Search results
For query "Vendor"
There is no page titled ":Vendor". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
No page title matches
Page text matches
  1. 60-Series Transmission (16379 bytes)
    176: {{Vendor|Bprojects|http://www.datsun1200.asia/category/sel...
    178: {{Vendor|Bprojects|http://www.datsun1200.asia/category/sel...
  2. Brake Swaps (21279 bytes)
    25: ...n some racing applications (check with your brake vendor for their suggestions).
  3. Starter (13970 bytes)
    136: {{Vendor|Bprojects|http://www.datsun1200.asia/category/sel...
  4. A14 Engine (6605 bytes)
    127: ...alistic), and call and discuss this with your cam vendor (e.g. Iskenderian). High-lift may require special...
  5. Transmission Gear Control (8648 bytes)
    87: {{Vendor|Bprojects|http://www.datsun1200.asia/category/sel...
  6. Headlights (12557 bytes)
    79: {{Vendor|RockAuto.com|https://www.rockauto.com/en/catalog/...
  7. Hub (6054 bytes)
    170: {{Vendor|Bprojects|http://www.datsun1200.asia/category/sel...
  8. Kangaroo Bag (2789 bytes)
    72: {{Vendor|Bprojects|http://www.datsun1200.asia/category/sel...
  9. Oil cap (5899 bytes)
    38: {{Vendor|Bprojects|http://www.datsun1200.asia/category/sel...
  10. Vintage Datsun Swap Meet (2287 bytes)
    21: ...ohol & no burn outs. No selling of food & drinks. Vendors need to enter before 9:00am to get a good spot. ...
    23: ...selling in front of your car will be considered a vendor and need to pay.</blockquote>
  11. Timing Chain (6849 bytes)
    143: ...shaft gear lets you fine tune the timing. The cam vendor's recommendations are usually best, but retarding...
  12. Camshaft Comparison (19920 bytes)
    60: ...ers with grinds from the same manufacturer. Other vendors may measure it differently.
    222: ...er cam (the journals are too small). Even so, cam vendors can do some high-lift and quick-opening magic fo...
    224: Call your cam vendor and ask for their advice. Tell them what RPM you ...
  13. Lowering (10370 bytes)
    46: ... certain length and rate. King Springs is popular vendor for 1200. Also Nissan Competition made lowering s...
  14. Shock absorbers (23993 bytes)
    154: ** One vendor says it fits all 1970-1982 sunny sedan
  15. Electric (37152 bytes)
    351: ...ctice, use the fuse recommended by the controller vendor.
  16. Carburetor Tuning (7969 bytes)
    96: cam vendor's recommendation.
  17. Tachometer Wiring (6734 bytes)
    94: ...d the resistor depends on the ECU, so ask the ECU vendor.
  18. Bulbs (26487 bytes)
    134: {{Vendor|RockAuto.com|https://www.rockauto.com/en/catalog/...
    605: {{Vendor|RockAuto.com|http://www.rockauto.com/catalog/x,ca...
    611: {{Vendor|RockAuto.com|https://www.rockauto.com/en/catalog/...
    664: {{Vendor|RockAuto.com|https://www.rockauto.com/en/catalog/...
  19. Steering Column Bush (3533 bytes)
    23: <br>{{Vendor|Bprojects|http://www.datsun1200.asia/category/sel...
  20. JAF (887 bytes)
    13: <br>{{Vendor|Bprojects|http://www.datsun1200.asia/category/sel...
    14: <br>{{Vendor|Bprojects|http://www.datsun1200.asia/category/sel...
Search in namespaces :
List redirects   Search for
