wheel database
hey guys.
iv'e been searching the net for wheels (and tyre combo's) and found it difficult to find details on the fitment of rims on 1200's so i thought it might be a good idea to start a tread based on this one from ozdat (http://www.ozdat.com/forum/viewtopic.php?f=51&t=16561)
please include offset and what front end gear you are running (including added track if know and brakes)
Vehicle:
Front end:
Wheel Make/Model:
Wheel Size:
Offset:
Tyre size:
Spacers Y/N?
Comments:
hope this becomes a "thing"
thanks
J
ps, as soon as i get some decent wheels i'll put one up ;)
Posted on: 2012/11/17 12:12
1200 coupe
Re: wheel database
From Hawaii, USA
Vehicle: 1200 ute with modified fenders
Front end:
* stock, but with small-diameter coils
Wheel Make/Model:
* SSR Mark II
Wheel Size:
* Front: 14x7 +0 offset.
* Rear: 14x8 +0 offset
Offset:
* +0
Tyre size:
* Front: Advan 175/60R14
* Rear: Advan 195/60R14
Spacers Y/N?
* No spacers
Comments:
* Front fenders are slightly flared
* Rear fenders are flared about 1"
* Flush look, so tires rub occasionally
* have about 1" clearance to spring front & rear
* Stretched tires (spec is max wheel width 6" & 7", but I'm using 7" & 8")
Posted on: 2012/11/18 1:06
Re: wheel database
Vehicle: 77 1200 Ute
Front end: 120y
Wheel Make/Model: minilights
Wheel Size: 14x6
Offset: +25
Tyre size: front: 14x60x185 rear:14x60x195
Spacers Y/N? No.
Comments: guards are stock totally stock and wheels sit flush. Could probably do with having the front guards rolled. Also the rim clears the strut by about 8mm but this will be increased with a soon to some brake conversion. Rears are a non issue.
Posted on: 2012/11/18 3:17
Re: wheel database
From Sydney, NSW
Vehicle: 120Y -Rolled Gaurd Lips
Front end: Shortened 120y struts with VW Mk1 Golf inserts. S13 Camber tops (8kg spring)
Wheel Make/Model: SSR Reverse Mesh
Wheel Size: 14x9
Offset: -0
Tyre size:155/55R14 Federal FD1
Spacers Y/N?: N
Comments:
*1.5mm clearance from strut to lip
*lip just outside gaurds
*Stretched tyres
*-5 Degrees Camber
Posted on: 2012/12/24 0:15
Snapped crank and still smiling, How do I do it? LOL
Re: wheel database
From Brisbane, Australia
here's mine from over the years:
Vehicle: 120Y Wagon & 120Y coupe
Front end: only posting this for rear offsets...
Rear end: ADM 120Y BW68 in both the Wagon & coupe.
Wheel Make/Model: Volk Racing
Wheel Size & offset: 14 x 7.5 +2
Tyre size: 195/60
Spacers Y/N? N
Comments: needs lipped gaurds for lowering like the coupe. Wagon was OK with standard gaurds.
Vehicle: 1200 coupe
Front end: Stanza struts, LCA and brakes, lipped gaurds
Rear end: 120Y BW68, lipped gaurds
Wheel Make/Model: R31 steelies
Wheel Size & Offset:
14 x 5.5 +30 front
14 x 5.5 +10 rear
Tyre size:
F 185/60
R 195/60
Spacers Y/N? N
Comments: lipped gaurds, and front gaurd cut
Vehicle: 1200 coupe
Rear end: KE55 BW68 (wider than 120Y BW68)
Wheel Make/Model: Performance Superlite
Wheel Size & Offset: 13 x 7 -7
Tyre size: 205/60
Spacers Y/N? N
Comments: 50mm IPRA legal flares
Vehicle: 120Y coupe
Front end: standard 120Y discs, Kings lowered springs. Lipped gaurds
Rear end: standard H150, flipped leaf lowering
Wheel Make/Model: unknown jellybeans
13x6 +14
13x7 +3
Tyre size:
F 175/70
R 205/60
Spacers Y/N? N
Comments: lipped rear gaurds.
Posted on: 2012/12/24 3:07
Edited by L18_B110 on 2013/10/31 22:02:13
Re: wheel database
Vehicle: 1200 deluxe sedan
Front end:standard
Wheel Make/Model: Simmons B-45's
Wheel Size: 8x15
Offset: took them off my mitsubishi
Tyre size: front 15(195x45) Rear 15(205x55)
Spacers Y/N? n
Comments: looks like it's been mini-tubbed at rear, needs guards flared slightly, no internal rub.
Posted on: 2013/3/19 9:46
Luck is what happens when Preparation meets Opportunity.....
Re: wheel database
Vehicle: 1974 Datsun 120Y 2dr sedan
Front end: stock, lowered. Stock rear also.
Wheel Make/Model: Enkei Easyrider
Wheel Size and Offset:
14x6 +8 with 15mm spacer = effective offset -7
14x6.5 +0 with 15mm spacer = effective offset -15
Tyre size:
165/65 R14
185/60 R14
Spacers Y/N? yes
Comments: lipped gaurds. slight scrub on the back over BIG bumps at speed.
thread is useless without pics:
Posted on: 2013/8/22 8:33
Edited by L18_B110 on 2013/10/31 21:58:00
Re: wheel database
From oregon in the usa
car: formula junior
front end: VW type 3
front wheel: 15"x5" vw
front tires: 145R15, 155R15 165R15 ( whatever I can get )
rear wheels: 1966 ford mustang 6 14x5.5(rim reversed on the wheel center so there is some offset)
rear tire: 185 R15 (it was ok but 4th gear became overdrive.)
now trying 175 70 14 on the same wheels
other rear wheels: western wheels (aluminum) 13"x 6"
175R13 but have not tried them
jpg  1985+Gwynn.jpg (23.74 KB)
17442_5254e93e9568f.jpg 480X308 px
Posted on: 2013/10/9 6:25
Re: wheel database
I think the wheels are looking a bit tiny as compare to the car structure.
Posted on: 2013/12/19 9:09
automotive transmission repair
Re: wheel database
Front end: S13 brakes on 120Y struts
Rear end: Stock 120Y BW68
Wheel Make/Model: Performance Hotwire
Wheel Size and Offset: 13x7 +3
Tyre size: 205/60x13
Spacers Y/N? No
Comments: lipped gaurds. Minor pump for front gaurds. No scrubbing at all.
Posted on: 2014/9/12 2:56
