A12GX Engine
(Redirected from A12GX)
Category: Engine Mechanical
The Datsun A12GX Engine is legendary. While it may not be a powerful as an A14 engine, it was a stock package offered in Japanese Domestic Model Datsun 1200 GX Sedans and Coupes and was rated at 20% more horsepower than the Standard A12 engine. The GX engine featured a matched pair of Hitachi HJE38W carburetors, larger cam, giant intake ports, and streamlined exhaust for superior high-RPM power.
A12 GX Engine
18247.jpgAlbum 18247
A12 GX engine - South Africa version
174_570c6e713ddba.jpgPost 478178
GX Engine - South Africa modified
17727.jpgAlbum 17727
free flowing exhaust system
29809.jpgAlbum 29809
174_67b163945c590.jpgPost 498788 174_67b163a8aaeee.jpgPost 498788 174_67b163ac9803e.jpgPost 498788 174_67b163b1892d9.jpgPost 498788 174_67b163b8716cd.jpgPost 498788 174_67b163bf397bb.jpgPost 498788 174_67b163d71eed7.jpgPost 498788
Performance
A12 69 horsepowerSingle carb Datsun B110
A12T 80 horsepower Twin carbNissan Cherry E10
A12GX 83 horsepower Twin carbDatsun B110
A14 80 horsepowerTwin carbDatsun B210
A14 92 horsepowerEGIDatsun B310
reference: Performance
GX Cylinder Head
The GX cylinder head has the largest ports of any factory A-series cylinder head. The ports are larger than A14/A15 ovals. This makes it suitable for extra-high RPM usage. However, the valves are standard A12 size, smaller than A14/A15 valves. The latter is a better head for regular-RPM usage (under 4000 RPM).
Main: A12GX Head
174_67b163c41c6b4.jpgPost 498788 174_67b163ccaf42c.jpgPost 498788 1002.jpgAlbum 1002
  • GX has intake ports shaped differently for flow and swirl, however it is said that a ported and polished standard A12 head with larger valves fitted flows about the same as a standard GX head. Also see head trivia.
  • The GX head bolts on an A14/A15, but is very similar to the oval port A15 head. However, the 1974-up heads provided oil to the rocker shafts in different locations so you may need to drill the oil passage in the newer block
  • There is apparently an A14 Oval Port GX head which flows more than the A12GX head.
    reference: GX Head or A15
  • GX head uses standard A12 size valves. No bigger than stock. The Nissan A14 Competition head was used by Nissan for racing is similar but has the larger A14-size valves.
  • GX fuel pumps have a slightly stronger spring under the diaphram to boost fuel delivery pressure a smidgen.
  • A12T (twin carb) cylinder head from Nissan Cherry has a different part number but seems identical
To be a genuine GX head, it must have these features:
  1. Extra-large oval ports 30x35 mm (larger than A14/A15 28x34 mm)
    18268.jpgAlbum 18268
  2. Four large-diameter water holes (5-6mm), one below each port (regular engines have three small-diameter, or none at all). These send coolant to the water-heated GX inlet manifold.
    4441.jpgAlbum 4441
  3. Heart shaped combustion chambers (Type B)
    3795.jpgAlbum 3795
  4. Extra hole drilled for rocker oiling
    18271.jpgAlbum 18271
  5. Valves: 35mm inlet, 29mm exhaust (smaller than A14/A15)
  6. Combustion chamber: 29.1 cc (as per FIA papers)
CAUTION: Some A12T heads also have the same features. How to tell the difference between Cherry Coupe (E10) A12T engine and A12 GX engine? Unknown. See discussion'Virgin Pone'.
Also note:
  • 1200 GX heads usually (always?) have no casting numbers at all
  • A genuine head may have had the dual-valve springs removed. But it will probably still have the dual-step valve spring seats
    18258.jpgAlbum 18258
Valves
A12GX valves are the same size as standard A12, and smaller than A14 valves. But they differ from standard A12 in material.
