Upgrade engine mount rubbers???
From Canberra
Just found I broke an engine mount rubber, standard 120Y item. I was going to go grab a b310 rubber and stick it in but no-one in canberra has them in stock, and if I have to wait to get one I might as well get something better.
So I was wondering what people have used that has the same bolt size, and is the same height or SHORTER than the original. I have a kelpro cortina rubber on the other side but it is taller than standard.
Part numbers would be best but make/model is good. cheers
Posted on: 2007/7/6 7:20
Re: Upgrade engine mount rubbers???
From Coondle, WA Australia
Tyrie
PhunkDr and i discussed a similar problem a while ago.
This link
should give you some ideas.
edit : a http://datsun1200.com/modules/myalbum/photo.php?lid=4129link
to the sketch that I drew to describe what I was on about.
Posted on: 2007/7/6 12:41
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Geelong, Vic
cortina ones????
arent they all the rage
Posted on: 2007/7/6 15:05
From Canberra
yeh I have a cortina one in the other side, it is a good 10mm taller than the standard 120Y mount, and I feel that using one on the other side would put the engine on more of a lean.
I like the idea of the bolt though, I'll give it a go.
cheers
Posted on: 2007/7/10 12:14
From Adelaide, Australia
A bloke around the corner from me has Jag V8 ones in his 1200, he reckons they are similar to the cortina ones but not as tall.
Posted on: 2007/7/10 12:46
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From bathurst nsw
i wouldnt mind knowing what type of jag v8 ones go on and if they were a bolt on because mine are about to break soonish
p.s. sorry for the quick hijack
Posted on: 2007/7/10 16:21
My car gets me from A to B...Just faster ;)
From southern sydney "the shire"
i broke 1 in my 120y not long ago and i got a replacement one from repco for like 20 bucks. that was just a stock one im not sure if you are after another stock one or a stronger one not though
Posted on: 2007/7/11 6:52
From Christchurch NZ
RB20 ones are pretty close. You need to open up the holes a few sizes, and fold down the rolled edge on the xmember.
Posted on: 2007/7/11 6:54
Forced Induction!
