Forced Induction
(Redirected from Supercharger)
Category: Forced Induction
Forced Induction comes in two forms: Supercharging and Turbo-supercharging. Both work well in a Datsun 1200!
One thing to remember is that a method that works well isn't the only good way.
POST Dodgeman: Forced induction. This is a subject that was vigorously & robustly debated in an extensive thread not so long ago, so have a play with the search function & you will likely find it.
Myself, & a few others prefered the ability of the positive displacement blower to deliver high levels of torque, almost instantly, at very low engine speeds, while a large number of others prefered the advantages that a turbo offers at higher engine speeds. The turbo debate was further broken down into blow through versus suck through.
See if you can find this thread & have a read through it all. With some luck ou will gain an insight of the advantaged & disadvantages offered by each system.
A15: what to do turbo or supercharge?
  • Should I swap the A15 1.5-liter for an L20B 2-liter? Or just turbo the A15?
  • What will it cost?
  • Will it be as fast as a common V8 ute?
The big discussion: regarding Turbocharging A12. Caution: difficult reading in that discussion.
Also see discussion: s/charged a14 (10 pages)
  • Yes, an engine swap is easier & less expensive than forced induction. A $600 engine swap can be done in a weekend
  • Forced induction can be done for about $1200 if you can do all the work yourself (including buying a used compressor and creating/fabricating the kit)
  • Yes, forced induction on an A15 can be just as fast as a common V8 sedan, the 2-liter engine swap will not be
Supercharging vs. Turbocharging -- what's better?
A supercharger does not suffer from lag like a turbo does. The power increase is immediate because a supercharger is driven from the crankshaft of the engine. The turbo is better for maximum HP, the blower is better maximum torque. F1 engines used turbos instead of blowers (turbos were allowed in certain years, banned in other years).
See main article: Turbo
Generally speaking a centrifugal compressor requires revving the engine up. as the engine revs higher, turbocharging makes more and more power. So does centrifugal supercharging (Paxton, Vortech, PowerDyne, Procharger, etc.).
By contrast, a positive-displacement compressor makes power all through the RPM range and so makes the engine feel like a larger displacement engine. This includes roots-type blowers and screw-chargers. The blower requires HP to run, so the engine must be built stronger than a turbo motor of equal HP.
  • Turbo: Less expensive, more HP. More complicated. Welding skills required
  • Blower: More responsive. Easier to install. Fabricating skills important if a kit is not available
  • twin-charged: blower for low RPMs, turbo for the rest. See A12RTT
Because there are no bolt-on kits available for Datsun 1200 (as of 2014), neither one is 'better'. Either pay a shop $$$ to convert your engine, or use your skills and time to do the same on the cheap. Either way the result is a lot more HP for less money than a traditional Engine buildup.
Centrifugal Compressors: Paxton blower & turbo
174_574bf0f8d992b.jpgUpload click to view 17698.jpgAlbum 17698
All have been used in Datsun 1200s, as these photos show.
94.jpgAlbum click to view B&M blown A14 (rootes-type supercharger)
825.jpgAlbum click to view B&M supercharged NAPS-Z engine (rootes-type blower)
634.jpgAlbum click to view A14 supercharged
544.jpgAlbum click to view Compound Supercharging concept
248.jpgAlbum click to view Twin-Turbo A12
21898.jpgAlbum click to view Supercharged A15 twincharger
Draw-through vs Blow-through
You can put the carburetor before the blower (draw-through) or after the blower (blow-through). Both work well.
  • Draw-through places the carburetor in the normal position (same as naturally-aspirated). A larger carburetor is needed to make more power, and the jetting should be richened up to handle full-throttle operation
  • Blow-through places the carburetor in the boost side, so it must be modified to handle this boosted condition. The floats must be non-crushable type, and the carburetor sealed against air leaks. Jetting using calls for radical changes
Engine Build
A stock A12 can make up to 160HP - with stock rods, stock pistons, stock head gasket -- when powered up by a turbo. If the same output is gained by revving the engine higher (naturally aspirated), the rods & pistons must be upgraded. If 160HP is made by Supercharging, the engine should be upgraded with forged pistons and stronger rods to handle the load of the blower.
The most important part of forced induction is Spark Control. If you keep the spark backed off, the engine will not self-destruct. At the most basic this means limiting the distributor Spark Curve.
Spark Curve
The more compression, the less advance the engine can handle. But a high-compression engine can still use some advance, and even a forced-induction engine needs some advance to make the most power at varying RPMs. The key is LIMITING the advance to a safe level.
Consequences of too much spark advance: cracked pistons, broken ring lands
What about locking the distributor? Yes, if you lock the advance mechanism, yes, it can help prevent detonation, but also it won't make the best power. Locked distributor will only work great at high-RPM, high-boost condition -- which is where racers spend most of their time, so it works well for racing. For a street engine, you will have a more flexible, more powerful engine at all RPMs by NOT locking the distributor, but by limiting the advance.
CONSTANT-LOAD RACING METHOD
  • Lock the distributor advance. Set full timing to an appropriate level, say 30 degrees for a high-compression engine or for maximum advance at 16 psi boost: 23 degrees.
