Search results
For query "08911"
There is no page titled ":08911". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
No page title matches
Page text matches
  1. Heater (11024 bytes)
    176: 08911-10637 NUT
  2. Radio (17232 bytes)
    198: ** 08911-10510 NUT (2)
    228: ** 08911-10510 NUT 2
  3. Intake Manifold (13709 bytes)
    18: 08911-10810 NUT CYLINDER HEAD TO MANIFOLD (9)
    36: 08911-20810 NUT CYLINDER HEAD TO MANIFOLD (11)
    107: * 08911-10810 NUT CYLINDER HEAD TO MANIFOLD 9
  4. Oil pan (12365 bytes)
    78: 08911-1062A NUT M6 FIXING OIL PAN 4 A12 08911-10610 $0.10
  5. Steering Linkage (12026 bytes)
    228: ...11-00011 NUT-lock, side rod (R.H.) (2) $1.10 USD [08911-3441A]
  6. Crossmember (3583 bytes)
    69: 08911-54010 NUT (4)
  7. EGI intake manifold (1513 bytes)
    54: * 08911-10810 M8 NUT
  8. 1979 aircon (7412 bytes)
    182: 08911-10637 NUT
  9. Steering Gearbox (9683 bytes)
    146: 08911-3401A NUT 1 OP. - 08911-34010 $0.11
    147: 08911-34010 NUT 1 OP. - superceded
    158: 08911-24610 NUT 1 OP. -
  10. Package Tray (3034 bytes)
    30: 08911-10810 NUT (2)
  11. Knuckle Arm (6390 bytes)
    165: [[NES#9-11_Hex_Nuts|08911-64010]] NUT-HEX M10x1.25 High, medium carbon stee...
  12. Ball Joint Comparison (5183 bytes)
    74: 08911-60810 NUT (6) [M8]
    75: * 08911 = Hex Nut
    86: 08911-64010 NUT (M10 X 1.25)
    87: * 08911 = Hex Nut
  13. Muffler (11258 bytes)
    61: 08911-10810 NUT
    64: 08911-10810 NUT (2)
  14. Block & Pan Part Numbers (3896 bytes)
    55: 30 08911-1062A NUT M6 FIXING OIL PAN (4)
    56: 08911-10610 NUT M6 FIXING OIL PAN (4) <> 08911-1062A
  15. Manifold Part Numbers (1933 bytes)
    23: 9 08911-10810 NUT CYLINDER HEAD TO MANIFOLD (9) A12
    42: 23 08911-10610 NUT-HEX M6 (4) A12
  16. Exhaust Part Numbers (3063 bytes)
    27: 17 08911-10810 NUT
    30: 20 08911-10810 NUT 2
    66: 10 08911-10810 NUT-HEX M8
    70: 13 08911-10810 NUT-HEX M8 (2)
  17. Fuel Part Numbers (24315 bytes)
    25: * 08911-10810 NUT-HEX M8 FIXING WATER PUMP 3 A12 -
    66: * 08911-20810 NUT-HEX FIXING INSULATOR TO BRACKET 8 A12 -...
    73: * 08911-10610 NUT-HEX M6 4 A12 -
    80: * 08911-14010 NUT-HEX M10 2 A12 -
  18. Gearbox Mount (12308 bytes)
    38: 12 [[NES_Part_Numbers#nut|08911-10610]] M6 NUT
    53: 18 [[NES_Part_Numbers#nut|08911-14010]] M10 NUT
  19. Exhaust Manifold (13709 bytes)
    67: 08911-10810 NUT CYLINDER HEAD TO MANIFOLD 9
  20. Accelerator Pedal (2831 bytes)
    42: 08911-30610 NUT
Search in namespaces :
List redirects   Search for
