front brake upgrade 1200 ute
From Gold Coast
having bought a datto 1200 ute as a promo vehicle for my detailing business and now been bitten by the datto bug I am wondering what can be done easily and cost effectivley to upgrade the original 4 wheel drum brakes that my ute is running to a disc front?????
Do i have the only ute still running front drums?????
Posted on: 2005/4/14 12:11
Re: front brake upgrade 1200 ute
From Geelong, Vic
i think a stanza front end is the easiest way to go, im pretty sure that is easy to do.
dont really know as i havent done the convesion but im sure that other members can give you a better idea of the work involved
and there is also the tech section if you feel like reading
Posted on: 2005/4/14 12:24
From T'ville
stanza came with two types of brake setup
you would want the 'Girlock' caliper struts, later models.
what year ute? check bolt centre of the two bolts
that hold strut to the steering arm , or
if you can get the front end from the stanza complete control arms too , would best
but do a search and read up! plenty of info here
Posted on: 2005/4/14 12:26
From Gold Coast
1979 model ute
will the stud pattern stay the same as I have just bought 14 x 6 superlites??????
Posted on: 2005/4/14 12:29
From Geelong, Vic
yes, stanza stud pattern is the same
Posted on: 2005/4/14 12:36
From Sydney, Australia
Offsets are more than likely going to be different.
It could present a problem with your new wheels.
Posted on: 2005/4/14 12:53
stanza's the way to go
easy upgrade, easy work and cheap. just make sure you get the ones with the girlok calipers though, and if you can get the whole front assembly ... strut tops to control arm pivot bolts and a set of 120y radius rods.
you'll end up with about 30mm or so wider track and more negative camber. so if your tyres are close to the guards already you may need to get the lips rolled and the guards pumped out a bit.
Posted on: 2005/4/14 13:22
From Bris-Vegas
If you are going to eventually go for a bigger motor ie/ CA18DET etc. I'd suggest some S13 / 180sx brakes & calipers on some 120Y or Stanza struts..... You just need an adaptor plate for the the calipers - Can fix you up with adaptor plates, PM me if interested.
Posted on: 2005/4/14 23:22
CA18DET '74 1200 ute project
From Central Vic
Once you have up graded to stanza struts the next upgrade I would look at is blue bird rear disk assembly
Posted on: 2005/4/15 1:38
From WA
as per boofheads comments there - BUT
you may need to swap the struts right-to-left and left-to-right to clear the steering arms. also mounts the calipers INBOARD for better weight distribution. if you choose the girlock calipers, this is a must. but then, it's not worth choosing anything BUT the girlock calipers.
you can also equalise the track by fitting a BW KE30 corolla diff, which is 30mm wider than the 1200 diff. then you have a car with 30mm wider track - back AND front - for better handling again! get the handbrake handle and cable too if you do this.
Posted on: 2005/4/15 4:48
