Lighting System
Revision as of 21:37, 25 February 2014; view current revision
Lamps, lights. Parking lights, running lights. Whatever you call them, Datsun 1200s have them.
Also see:
27.jpg North America lights
Headlights
Both Koito and Ichiko (IKI) were original equipment.
NOTE: Large round headlights from *any*
car will fit the Datsun 1200.
B110, B210, and round-headlight B310 all use the same parts.
Rectangular Head Lamp
Square Headlights were IKI supplied. B122 starting in October 1989 uses square headlights.
NOTE: These appear to be same as B310 square headlights with buckets swapped left/right. But the adjuster screws and grommets are different.
North America
These are type 6012/6014 for a two-headlight system (a single large round headlight on each side of the car). These are "dual beam" lights (two-filament), encompassing both regular and high-beam in the same light.
Note that the original specification 6012 headlamp is only 50W/40W. You can substitute the brighter 6014 which is 60W/50W. Type 6015 is a longer-life bulb, but more expensive.
USA 1972 Owners manual (see page 36 for headlight specification):
Alternatively, and recommended, H6024 (65W/35W) is a halogen replacement. Halogen is a brighter light, and now available in shades of blue, gold, white. Street-legal in USA.
The brighter 6014 is as inexpensive as $3. See RockAuto headlights for Datsun 1200
Type Spec. Comments
6012 50/40 watt Original spec.
6014 60/50 watt replaces 6012
H6014 60/50 watt Halogen
6015 60/50 watt long-life
H6024 65/35 watt Halogen
H6024 XV 65/55 watt Extra-bright, long life
High-power Headlamps
H4 euro-type, Halogen, etc that require upgraded Headlight Wiring.
2962.jpg Halogen
Koito brand H4 headlamps, from original equipment supplier for Datsun 1200. Power Up - Wo!
H4 crystal headlight lenses with white LED insets.
Side Lamps
Side lamps come in two sizes: small and large
Side lamps are larger on North American models, also the fenders come with a larger hole to match. Euro/Asia guards/wings can be used on America 1200s, if the hole is enlarged.
9856.jpg USA - Large running lights (markers)
2301.jpg Other countries - Small turn signal lights (indicators)
See main article: Side Lamps
Front Lights
See Front Combination Lamp
Rear Lights
Rear light lenses are either:
  • orange-red-white, white-red-orange
or
  • red-red-white, white-red-red
Orange & red: Australian market, while all-red in America, Japan and South Africa markets.
1549.jpg Sedan (USA)
10520.jpg Sedan (Australia)
Coupe: long and thin. Sedan: short but tall:
9806.jpg Coupe vs Sedan Comparo
Coupe:
7034.jpg Australia
8570.jpg America
10207.jpg Coupe closeup
5164.jpg Wagon and Sedan (Australia)
1524.jpg GL Sedan (Japan)
2851.jpg ute
638.jpg Van (Australia)
47.JPG Sedan (portugal)
2842.jpg Sedan (Europe) - orange blinkers
9857.jpg Sedan (USA) - red blinkers
Later GLs used a different taillight:
    1972 GL
Possibly it was the same as Coupe or PB110, but with a different trim surround:
  • 757.jpg 1972 PB110
Rear License Plate Lamp
For USA market, the rear number plate light changed in 1973 to meet higher government standards of illuminating the plate.
Early license plate lamp (on top of bumper):
Late license plate lamp (dual lamps on either side of plate):
Customized Lights
  • Square headlights
  • Quad headlights
  • Clear lamp lenses
  • All-red rears
  • White-outside rears
  • Coupe rear lights on Sedan
  • Supra lights on Coupe:
Driving Lights
side markers, front combination lamp, rear combination lamp
Fog Lamps
Fog Lights were an Option.
B110
H1012 Rectangular
H1014 Round 126mm diameter
H1018 Round 160mm diameter
th_b1101971companybrochure1.jpg th_b110071.jpg th_sunny1200_catalog_p2021.jpg th_img_254596_7869102_5x.jpg th_fog_lamp-a.jpg th_fog_lamp-1.jpg th_fog_lamp-2.jpg th_fog_lamp-3.jpg
Aftermarket/Custom
B10 Fog Lamps
B210 Fog Lamps
フォグ ランプ
Operation
Headlight Switch
10046.jpg See: Instrument and Controls#Switches
Turn Signal Switch
T/S switch
Interior Lamps
The middle position operates from the door switches (if equipped).
5036.jpg interior "dome" light
USA 1972 Owners manual (see page 6 for Interior Lamp):
To switch the interior lamp "ON", and "OFF", turn the switch lever clockwise or counterclockwise.
