13BT VERSUS CA18DET
From Albury
Hi guys
There is another thread going at the moment about rotary conversions and i do not wish to hijack it but it has got me thinking about which one of the 2 has better power and reliability in reasonably standard trim ? I am toying with the idea of building a track car so compliance is not an issue.
Which one is easier to fit and more user friendly ?
Thanks
Bob
Posted on: 2009/5/25 10:11
Re: 13BT VERSUS CA18DET
i'd go 13bt definitely for a track car, the drama's would be the brake master hitting on the intake and the clutch fork for the 13bt 5 speed other than that i had alot better time installing my 12a compared to the ca18det
Posted on: 2009/5/25 10:22
From Toowoomba, Qld
I think to answer both sides of your question bob, it's a bit of a toss up, the rotary can be made to put out more power in reasonably standard trim and might be easier to fit to the car, but I dont think it will be as reliable as the CA in the long run.
my 2c
Posted on: 2009/5/25 12:32
I'd probably go the rotary, specifically because of the weight (or relative lack of weight) of the vehicle. The rotaries (and please bear in mind this is a relative thing) in general produce more power but less torque than a comparable piston engine, which should suit a lighter car and a race-car at that. Plus, there's something quite enjoyable about the powerband of a rotary, even a turbo rotary.
If you are talking relatively standard engines, and making a complete guess as to how many hours you might cover in a year of competition, it's hard to knock the reliability of either one I suspect - you'd be running for a good few seasons before even having to think about any engine freshening up.
Posted on: 2009/5/25 12:50
John McKenzie
From tasmania
Bob there is a fella down hobart that as done the rotary conversion in a coupe It is a 13b I think. He is going to drag it.I bought the back end off him he had a r31 backend under it when I sore it .He is a mechanic and it is a really good job I may still have is number some were if you wanted to give him a call.
Posted on: 2009/5/25 13:05
From perth
hate to say it but power = rotor
just keep screwing the boost into it
Posted on: 2009/5/25 13:55
Not too shy to talk
From Guatemala
i'd rather go for a factory engine.. maybe a well done setup A15 with wiseco pistons. or ca18det
Posted on: 2009/5/27 5:51
Datsun Project.
From Mudgee NSW Australia
I have had both a 13B Jport 1200 ute and a ca18det 1200 coupe
The Ca18det was better in every way: power,realiability,economy,legality instalatiopn and not to menchin noise and police atraction. Yes you can get more power from a 13b turbo but in my opinion pretty $$$ for a decent engine build box engine managment ect. I would stick with the nissan 4 banger if I where you.
Posted on: 2009/5/27 9:28
If In doubt run more BOOST
From Christchurch NZ
the rotor can make more power, but be prepared to spend a #OOPS#load of money. CA=better value for money.
Posted on: 2009/5/28 8:32
Forced Induction!
just out of curiousity - is the car heavier with a ca18det or a 13bt? and secondly, is it possible to backspace the rotary further than the ca18det (or vice versa)?
I can never seem to get a straight answer as to the weight of a rotary engine. I'm also curious, due to the way the capacity increases - I suspect that the larger capacity rotary engines aren't that much heavier than the smaller ones, but could be wrong of course.
Posted on: 2009/5/28 12:13
John McKenzie
