Automatic late B210
  • 11341-H8700 MEMBER-engine mounting, rear Automatic B310
B210 USA
AUTO, MEMBER-ENGINE MOUNTING REAR
11341-H5200
11341-H7320 0974-0776
11340-H7500 AUTO -1276
11340-H7600 AUTO -1276 0177- <> 11340-H7500
B310 USA AUTOMATIC
11341-H9300 AT.FED+CAL
11341-H8700 AT.CAL
* both use INSULATOR 11320-W5800
23297.jpgAlbum 23297
Rubber Insulator
There are different types of rear insulators.
The 56-Series Transmission type of mount bolts to the crossmember from the sides of the mount, just like these stock 1200 mounts:
21966.jpgAlbum click to view 21965.jpgAlbum click to view 4651.jpgAlbum click to view
This type, used with 60-Series Transmission, straddles the crossmember and bolts from the bottom:
1706.jpgAlbum click to view 23295.jpgAlbum click to view
Automatic is yet again different.
23292.jpgAlbum click to view 23296.jpgAlbum click to view
56-series
11321-18000 INSULATOR F4.56-series B10
11321-H1000 INSULATOR F4.56-series B110, B120.(-8910)
11321-G1900 INSULATOR F4.56-series B120.(8910-)
11321-H6201 INSULATOR F4.56-series B310
60-series
11323-H7500 INSULATOR B210
11320-H9100 INSULATOR B310
63-series
11323-H7510 INSULATOR B210 FS5W63A A14/5-speed
AUTOMATIC
11321-20300 INSULATOR AT B10
11321-H1020 INSULATOR AT B110
11321-H2521 INSULATOR AT B210 early
11321-H7321 INSULATOR AT B210 late
11320-W5800 INSULATOR AT B310
56-series
rockauto.com
PN 11321-H1000 INSULATOR ASS'Y-engine mounting, rear manual trans $35.83 USD
* B110, B210, B310
* 56-series transmission (3-speed, 4-speed and 5-speed)
* Anchor 8115
* DEA A6380
* Pioneer 628115
* NAPA Balkamp BK 628115
H10 (B110) insulator has one flat flange, one bent flange
23294.jpgAlbum 23294 26251.jpgAlbum 26251
26252.jpgAlbum 26252
LATE B210 A12
11323-H7400 INSULATOR ASS'Y-engine mounting, rear MT
Anchor 2489
Connects with special bolts
26367.jpgAlbum 26367
B10
B10 MT mount looks identical to the newer B110 version.
11321-18000, 11321-20300 ASS'Y INSULATOR-rear
15724.jpgAlbum 15724
60-series
rockauto.com
rear manual trans: A14 B210 4-speed (60-Series)
* 11321-H7500 INSULATOR ASS'Y-engine mounting
B310 5-speed (60-series) from 7911
* 11320-H9100 INSULATOR-ENGINE MOUNTING REAR $120.48 USD
  superceded 11320-W5000 INSULATOR-ENGINE MOUNTING REAR B310
  KB310HF,B310HF (A12) 5-speed, A14 4-speed
* Anchor Industries 2489
  * 1972-1982 Nissan Vehicles
* Anchor Industries 2488
  * 1978 B210
  * 1979-1982 B310
  * 1984-1988 S12 (200SX)
63-Series
USA B210
11323-H7310 COMP.-INSULTOR ENGINE MOUNTING REAR 5-SPEED 0476-
* DEA A7316
4-speed
* DEA A6360
B110: Similar to 56-series M/T insulator
B210: Has shift bracket integrated
B310: Rationalized to use 60/71 series M/T insulator
B110
11321-H1020 INSULATOR ASS'Y-engine mounting, rear auto trans B110 $54.18 USD
23300.jpgAlbum click to view
* Anchor 8115 $8.13 RockAuto.com
* Westar EM-8115
B10
Datsun 1000
11321-20300 ASS'Y INSULATOR-rear Coupe Automatic B10
JAPAN
11321-H2521 INSULATOR ASS'Y-engine mounting, rear auto trans early B210
11321-H7321 INSULATOR ASS'Y-engine mounting, rear auto trans late B210 $117 USD
1974 USA 11320-H6900 Insul Mount USA -0874 $120 USD
23298.jpgAlbum click to view 23299.jpgAlbum click to view 25295.jpgAlbum click to view
* DEA A2760
* Westar EM-2760 CANADA
* Pioneer 622760
11320-H6900
11320-H6900-a.jpg 11320-H6900-b.jpg 11320-H6900-c.jpg 11320-H6900-d.jpg 11320-H6900-e.jpg
11321-H7300
DEA A6380
DEA A2760
B310
11320-W5800 INSULATOR-ENGINE MOUNTING REAR B310 auto trans $79.77 USD
* C120, S110, S12?
* Anchor 2488
** S12 CA20E MT
** S12 CA18ET
** B210 A14 AT
** B310 some
** B210 1978
11320-W5000 910, B310, C120, F30
Insulator Upgrades
Kelpro mounts are tougher and hold up to racing.
9132.jpgAlbum 9132
Polyurethane
20191.jpgAlbum 20191
Also See
For swap details and other information, see:
* Transmission Interchange#Gearbox_Crossmember
* 56-Series Transmission
Conversions
See the following:
* Putting F5C56A into 4-speed cars: 56-Series_Transmission#56_5-speed_swap_Notes
* Putting 60-series transmission into 1200: 60-Series_Transmission#Swap_Notes
ミッション メンバー
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Gearbox_Mount"
This page has been accessed 86,022 times. This page was last modified 00:48, 28 November 2025. Content is available under Datsun 1200 Club.