13404.jpg int. lamp switch
3401.jpg alternative interior headliner light
Replacing Procedure
USA 1972 Owners manual (see pages 36-38 for replacing details):
headlights:th_36.jpg front & rear:th_37.jpg
license lamp & side lamps:
Dash Lamps
The instrument meter combination uses seven lamps which fit in the seven black holders with the white dots on them
Wedge Lock lamps - twist lock
Lamp Specifications
Front Combination Lamp - Early
26717-89920 BULB (12V-23/7W)
26261-89900 BULB (12V-3W)
Front Combination Lamp - Late
26717-89900 BULB (12V-23) [P21W]
26261-89920 BULB (12V-8/3.4W) [P21/5W???]
* or 26261-89925 BULB (12V-8/3.4W) 7804-
North America
  Spec. SAE No. Nissan^
Headlight unit 12V-50/40W 6012 see above
Direction and Parking 12V-23/8W 1034/1157 26717-89920
Side marker 12V-8W 67 26715-89902
License plate 12V-7.5W 89 26715-89901
Rear combo. Light
Taillight
Stop (brake)
Turn signal
Back-up light
12V-23/8W
12V-23/8W
12V-23W
12V-23W
1034
1034
1073
1073
26717-89920
26717-89900
Meter illumination 12V-1.7W (round gauge) 161 26711-89900
Wiper Knob illumination (1973) 12V-3.4W 158  ?
Heater control ill. (1973) 12V-3.4W 57  ?
Ignition warning 12V-1.7W 161 26711-89900
Turn Signal indicator 12V-1.7W 161 26261-89902
Headlight beam ind. 12V-1.7W 161 26711-89900
Oil press. warning 12V-1.7W 161 26711-89900
Brake warning 12V-1.7W 161 26711-89900
Room light 12V-10W n/a 26736-89902
^from USA catalog, all are ICHIKO brand
USA 1972 Owners manual (see page 36 for bulb specifications):
  1. Exterior single element, one bottom contact
    Rear T/S (turn signal)
    23 watt (North America) Sylvania 1156 Wagner 1156
    21 (other countries)
  2. Exterior dual element, two bottom contacts
    Front park & T/S, Rear Tail & Stop
    23/8W (North America) Sylvania 1157 Wagner 1157
    12/5 watt (other countries)
  3. FUSE, 10-AMP (2 needed) 08941-11000
  4. FUSE, 15-AMP (4 needed) 08941-11500
  5. 1972-1973 Seat belt light (on top of dash) Toshiba 12V 10W Type SV8.5 31mm long
  6. Dome lamp - 10 watt (room lamp) 26736-89902
    • Type SV7, ~29 mm long (pictured) seems to fit best, but are usually 3w or 5w
    • Parts stores specify the larger unit (see above Wagner 12100, Sylvania DE3175) which is readily available
  7. Instrument Panel lamp with twist-lock holder (7 used in round dash)
    • 26260-89900 Wedge Socket (7 total for round gauge) $3.28 USD each
    • USA 26261-89902 1.7 watt bulb (ROUND GAUGE)
    • JPN B110
      • 26261-89900 BULB-12V, 1.5W SQUARE METER 7
      • 26261-89902 BULB-12V, 1.7W ROUND METER 7
    • JPN B120
      26261-89900 7510-7803 12V-3.4W 商B113 8
      26261-89902 7804- 12V-2.7W 商B113 6
      26711-89900 7804- 12V-1.7W 商B113 2
      26711-89902 8910- 12V-2.7W 商B113 6
      26711-89900 8910- 12V-1.7W 商B113 2
    • 3.4 watt (Square Gauge) Type 158 14V
    • NOTE: Type 159 is identical looking, but only 1.0 watt 6.3V
  8. Exterior Lamp
    • Side-marker lamp
      • 8 watt (North America, non-flashing)
        Wagner 97 Sylvania 97 (9.32 watt nominal)
      • 6 watt (flashing, non-North America)
    • License lamp Sylvania 1895 Wagner 1895 (3.78 watt)
      10 watt (Sedan, except North America)
      7.5 watt Coupe, Van 26715-89901 Ichikho
      7.5 watt Sedan USA
    • Reverse light - 10 watt
  9. Instrument Panel Turn Signal indicator (2 needed)
Portugal
Opticas 12V-50/40W
12V-21/5W Luz de mudança de direcção o de presença
12V-6W Luzes laterais de mudança de direcção
12V-7.5W Luz da chapa de matricula
Conjunto de luzes traseiras
 12V-5W luz de presença
 12V-21W luz de stop (travões)
 12V-21W luz de mudança de direcção
 12V-21W luz de marcha atrás
12V-3W Luz de iluminacão do painel de instrumentos
12V-3W Luz avisadora da ignicão
12V-3W Luz indicadora dos máximos
12V-3W Luz avisadora da pressao do óleo
12V-10W Luz interior
12V-3W Luz de iluminação do relogió
