Finally, the beast has been tuned!!
From In front, and pulling away.Sometimes around Sydney....ish!
Finally after much heart ache, the Sunny made it to the dyno. At the end of the day, ( well, 8 runs anyway.) we ended up with a figure of 121.3 rwhp (90.4 rwkw). Not too bad out of a standard A14. It made good torque, and peaked at 12.1 psi boost. Now if I could just go up to 15 psi.....
Posted on: 2006/9/25 8:19
Lifes good when your on BOOST!
Re: Finally, the beast has been tuned!!
From Sydney , NSW
BAAAAAAANNGG !!!
Cheers
Posted on: 2006/9/25 8:36
Ha Ha Ha. Who had the big grin driving it there? What was the L series making?
Posted on: 2006/9/25 9:28
i thought blood was supposed to be thicker than boost?
are you runningblow thrpugh set unp dog160 or efi?
Posted on: 2006/9/25 23:30
From Canberra
120hp thats pretty good. I think it made 70hp with 120fly on an a12. Is that still with the decomp plate?
Posted on: 2006/9/25 23:44
From Ipswich,QLD
hell yaeh the torque factor was quit impressive when i used it it pulled like 10 men ,third gear would wind out for ever .
Posted on: 2006/9/25 23:50
From Brisbane, Australia
that's not bad at all on a stock motor. Will be good to hear how it goes on the track!
imagine what it could do with a cam, some porting, maybe valves, and pistons that will handle more boost...
it that still with the old T3 on it?
Posted on: 2006/9/26 3:04
Unfamilia- The set up is a suck thru 1 3/4" SU and a Sigma turbo out to T3 spec.
Tyrie- Yep, still has the decompression plate, it's the same as when I bought it!
120fly- You know how hard this goes Geoff! 3rd and 4th gear are where all the action is! And it is running a Stanza diff with 4.1 centre.
L18 B110- Harry, it is still running the Sigma turbo out to about T3 specs. We toyed with cutting the flange off and fitting a T28, but this one has more top end, and is a T4 bolt pattern for if we get REALLY serious!(or stupid?)
Posted on: 2006/9/26 13:25
From perf
how much timing are you running?? i just had mine dynoed at 110 on 11psi and it has turbo pistons, cam, efi, t25/28.... very dissappointed to say the least
Posted on: 2006/12/7 19:53
From Perth
That sounds like a whole heap of fun to drive...... keep up the good work on those turbo's boys!
Posted on: 2006/12/11 17:48