  • Intake
  • Exhaust
  • Dual Spring (inner coil, outer coil)
    • Cylinder head is machined for dual-step spring seats
  • Different valve stem oils seals (Option on standard A12)
  • Valve retainers are same as standard A12
Engine Block
The GX engine block is a standard A12 part. However, it carries a different Part Number because it has some extra parts attached to it:
  • Pistons: Flat top pistons for 10:1 compression ratio on hi-gas models
    • These are same as Datsun 1000 coupe (A10 engine) and Nissan Cherry A10 pistons (same part number)
    • NOTE: some GX engines have standard A12 9.5:1 dished pistons
  • Camshaft: Slightly longer duration cam than stock 1200, for 6800 RPM usage (up 400 RPM over stock cam)
  • Water pump inlet pipe at front of block (PIPE-suction, water pump) has an additional hose fitting for the manifold coolant hose.
20648.jpgAlbum 20648 11267.jpgAlbum 11267 14429.jpgAlbum 14429
  • PIPE-connector (breather pipe at rear of engine) is standard. Distinguish from Cherry block which has a right-angle pipe. Datsun 1200 pipe is straight out.
The block crank and rods are the same as the standard A12.
Block Ventilation
Induction
The GX engine uses a twin-carb inlet manifold with extra-large oval ports to match the cylinder head.
Features include:
  • a matched pair of left- and right- hand Hitachi HJE38W carbs. These are variable venturi (SU-type), with 38mm bore (~1.5 inches)'
  • Oval port inlet manifold with water jackets to match up with th water hoes in the cylinder head
  • Intake manifold has 2 studs at the top of each pair of inlet ports (cylinder head matches this). Standard A12 has only one stud per pair of intake ports.
  • Manifold has provision for PCV valve:
    24761.jpgAlbum 24761
  • It is reported that SU carburetors (H4 or HS4 1.5 inch carbs) will fit the GX manifold, with some linkage creativity.
  • The GX manifolds will fit an A14/A15 engine but port mismatch occurs
  • Fitting A14T manifold to A12 GX head will likely result in leaks since the GX head ports are higher up than the manifold ports.
Intake Manifold
5758.jpgAlbum 5758 14760.jpgAlbum 14760
Indentification
A12GX vs A12T: Manifolds are nearly identical, but A12T has two extra fittings
A12GX
26609.jpgAlbum 26609
Center fitting (yellow arrow) is for IMS speed screw assembly.
24759.jpgAlbum 24759
Far left fitting (no arrow) is for power brake booster. NOTE: Early Nissan Cherry A12T may be missing this fitting
A12T/A12GX versus A14T Port Sizes
* A12T: 30x35 mm
* A14T: 28x34 mm
A14T identification
24760.jpgAlbum 24760
Carburetors
The left-hand and right-hand Hitachi 38mm carburetors have a unique center linkage. They are 'dome-top' Hitachis, not the 'flat-top' models used in newer models like the B210.
  • The L-series twin-Hitachi engine linkage reportedly does not fit.
There is a stamped aluminum heat shield. The carb throttle return springs connect to a stamped hook on this heat shield.
14558.jpgAlbum 14558
Choke Linkage
Air Cleaner
Exhaust
The GX engine has a dual-outlet cast exhaust manifold that bolts to twin head pipes which blend into a single pipe further down. So this is very similar to tubular exhaust headers. The GX exhaust system is finished with a small resonator (for optimum power) and a muffler at the end of the floor pan.
12778.jpgAlbum 12778
Exhaust Manifold
Distributor
GX has special distributor, but it is not dual-points. The GX distributor differs from the standard 1200 model in only two parts. These two parts are the spring for the mechanical advance weights & the cam [for the points]. Both of these parts are standard A10 [non Coupe] components.
It uses only one spring for the mechanical advance mechanism instead of two in the standard distributor.
The engine from the KB10 [Datsun 1000 Coupe] used a different spec distributor to all other A10 powered models.
Spring 22110- 18001 [One only req]
Cam 22132- 18005
NOTE: Part numbers in the xxxxx- 18xxx range are A10 engine or B10 car part numbers.
The distributor in the photo below is the factory competition [race engine] distributor.
