Datsun 1200s came with several badges (emblems). The original 1200 badges were metal, but the new ones -- genuine Nissan items -- are a high-quality plastic that looks very good. Aftermarket reproduction badges vary in quality from poor to very good.
Also see: Badge Part Numbers
Genuine Nissan badges are metal or plastic depending on the year made.
Various early B110 Sunny Emblems (Japan)
1972 JDM Facelift emblems
Market Differences
- Japan market 1200s used "Sunny" & "S" badges
- Export market 1200 used "Datsun", "D" badges
Colors
Most badges, especially the script ones, are simple silver color.
Sedan "S" and "D" grille emblems have red and blue bars:
Coupe "S" and "D" round emblems have tricolor red, white and blue pie sections:
Some are faded after all this time:
Most are faded to no color after 40 years:
Coupe
See main article: Coupe Badges
Sedan
Grille
Center Ornament
Early center ornament 62312-H1626 ('D') and 62312-H1026 ('S')
Facelift grille 62312-H3125 ornament Late JDM intricate "S"
Grille Left Side Badge
NOTE: there are 3 types of GX badges:top: early GX grille middle: 1972 GX grille bottom: GX rear (see through script)
DX early - no trim badge on grille
DX 1972 - 62330-H3125 EMBLEM SET-radiator grille "DELUXE"
compare to rear badge
84823-H1000
GL early - 62330-H2026
screw-on type. Rear GL badge is push-in type.
GL 1972 - 62330-H3325 EMBLEM SET-radiator grille "GL"
compare to early rectangular badge
GX early - 62330-H2325 COUPE, SEDAN
If the mounting bracket is lost, a length of plumbers tape will do the job (metal strapping tape)
GX 1972 - 62330-H3425 EMBLEM SET-radiator grille "GX"
compare to early wide badge
or rear see-through badge
GX5 - 62330-H7225 EMBLEM SET-radiator grille "GX 5 SPEED"
Side
C-pillar Emblem
GL
Rear
Model
Trim
Left Rear Deluxe - 84823-H1000
differs from similar looking front facelift badge
Left Rear GL - 84823-H2001 early
Left Rear GL - 1972 - 84823-H3300
Left Rear GX 84823-H2300
"see-through" script (compare to front GX badges which have a background attached)
GX 5-Speed 84823-H7200
Sports
4-speed Center Rear (left of license plate)
Sports badge
"Sports" 4-speed - to right of license plate
1972 GL Sedan rear
Automatic
Early "Full Automatic" 79200-H1020
Late "Full Matic" 79200-H2820 from '71 April (also used by coupe), 79200-H3200 1972
non-1200 'Nissan Matic' is blue 84821-U0300
Coupe badge on sedan ('Nissan Automatic')
keywords: エンブレム
Sunny Truck & Ute
See main article: Truck Badges
Van
Van uses the same badges as Sedan:
* Grille 'S' ornament (including facelift version) * No grille trim badges (Deluxe, GL or GX) * 'Sunny' rear quarter badge * 'Sunny 1200' rear badge * 'Deluxe' rear badge (DX only, early version) * 'Sports' rear badge (DX 4-speed only)
In addition, Van used these unique badges:
96905-18100 LABEL-loading capacity '400 kg' * lower left side
96907-G1100 LABEL-4 speed Van-Std T, Van-P T * middle height right side
'VAN' badge - Portugal![]()
Custom
'DATSUN 1200' coupe badge + Portuguese 'VAN' badge
1200 SSS
The Datsun 1200 SSS sedan was a product from Datsun New Zealand.
SSS left-side grille emblem
Same as 62800-N0401 MARK-radiator grille "SSS" Datsun 510 Coupe KPK, Sedan PTK
82858-U0800 - same as 610/180B SSS
- SSS badge on the glove box. Anyone have a photo?
Non-1200 SSS
These 1200 SSS badges are not to be confused with similar badges from other Datsuns that are pointy on the bottom.
910 Bluebird SSS 62892-W3500 Front Grille Mark 8201-8907 [triangular 'SSS']![]()
62896-W1200 Front Mark 7910-8112 [octagonal 'SSS']
810 Bluebird SSS [Sedan:62396-U7625, Coupe:62396-U8325]
62397-U7600 'SSS' ~120 mm long
411 SSS rear badge
:post
:full
:full
PB110 Sunny Excellent
The PB110 model line for the most part uses unique badging. See the "Sunny Excellent 1400" article: PB110.
The badges that appear to be the same as B110 are:
- 'Sunny' badge
- 'Nissan Full Auto Matic' badge
- Steering wheel badges
Datsun 1200 S1
The Datsun 1200 S1 2-door sedan was a Datsun of Portugal offering.
See main article: Datsun 1200 S1
- S1 grille badge
- S1 boot badge, fitted to left of the right taillight
Germany
'DATSUN' rear side 'DATSUN 1200' boot right side
Interior
The only interior badge is the steering wheel, a small piece of aluminum trim. See the steering wheel article.
Part Sources
* Nissan USA and Nissan Japan are out of badges * Nissan Australia apparently still has some. * eBay has them from time to time * Yahoo Auctions Japan always has some * Too Intense usually has some 1200 badges * Aoba Auto * South Yokohama * Matsuoka
Be careful of the quality:
Malaysia repro vs Nissan item: This reproduction badge has has poor chroming and what appears to be hand-painted coloring that doesn't exactly stay within the lines. However, other reproduction badges may be high quality.
エンブレム バッジ マーク