LOW-DOLLAR STREET POWER METHOD
  • In the distributor, weld the advance slots partially to limit mechanical advance (see Limiting Mechanical Advance)
  • Keep the stock vacuum advance (it will have no effect under heavy throttle or boost)
  • Connect vacuum advance up directly to manifold. This will help idle and starting out under low throttle, but the vacuum advance will have no effect under heavier throttle
  • Set initial timing to lower than normal, say 3 degrees or 0 degrees (instead of the normal 5-7)
  • Downside: On a forced-induction engine, the advance won't be right for varying boost levels. You'll have to set the advance for full boost scenario, giving up HP and fuel economy for lower throttle conditions such as highway cruising
BEST METHOD: fully programmable ignition
  • use a crank trigger with a fully programmable ignition system. MegaSquirt and other ECUs can provide initial timing, limited full timing, timing under boost and even retard under boost and compensate for high temperatures.
  • use a standalone advance controller like the Block Box or an MSD Programmable, which allows for limited mechanical advance along with variable retard under boost, off-boost, and partial-boost conditions. With such a controller, the distributor is locked, and the box takes over the exact timing curve.
Intercooler
An intercooler can result in far more HP, but requires a blow-through system (boxed carburetor) or EFI port injection. This is because for safety you don't want air-fuel mixture going through the cooler, where it will condense out of the airstream and result in fuel puddles in the cooler!
By keeping the air cool and therefore dense, the same boost will make more HP, because more air is entering the engine. Because it's not overheated, more spark advance can be applied for more HP.
See Main Article: Intercooler
Boost pressure
  • 6-7 psi is what a lot of OEM applications use.
  • 10 psi is reliable with a stock A12 or A14
  • 14.7 lbs gives theoretically double the airflow so max. power would be about 2x stock, but this isn't actually the result. The reason is that the stock induction and exhaust system won't flow this much air under pressure. However, the low rpm torque could approach 2x (at about 2250 rpm) if a small blower is used. So a 130hp forced induction engine will have much more performance than a 130hp NA engine
Induction and Exhaust
Obvious, to obtain more airflow, a higher flowing carb, intake, heads (ports and valves) and exhaust system is beneficial.
Supercharging will increase power on a stock engine, even one with no mods. But increasing the airflow capability of the engine will bring your blown engine to its full potential.
Rootes
See Main Article: Blown 1200s
Centrifugal
* Paxton (as of 2016) only makes high-HP blowers (smallest is 775 HP)
* Vortech's smallest (V5) is up to 450 hp output
* Powerdyne seems out of business
Procharger makes blowers suitable for A-series:
* A-1P up to 100 HP is for engines of base 25-75 hp
* A1-R up to 150 HP is for 50-95 HP engines
* B1   up to 250 HP is for 60-150 HP engines
These are about the size of a large alternator, and have serpentine belt pulleys.
Crank Pulley For Supercharger Drive
The factory pulleys have a bad habit of cracking through the keyway. Use a custom one with a steel crank hub.
http://www.kemotorsport.com Datsun A-SERIES Supercharger pulley 6rib+V $140 posted
27151.jpgAlbum 27151
POST Supercharger Dilemma
174_659cf31d289d6.jpgPost 498161 174_659cf326d3470.jpgPost 498161
Supercharger Setups
Autospeed article: Supercharger Steal - A look at the second-hand superchargers on the market
4AGEZ supercharged from the MR2.
Possum1200
Possum bought this 1200 with dry sump, then sold the blower to revhead
17707.jpgAlbum 17707 17633.jpgAlbum 17633
Mercedes
Mercedes blower by Eaton (w/o clutch) | Eaton M45
7679.jpgAlbum 7679 21901.jpgAlbum 21901
datsa73
Main: datsa73
Mercedes Kompressor-boosted Datsun 1200 (with OEM electric clutch)
AMR
Wally
See Wally's Wagon: A Supercharged Super Car with AMR300 blower
AMR500
Made by Aisin. Larger than the tiny AMR300 found on Subarus. Found on Nissan March with MA09S engine
AMR500
737_52a46b422d62f.jpgUpload click to view
http://www.kemotorsport.com kit for A12
27153.jpgAlbum 27153
POST A12iR Project (i=injection, R=supercharged)
GM sensors
AMR500 Supercharger
12954_530757705943b.jpgPost 451883
blog
rogue
AMR300 from Subaru Vivio with EN07Z 660cc-class (kei car) engine
See Main Article: Rogue
6168.jpg 6171.jpgAlbum 6171
SC12
Toyota SC12 supercharger
15590.jpgAlbum 15590 15591.jpgAlbum 15591 15592.jpgAlbum 15592
4053.jpgAlbum 4053
SC12 1200
See main article: SuperSedan
SC14
Toyota SC14 supercharger is the most popular blower swap for Datsun 1200s.
See Main Article: SC14
NZ2DR
Blown A-series 2-dr from New Zealand
25792.jpgAlbum 25792
Blown 3800
GM V6 with supercharger in Datsun 1200
blown1400
POST blown1400's ute for sale
Datsun 1200 Utility
Supercharged a14
Ross pistons
shot-peened valves, con-rods etc.
Water-injected supercharger sucks through a 2-inch SU
3386.jpgAlbum click to view 3387.jpgAlbum click to view 3388.jpgAlbum click to view 3389.jpgAlbum click to view 3385.jpgAlbum 3385
See Forced Induction A-series Photo Index
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Forced_Induction"
This page has been accessed 106,158 times. This page was last modified 07:25, 9 January 2024. Content is available under Datsun 1200 Club.
