There is no page titled ":Cover". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
Article title matches
- Steering Column Cover (3856 bytes)
1: {{BackTo|Steering Column|Steering_Column_Cover}}
3: ...eering column shell finishes the steering column, covering the [[turn signal switch]] and provides a moun...
13: ...witch and the [[turn signal switch]]. It does not cover the steering lock and key lock.
19: 48470-H1010 COVER SET-STEERING COLUMN [cut for 25.6 mm diameter sha...
46: * 48470-G1150 COVER SET-STEERING COLUMN [Black] 7510-7803 - Rocker cover (9297 bytes)
1: ...er cover is also known as a valve cover or tappet cover.
8: They are prone to leaking like most stamped steel covers. Biggest problem is over tightening. They should...
14: ... The cork gaskets tend to tear on removal of the cover.
16: Tighten all the valve cover screws finger tight. Then go around and re-tighte...
50: <br>{{Photo|nissan_cover.jpg|Datsun%201200/wiki}} - Timing Cover (3915 bytes)
1: ...also has a [[Ignition Timing|timing mark]] on the cover and houses the [[Crankshaft Seal|crankshaft pulle...
4: ...g Chain]]. The [[Water Pump]] bolts to the timing cover.
6: Timing Cover with water pump bolted on
7: <br>{{Photo!|Timing_Cover.jpg|Datsun%201200/Parts2}}
9: Early 1200 cover - single timing mark - Coupe Tonneau Cover (297 bytes)
1: Optional tonneau cover for Datsun 1200 Coupe
5: 84950-H1825 COVER SET-Tonneau
6: 84951-H1800 HOOK-Tonneau cover (2) - Tonneau Cover (93 bytes)
4: * [[Coupe Tonneau Cover]] - Alloy rocker cover (7210 bytes)
1: {{BackTo|Rocker cover}}
3: ...s quieter. Also seals better than a stamped steel cover which will seep/leak when overtightened. And it l...
8: = {{RefNo|Pulsar|}} Nissan/Datsun Pulsar OEM cover =
16: ... a mesh clip nail which can be used on top of the cover for the cables, after removing the nail from the ...
30: plain valve cover prototype, limited edition for high-cam
Page text matches
- Engine Gasket Kit (2904 bytes)
20: * [[Valve Cover]] gasket
27: * [[Timing Cover]] gaskets & Seals
68: 13270-H1000 PACKING-ROCKER COVER A14,A15
70: 13044-H1000 GASKET-TIMING CHAIN COVER A14,A15 - Cylinder Fitting (83 bytes)
3: [[Timing Cover]] - Nissan Parts (563 bytes)
6: 80886-H1000 Rubber - Door cover RH
7: 80887-H1000 Rubber - Door cover LH - Magazine Articles (24401 bytes)
17: * ??? {{cover|1767}} James Laing-Peach remembers driving the 12...
19: ...photo.php?lid=2417 yellow ute] (with hard tonneau cover)
23: * {{UPC|9312966023490|Fast Fours 1994 Sep}} {{cover|22083}} Datsun 1200 upgrade (2-pages)
24: ...C|9312966023490|Fast Fours 1997 Feb Vol 10 #2}} {{cover|25296}} Datsun 1200 Coupe 13B Pro-Street
25: ...C|9312966023490|Fast Fours 1997 Mar Vol 10 #3}} {{cover|23933}} '9-second Datsun' 1200 Datsun 1200 Coupe ... - 5-Speeds (19568 bytes)
72: * You may use your existing flywheel and clutch cover (pressure plate) - Racing History (26063 bytes)
173: <br>Note the blue cam cover, Nippondenso fuel injection, dry sump oiling - Heater (11024 bytes)
24: ...]] B110 used a Nissan heater by Smiths. The front cover is fastened with screws instead of clips like the... - A12GX Engine (12809 bytes)
166: = Rocker Cover =
167: The [[Rocker cover]] is unique to the A12GX engine:
180: NOTE: A12T in Nissan Cherry has a unique rocker cover that is different from A12GX or standard A12. Any...
252: ...tle to accomodate more fittings too, but the main cover piece was unchanged, other than for the change in... - Rear Axle (11620 bytes)
33: ...xle has an octagonal rear cover. H145 has no rear cover. - Rear Axle Swaps (24555 bytes)
160: BW has removable back cover
204: ...89 (manual), 4.1 or 4.3 (auto). A tag on the rear cover has the ratio stamped on it. The Corolla diffs ha...
387: ...onto studs with nuts?<br>{{Album|594}}<br>No back cover - Carburetor Overview (3188 bytes)
88: ...imilar to DCH340 with a large bolt-on glass float cover. - Ignition Timing (9164 bytes)
25: ...>NOTE: If you use the older pulley with the newer cover, then you could get really weird timing readings<...
107: ...In a pinch you can use an old-fashioned matchbook cover, which is typically 20 thousands of an inch thick... - Choke Operation and Adjustment (6774 bytes)
119: ...retor_Part_Numbers|16389-H7010}} Choke Thermostat Cover 0772-
120: {{Pn|DCH_Carburetor_Part_Numbers|16389-H3910}} COVER-THERMO -0672
126: 1974 A13 choke thermostat cover (fits 1200) 16389-H6200 Hitachi - Emission Controls (28459 bytes)
136: ... hoses to route the fumes from carburetor, rocker cover and air cleaner to appropriate places. Be sure to...
166: ...ond delay valve added inline near front of rocker cover
422: * '''Fuel Tank vapor recovery''': This is a good thing, as why let gas fumes g... - Parts Sources (15979 bytes)
54: * Valve Cover Gasket - Radio (17232 bytes)
306: * 27979-H5000 COVER-ANTENNA OP. - - Part Numbers Index (8259 bytes)
6: ... Part Numbers|Block & Pan]] CYLINDER BLOCK, FRONT COVER & OIL PAN
7: * Timing Chain Cover, Cylinder Liner
8: [[Head Part Numbers|Head]] CYLINDER HEAD, ROCKER COVER & THERMOSTAT
38: ...[Clutch Part Numbers|Clutch]] CLUTCH DISC, CLUTCH COVER & WITHDRAWAL LEVER
141: ...t Part Numbers|Rear Seat]] includes COUPE TONNEAU COVER - GX-5 (8005 bytes)
14: GX5 on cover photo - ''Nostalgic Hero'', June 2016 - Clutch (17014 bytes)
2: ...ifications, but now Nissan sells one disc and one cover for all A-series engines. The only one that is di...
78: = Clutch Cover =
79: The clutch '''cover''' is also known as the '''pressure plate'''.
81: {{AlbumRefH|Clutch_Kit|15344|Aisin brand cover}}
83: C0210-H3120 Clutch Cover $112.63 USD - Yahoo Auctions Japan (4625 bytes)
58: ...hey have VISA, MasterCard, American Express or Discover card and a verifiable address
65: ...r existing doesn't find what you want. They don't cover all Yahoo! items, only ones in certain pre-define...
