Search results
For query "OwnersManual"
There is no page titled ":OwnersManual". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
No page title matches
Page text matches
  1. Rear Axle (11620 bytes)
    136: {{OwnersManual|23||Recommended Lubricants}}
  2. Ignition Timing (9164 bytes)
    97: ...every 3,000 miles (5k) as part of a [[Tune-up]].{{OwnersManual|36|36|Be sure that the contact surfaces are clean...
  3. Emission Controls (28449 bytes)
    9: {{OwnersManual|28|31|Are you familiar with the air pollution<br>...
    193: {{OwnersManual|29|30|Throttle Opener}}
  4. Radio (17165 bytes)
    13: {{OwnersManual|20|20|<center>[[Comfort_and_Convenience_Features#...
    21: {{OwnersManualB120|17|17|<center>[[Comfort_and_Convenience_Featu...
  5. Ignition Switch (12669 bytes)
    6: {{OwnersManual|11|p=29371||Instruments and Controls}}
  6. Tires (14923 bytes)
    36: {{OwnersManual|26|27|Recommended cold inflation: 24 psi<br>(155S...
    38: {{OwnersManualB120|23|25|Recommended cold inflation:
  7. Lighting System (2956 bytes)
    13: {{OwnersManual|36|38|(see pages 36-38)}}
  8. Fuel Requirements (12778 bytes)
    12: {{OwnersManual|22||87 R+M/2, or 90 RON equivalent}}
  9. Valve adjustment (7052 bytes)
    30: {{OwnersManual|40||Valve clearance (hot) 0.014 in (0.35 mm)}}
  10. Owners manual (9135 bytes)
    32: {{OwnersManual_nopage}}
    184: <br>{{OwnersManual}}
  11. Fume Control (11421 bytes)
    66: {{OwnersManual|31|31|This system prevents gases from going out f...
  12. Wipers (8777 bytes)
    20: {{OwnersManual|12||p=29372|<center>[[Instruments and Controls|In...
    28: {{OwnersManualB120|11||Instrument and Controls}}
  13. Glass (11375 bytes)
    4: {{OwnersManual|07|07|opening of the windows: door window, ventil...
  14. Hood (6721 bytes)
    23: ...ick this page of the owner's manual for details:{{OwnersManual|21||Pull the hood lock handle}}
  15. Transmission Overview (6766 bytes)
    47: {{OwnersManual|33||Replace every 30 months or 30,000 miles}}
    68: {{OwnersManual|23||Recommended Lubricants}}
  16. Instruments and Controls (12492 bytes)
    6: {{OwnersManual2x|29372|p1=12|29378|p2=13|Instruments and Control...
    8: {{OwnersManualB120|06|08|Instruments and Controls}}
    14: {{OwnersManual|09||Seat Belt Lamp, Tachometer and Speedometer}}
    17: {{OwnersManual|10||If the pointer stays on the "H" side for more...
    37: {{OwnersManualB120|08|08|the pointer will hover about halfway......
  17. Automatic Transmission (16924 bytes)
    49: {{OwnersManual2x|29376|p1=16|29377|p2=17|[Use "D"] for most city...
    54: {{OwnersManual|23|p=29383||<center>'''[[1972#Daily_Care|RECOMMEN...
  18. Spark plugs (15511 bytes)
    86: {{OwnersManual|35||'''SPARK PLUGS'''
  19. Headlights (12557 bytes)
    95: {{OwnersManual|36||Specification}}
  20. Fan belt (4281 bytes)
    4: {{OwnersManual|35||Fan belt slackness: 10-15mm}}
Search in namespaces :
List redirects   Search for
