Ernie's Twin-Weber Downdraft
(Redirected from Datsa73)
Categories: Featured Cars | Forced Induction
Ernie "datsa73", who lives in the Seattle area, has a nice Datsun 1200 2-dr sedan with a unique custom-built twin-Weber downdraft intake system.
2029.jpgAlbum 2029
Ernie says:
I have been wanting this car to go faster so I rebuilt the motor years ago. It wasn't fast enough so I put the dual Webers on it. It went faster but not fast enough. So I installed Nitrous. It went faster but not enough. You can see where this is going...I wanted it to still go faster so I supercharged it. Well, it's faster!!
8,000 RPM A15 engine:
2028.jpgAlbum 2028
Features
  • 1973 Datsun 1200 2-door Sedan
  • Datsun A15 Engine
    • Oversized deep dished forged pistons
    • Balanced
    • Ported A15 head with dual heavy springs (for 8,000 RPM capability)
    • Delta Cam
    • Dual Weber Downdrafts,
    • 50hp Shot of Wet Nitrous Oxide
    • Weekend Warrior: street licensed, but only put 4000 miles on it in the last 8 years
Twin Downdraft Webers
Datsa73 welds up aluminum plate to make the manifolds using the original A14/A15 manifold.
2027.jpgAlbum 2027
  • 36/36 Webers
  • This engine runs very well, has a slight lope at idle, but runs smooth at lower rpms. The power comes on harder starting about 3,000 rpm
At the 1/8 mile drags, Evergreen Speedway in Monroe, WA USA:
16222.jpgAlbum 16222
  • 1/8th mile track @ 9 second (equivalent to a 15.7 second 1/4)
  • Nitrous oxide, approximately 35 HP boost
  • Stock Datsun 1200 rear axle (H145 differential) -- never broken
Later upgraded to B210 rear axle assembly (H150 diff) with Lincoln-locker (welded spider gears)
16319.jpgAlbum 16319
  • Stock 4-speed
  • FIAT tachometer
  • Stock 1/4" fuel line
  • 278 duration camshaft
I run one NOS and one Fuel nozzle right into the intake between the two carbs.
I have only ran the car on an 1/8th mile track at 9 second... I am running a electric fuel pump that pushes 8-10 pounds of pressure which seems to work fine. The blower is a screw type and it does look like an eaton. Not sure if it really is. You can google them on ebay. They run about $450. It is clutch drive so I installed a switch on the dash.
It seems to run fine. I am still able to run my RPM's up to 8000 on full boost with NOS. The A15 motor is really holding out.
18026.jpgAlbum 18026
  • Weber 36/36 carburetors
    • Jetting: 120 on all bores
Ernie rebuilt the A15 "with only 6k miles on it" during the winter of 2008/2009 "about 10 years since it's last rebuild".
After taking it apart I found out that it really didn't need a rebuild. The head was worn out so I rebuilt that. No new parts on the lower end. I ended up putting all the bearings back in as well as my Total Seal Piston Rings. So really my block was only dunked and dingle balled. That was it. The hatch marks in the cylinders were still there from my original build. The machinest told me to just put the thing back together.
18027.jpgAlbum 18027
  • A15 going back in
A set of stock wheels and tires (pizza cutters) and I can leave 2 patches of tread for over 60 feet and that's without the Nitrous!
The unlocked H145 survived years. The locked H150 didn't have a chance:
18424.jpgAlbum 18424
  • Broken axle shaft
Now Supercharged
March 2009. As if a 50-HP Nitrous system is not enough, Ernie has added a Mercedes CLK Kompressor (supercharger) to the A15. The blower is driven off a Ford 5.0 pulley bolted to the crank in front of the existing A15 pulley. With this power boost, Ernie upgraded to an H165 rear axle from Datsun 411.
19225.jpgAlbum 19225
I finally got this project done and it only took me a couple of weeks.
Discussion: POST Supercharged 1200
Super B110
Videos
Features
  • Mercedes SLK 2.3 Kompressor (twin-screw design)
  • locked (welded) H165 differential
  • Rear axle from Datsun 411
  • Homebuilt traction bars
  • Tires Rear: Yokohama A048 R ADVAN 205/60R13
  • Tires Front: Federal 185/60R13
  • 10 psi blow-through boost
  • No intercooler, no water injection
  • 50 HP Nitrous shot
  • Stock 1/4" fuel line, 5/16" fuel hoses
  • MSD StreetFire Ignition Box and MSD tachometer adapter
      • Jetting: 140 on all bores (up from 120 pre-supercharged)
KA Power
Ernie converted to KA24DE DOHC power! Estimated 390 HP
Discussion: POST Super Bee KA24DR Mod
Twin Cam (156hp stock from Nissan S14)
24660.jpgAlbum 24660
Ernie changed to Twin Carbs, Supercharger and Nitrous
39_571bab7141767.jpgPost 478411 39_5136c504bbe4e.jpgPost 431566
S14 Front Sump oil pan
174_50a5dec7d1eed.jpgPost 423271
The motor sits low so the oil pan interferes with the cross member. New motor mounts have to be made.
KA24DE is an inch shorter than the Z24 and uses similar motor mounts. Ernie used modified engine mount brackets so it would fit the A12 crossmember horns. He shortened the S14 engine mount brackets 1".
39_50e4f7e9c2581.jpgPost 426544
Ernie notched the 1200 crossmember so the KA front sump oil pan would fit low-down
39_50b260282f6b6.jpgPost 423968
24865.jpgAlbum 24865 24750.jpgAlbum 24750 24749.jpgAlbum 24749 24748.jpgAlbum 24748 24747.jpgAlbum 24747 24746.jpgAlbum 24746
Datsa73's Photo Album
1232.jpgAlbum 1232 2027.jpgAlbum 2027 2030.jpgAlbum 2030 16222.jpgAlbum 16222 16223.jpgAlbum 16223 16224.jpgAlbum 16224 16225.jpgAlbum 16225 16226.jpgAlbum 16226 16227.jpgAlbum 16227 17329.jpgAlbum 17329 18024.jpgAlbum 18024 18025.jpgAlbum 18025 18026.jpgAlbum 18026 18027.jpgAlbum 18027 18028.jpgAlbum 18028 18423.jpgAlbum 18423 18424.jpgAlbum 18424 19278.jpgAlbum 19278 19279.jpgAlbum 19279 19280.jpgAlbum 19280 19281.jpgAlbum 19281 19282.jpgAlbum 19282 19283.jpgAlbum 19283 19284.jpgAlbum 19284 19285.jpgAlbum 19285 19286.jpgAlbum 19286
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Ernie%27s_Twin-Weber_Downdraft"
This page has been accessed 39,455 times. This page was last modified 19:56, 2 November 2023. Content is available under Datsun 1200 Club.