18240.jpgAlbum 18240
Rocker Cover
The Rocker cover is unique to the A12GX engine:
14415.jpgAlbum 14415
  • accelerator clip is on front pad, not rear
  • fuel line clip boss is on rear left side, not front left side
  • Datsun logo (not Nissan)
17453.jpgAlbum 17453
Arrows: Accelerator cable clip
  • GX: center feed accelerator cable
  • A12: rear feed accelerator cable
Circles: Left side threaded boss for fuel line
  • GX: rear boss
  • A12: front and rear bosses
NOTE: A12T in Nissan Cherry has a unique rocker cover that is different from A12GX or standard A12. Anyone have a picture?
  • Nominal Rev Limit: 6800 RPM (instead of standard A12 6400 RPM)
  • Actual Rev limit: reported fine at 8,000, float at 8,150 rpm
  • intake ports 30mm x 39mm oval ±1.5 mm tolerance
reference: FIA Amendment March 1970
Comparison
part A12GX Engine A12 Engine
Carb Hitachi HJE38W side-draft (two carbs) Carb Hitachi DCG306-1 down-draft
Carb Venturi Variable Primary: 26 mm, Secondary: 30mm
compression ration 10.0 9.5:1
combustion chamber 29.1 cm3 36.6 cm3 or 29.1 cm3
valve opens BTDC 20 degrees +- 7 degrees  ?
valve closes ABDC 56 degrees +- 7 degrees  ?
valve opens BBDC 58 degrees +- 7 degrees  ?
valve closes ATDC 18 degrees +- 7 degrees  ?
In. Valve dia. 29 mm 1.14 in  ?
valve lift 9 mm 0.35 in  ?
exhaust ports 27w x 29h +- 1.5 mm  ?
intake ports 30 mm circle with 6 mm elongated section  ?
exhaust ports 26w x 28h with 3 mm radius +- 1.5 mm  ?
center ex port 69w x 28h  ?
intake ports 28/27 mm circle  ?
Flywheel weight  ? 9.5 kg
Flywheel with all turning parts  ? 13.1 kg
hp 83ps @ 6,400 rpm hp 68ps JIS @ 6,000 rpm
max rpm 6,800 rpm (80 ps) hp 68ps JIS @ 6,000 rpm
max torque 10.0 kg-m at 4,400 rpm 9.7 kg-m at 3,600 rpm
max speed car 160 km/hour 150 km/hour
B210 A12 'GX' Engine
B210 GX car model came either with single-carb engine, or twin-carb engine.
Japan: Highest trim level
* Some GX models had the twin-carb engine (A12T or A14T)
* Other GX models had the single-carb engine (A12S or A14S)
USA:
* GX models had a standard A14S (single-carb engine)
The B210 A12 twin-carb engine was designated A12T by Nissan. It was basically the same as the B110 twin carb (1200 GX Engine), but based on the newer cylinder block. The head was no longer drilled for the oil gallery that was unique to the A10 & 1200. It also used flat top carbs and the inlet manifold had provision for a few more fittings to allow compliance with newer smog laws. There was also provision for a vacuum takeoff for the brake booster.
The B210 A12T induction seems to be the most commonly encountered twin-carb A-engine setup in Australia.
The B210 A12T exhaust manifold was the same as the GX one, but the fuel pump was of course the newer type for the new cylinder block.
The air filter housing base plate was revised a little to accomodate more fittings too, but the main cover piece was unchanged, other than for the change in colour from red to blue. It seems that L series SSS air filters also went from red to orange.
Late B210 in Japan had a twin-carb A14T engine option and came with special GX-T badging.
A14 and A15 'GX' Engine
Datsun Competition referred to an A14 'GX' cylinder head, however, this appeared to to be a late A12T head fitted with the larger A14/A15 valves. This would be the best A-series cylinder head and was not factory offering, but a racing/competition offering.
Late B210 (1976-1977) for the Japan market changed from the A12T to A14T (Twin Carb) engine. This had a regular oval port cylinder head and did not use the large oval ports of the A12GX Engine.
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=A12GX_Engine"
This page has been accessed 150,619 times. This page was last modified 04:44, 16 February 2025. Content is available under Datsun 1200 Club.
