a15tt to drag (cancelled, motor shagged)
From Melbourne, Australia
just an invitation for the melbourne boys to come have a look if they so desire
maybe someone else will want to run there car aswell?
im thinking of getting another diff centre to weld up for the night, and hopefully adjustable boost so i crank it up to 10psi
hope to see some of you guys down there,
cheers mateys
Posted on: 2004/10/31 2:16
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: a15tt to drag at calder this friday night (5th nov)
From Christchurch NZ
Good luck dude, I look forward to hearing what times she puts down.
I too, am itching to give mine a blast down the 1/4 mile.
Posted on: 2004/10/31 8:25
Forced Induction!
From Canberra, Australia
any chance of a video capture for people unable to attend?
Posted on: 2004/10/31 9:03
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
yes well,
doing a turn sunday night, missed second gear from 7500rpm in first, and i must have over-revved it when it didnt go into gear, i thought i killed the gearbox, but i changed that and it still makes a massive rattle, so i guess one of the bottom end bearings has died on me
dunno if will try the a14 block i have or look out for a CA now
maybe sell the twin turbo setup
Posted on: 2004/11/3 1:09
1200 Coupe Rallycar
From WA
you know where to send the turbos should you choose to get rid of them....
Posted on: 2004/11/3 1:46
Sorry to hear it! Keep working on the a-series if it interests you at all. The CA is so "been done".
Posted on: 2004/11/3 2:35
From Brisbane, Australia
don't give up just yet - check that the flywheel hasn't come loose! It certainly wouldn't be the first A series to shake the flywheel on an over-rev. If it is, make sure you tighten to manufacturer's specs and locktite the bolts.
Posted on: 2004/11/3 3:53
Coulda had a piston Kiss a valve, bent pushrods make a hellava rattle, you'd probably hear a 3cyl idle though.
Either way, open 'er up for a post mortem.
Posted on: 2004/11/3 5:19
From South Africa, Bloemfontein
1200rallycar
I agree with ddgonzal. Rather keep the A15 and just rebuild and maybe balance and play around with it.
You must admit, it kept up well with the punishment you put it through so far.
A CA conversion has been done quite a few times and is not interesting anymore.
Everytime I see a post from you about the A15tt I check it out.
The CA posts does not interest me that much anymore.
Sorry CA guys.
Posted on: 2004/11/3 6:30
1977 Datsun 1200GX
From Melbourne,Australia
Even though im putting a ca in the ute id have to agree with the other guys give her a freshen up and work on the injection manifold that you were going to do and keep it twin turbo just cause its different.If it turns out the engines stuffed and you cant be bothered building it yourself give randy a call at the 1600 workshop in bayswater they do good work
Posted on: 2004/11/3 6:55
(1) 2 3 4 »
