Search results
For query "Chassis"
There is no page titled ":Chassis". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
Article title matches
  1. Chassis numbers (12594 bytes)
    1: The B110 chassis number is stamped on the cowl and on the engine-c...
    3: See [[Nissan chassis codes]] for explanation of model numbers.
    88: <br>chassis number B110-xxxxxx
    268: In addition to the Nissan chassis numbers, USA models have an [[FMVSS]] build plate...
    282: The Car Number is both on the chassis plate, and embossed into the firewall (cowl) shee...
  2. Nissan chassis codes (8030 bytes)
    1: Datsun 1200 Chassis codes are marked on an aluminum plate fitted in t...
    6: * [[Chassis numbers]] Vehicle Number
    10: Nissan parts catalogs use involved chassis codes.
    20: = Datsun 1200 Chassis Codes =
  3. Chassis Lube (890 bytes)
    1: Chassis Lube or "Grease job" should be done every 12 mont...
Page text matches
  1. History of Datsun 1200 (17010 bytes)
    1: ... known as "Datsun Sunny 1200". The car was Nissan chassis code '''B110'''. It was sold in Japan 1970-1972, ...
    88: ...mdash; with 1400cc power &mdash; and so is Nissan chassis code [[Nissan B140]], named the Nissan 1400 LDV b...
  2. Rear Axle (11620 bytes)
    178: Flexible Hose (from chassis to rear axle) is the same RHD/LHD. Splitter is th...
  3. Rear Axle Swaps (24555 bytes)
    137: ...ve to do some significant mods to mount it to the chassis. This involves grinding off the existing multiple...
  4. Puerto Rico (4691 bytes)
    7: ...GTE,MITSUBISHI 4G63,2.6 G54B,NISSAN SR20DET...3/4 CHASSIS 26X10.5 IN THE BACK... AND IF YOU WANT IT A LOT O...
  5. Performance (21399 bytes)
    326: ...l HP there are standards sometimes used, but the "chassis" dynos which measure rwhp are notoriously uncalib...
  6. Radio (17232 bytes)
    157: * DIN chassis
    454: DIN chassis mount head unit will fit in the dash, the glovebo...
    456: {{SeeEx|see=Main|Radio_mounting#DIN_Chassis|DIN Mounting}}
  7. Part Numbers Index (8259 bytes)
    27: = Chassis =
  8. PB210 (11696 bytes)
    107: ...tion for the regular B211. The Excellent 1600 was chassis code GB211 (4-dr) or KGB211 (Coupe).
    169: ...'t the 1976 Sunny Excellent models carry the "PB" chassis designation?'''
  9. Datsun B10 (14041 bytes)
    41: ...ker_cover#Identification|rocker cover]] and the [[Chassis_numbers#B10|ID plate]] said Datsun.
    46: ...71. The only info I have on the model year is the chassis bumber KB10-080,001. From this number & upward, t...
  10. 63-Series Transmission (11903 bytes)
    64: ...ry Service Manual]] DATSUN model 1976 B210 series Chassis and Body Supplement 1 [63A transmission supplemen...
  11. 60-Series Transmission (16379 bytes)
    275: ...verse-light switch is right where the Datsun 1200 chassis x-member mount is.
  12. 56-Series Transmission (22608 bytes)
    20: The Nissan chassis code (not transmission code) has F = Five-Speed, ...
  13. Toyota 4A engine (10159 bytes)
    167: ...than the a12, so you can position it lower in the chassis.
  14. Trayback Utes (2462 bytes)
    19: ...ff the quarter panels, removing the tray from the chassis and welding it all up and then bolting on the new...
    29: ...rength. I assume you would have to make up a half chassis or something similar.
  15. Wing (1664 bytes)
    1: ...ear of the bodywork and supplies downforce to the chassis. So that the car does not lift up and lose tracti...
  16. DAS (7541 bytes)
    68: ...e final assembly of the pickup bed to the cab and chassis, has necessitated the building of a production li...
    70: ...ounted on a truck bed which is then placed on the chassis and secured further down the production line. Onc...
  17. Model names (18990 bytes)
    212: ... body panels and interior but same running gear & chassis/suspension.
    216: ... body panels and interior but same running gear & chassis/suspension. 710 did not use IRS in most of its mo...
  18. Repair Manual (20287 bytes)
    38: * Chassis And Body
    51: Model B120 Series Chassis and Body
    56: * Nissan Model B120 Series Chassis & Body
    93: * 1971/1972 Chassis: 20019
  19. Tools (9147 bytes)
    102: For chassis lube
  20. Engine buildup (10548 bytes)
    87: ...d 64 RWHP (rear-wheel horspower, as measured on a chassis dyno). See [[Performance]], horsepower section).
Search in namespaces :
List redirects   Search for
