Search results
For query "Version"
There is no page titled ":Version". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
No page title matches
Page text matches
  1. History of Datsun 1200 (16941 bytes)
    52: ...) and the 4 door GX (SUs) were also produced. All versions came with a 4.1:1 diff ratio. Chris still has hi...
    81: ...ell as new grilles and tail lights. The last B110 version intoduced was the [[GX-5]] which arrived in Augus...
    94: ... B110 there was also a different L series engined version. This model came a year after the A series cars a...
    113: ...edans and GX Coupes were sold. The truck "bakkie" version continued to be manufactured through 2008.
  2. Magazine Articles (24401 bytes)
    85: ...cusses the car with us, while we've also tested a version, the GX auto. (6pp about Nissan Australia and FUJ...
    257: ...com/modules/myalbum/photo.php?lid=26465 Datsun conversion]" (captioned photo)
    271: * Car & Car Conversions Apr 1973 - Datsun 1200 Coupe by Samurai is teste...
    272: * Cars and Car Conversions Jul 1974 - [[Janspeed]] racers, Sunny and Cherry
  3. 5-Speeds (19568 bytes)
    29: ** The 5-speed versions were 1:1 direct fifth-gear (non-overdrive), call...
    36: ** Vanettes have the "R" version (remote shifter for column shift) so it is not a ...
    39: ...ansmission commonly used with L-series engines, a version was also fitted to A14 engines in B210s
    41: ** The 5-speed version is a "dogleg" shifter
    101: ...roduction-based transmission available for racing versions of the 1200, B210 or 210 Datsuns. The synchro me...
  4. QR25DE Engine (6399 bytes)
    2: ...p into a Datsun 1200. One guy has swapped the B14 version into a Datsun 510, so you know it will work in a ...
  5. Engine Swaps (25981 bytes)
    10: A special hi-power version of the A12 is the [[A12GX Engine]]. These came in...
    79: ... (or swaps the cam & heads if you have a lo-power version).
    100: ...ng the 1486 will make a bit more HP than the 1488 version.
    184: ...or a 1200 race car so it is possible. A 1.4 liter version is available.
  6. Heater (11725 bytes)
    87: ... part from Repco can be used for the hose to this version of the heater cock [{{Post|455280}} non-Japan hea...
  7. A12GX Engine (12809 bytes)
    12: A12 GX engine - South Africa version
  8. Rear Axle (11788 bytes)
    111: ...lasting part behind an A12 or A13 engine. The ute version is strong enough for 1.8 liter engines.
  9. Rear Axle Swaps (24650 bytes)
    284: ...a, also available in a lighter (but weaker) alloy version.
  10. Performance (21399 bytes)
    206: ...e it was near the Datsun's top speed, but the SSS version took half a minute to reach this velocity, and co...
    303: == Torque and HP conversions ==
  11. Weber 32/36 Carburetor (22613 bytes)
    70: ...><td>&nbsp;Holley 180</td><td>Australian licensed version of Weber 32/36</td></tr>
    71: <tr><td>&nbsp;Holley 5200</td><td>US licensed version of Weber 32/36</td></tr></table>
    90: ...e there is a different brand name. Holley's first version was the Holley 5200, fitted to the 2-liter German...
    117: In Australia, the G180 is a licensed version of the Weber 32/36 and fitted to:
    162: '''Double-venturi''' is used on some newer versions for better driveability and fuel economy. This i...
  12. Parts Sources (15979 bytes)
    146: ...nce Nissan South Africa is still selling the 2004 version of the Datsun 1200 truck (now the 1400), they are...
  13. Gilmer drive (4901 bytes)
    5: ...n V-belts. A serpentine belt is a less exepensive version but is not synchronous (will still slip slight du...
  14. Clutch (17014 bytes)
    246: Obtain "heavy duty" version of the pressure plate
  15. Choosing A Carburetor (14914 bytes)
    108: ...le in "dome-top" through 1972 and then "flat-top" versions in 1973 and up. Most use the 38 (38mm bore), but...
    235: ... for HP or torque. I don't know of any commercial version for 1200s, but here's a custom-made one:
  16. Datsun 1200 SSS (14109 bytes)
    3: The '''Datsun 1200 SSS''' was a special version of the [[History of Datsun 1200|Datsun B110]] cre...
    11: ... and felt there was a local market for a modified version of the successful 1200 after seeing the success o...
    94: <br>NOTE: the later B210 SSS version had a [[120Y_SSS#22485|thick side stripe]]
    132: ...e it was near the Datsun's top speed, but the SSS version took half a minute to reach this velocity, and co...
    139: ...an Jul 1973 (pp 12-13) - track test of the racing version
  17. Intake Manifold (14016 bytes)
    22: ...l washer with non-parallel faces. It is a smaller version of the [[Crankshaft_Pulley#Pulley_Bolt|Crank Pull...
  18. PB110 (13462 bytes)
    28: * Single-carb version: 85hp, 11.8kgm/3 torque @3,600 rpm
    29: * Twin-carb version (GX): 95hp, 12.2kgm/3 torque @4,000 rpm
    146: ...h 1400cc [[L|L14 engine]], a smaller-displacement version of the L16 fitted to the [[510|Datsun 1600]]. Thi...
  19. PB210 (12135 bytes)
    4: ...0 Excellent was available in Coupe and 4-dr sedan versions.
    12: The Excellent was a heavy-duty version of the B210, featuring larger wheels and suspensi...
    113: ... engine. The Excellent 1600 was an upscale luxury version.
    180: ...211 from 1976 - A12, A14 and L16. The L16-powered versions were marketed as the '''Excellent 1600'''. Taken...
  20. B310 Electronic Distributor Swap (3084 bytes)
    5: ...ory stock on 1979-1982 Datsun 210 (North American version of the B310), and is commonly known as a "matchbo...
Search in namespaces :
List redirects   Search for
