Block Comparison
Revision as of 23:52, 21 June 2016; view current revision
Category: Engine Mechanical
The engine cylinder block changed for the 1974 model year. Early A-series Datsun engines (1966-1973) feature a front-distributor design. The A Engine Redesign of 1973 moved the distributor back to mid-engine, and moved the motor mounts back 35 mm.
B10 A10 Engine
 * no Breather Tube at rear of block
B110 A12 Engine
 * only two accessory bolt bosses on left side
 post
1974-up A12/A13 (short deck engines)
* Many accessory bolt bosses
 full
1974-up A13/A14/A15 (tall deck engines)
* Evenly-spaced Welch Plugs
Early A12
Block Oiling
Head Oiling
Early blocks have oil coming up through the head gasket to the cylinder head. 1974-up blocks have this hole plugged, and instead the oil comes up the center head bolt hole.
Brass plug in Late block
Pickup
Oil Pickup Location & Dipstick
changes
Dimensions
A10 Deck Height: 179.1mm
A12/A13/A12A Deck Height: 189.1mm
A14/A15 Deck Height: 204.1mm
Length (all): 393-394 mm block proper (less timing cover)
Tall Block
A14/A15 tall block engines have a Deck height of 204.1mm, or 15mm taller than an A12/A12A block. Length is the same.
  • 11010-H6200 [1974] A13 BARE BLOCK 73mm/2.87" bore size
  • A14 cast "A14" above fuel pump
    • H72 or G30
  • 11010-H9700 A14/A15 BARE BLOCK 76mm/2.99" bore size
    • G34
A10
B10 Sunny "Datsun 1000" came with A10 engine, 998 cc, 3-main bearing block. All other engines except A10 have 5-main bearings.
JDM Catalog
11010-18000 ALL Except Coupe
* uses 13035-18000 ASSY-COVER TIMING CHAIN
11010-18001 from E/# A10-184228
* uses 13035-18001 ASSY-COVER TIMING CHAIN < 13035-H1000 from 0570
 [updated to Double timing chain & pressure tensioner]
 [Fits all B10 blocks]
11010-25700 Coupe
Some B10 was fitted with NIKKI carburetor.
A12 Original
H10 block castings
11010-H2300 A12 BARE BLOCK 73mm/2.87" bore size
* USA 11010-H2300 0570- ALL <> 11010-H1000
* USA 11010-H1000 -0470
* JPN 11010-H2300 GX, running change replaced <2,0> 11010-H1000
* JPN 11010-H1000 except GX
M08 block from 1970-1973 E10 Nissan Cherry X-1R A12T
M15 E10 Cherry A12 single-carb
B110 A12 engine, five main bearing (so not interchangeable with A10 engine).
  • 11010-H1000 JDM, USA -0470
    • 13035-18001 ASSY-COVER TIMING CHAIN [single mark, pulley has multiple marks]
  • 11010-H2300 GX, USA non-GX from 0570-
    • 13035-H1000 ASSY-COVER TIMING CHAIN [multiple marks]
    • [chain tensioner and bolts changed 0570]
M08
M08 - Cherry A12T
A12 GX
B110 A12GX Engine block is the same as standard block, except for:
  • Flat-top pistons
  • GX camshaft
  • extra connection on the Suction Pipe
A12 from 1974
1974 engine redesign (From October 1973), accessory mounts and engine mounts not compatible with earlier A12 engine.
More bolt holes for more accessories.
Engine mount bosses are 35 mm farther back (in photo, mount is forward, on accessories mounts)
Revised Block
Early Block
Dimension (late engine)
B210 JDM
  • 11010-H5000
  • 11010-G1600 From June 1975 (?)
  • Both use 11110-H5000 PAN ASSY-OIL
  • Both use 13035-H1000 COVER-timing chain
B120 JDM (from Oct 1975)
  • 11010-G1600 7510-7907
  • 11010-G1618 7908-8503
    • 11110-H5000 PAN ASSY-OIL 7510-8503
  • 11010-G1619 8504-
    • 11110-G3401 PAN ASSY-OIL 8504-8910
    • All use 13035-H1000 Timing Chain Cover
    • 11110-H9701 PAN ASSY-OIL 8910-
B310 JDM
  • 11010-H5000 Van -7909
  • 11010-H9460 Van 7910-8010
  • 11010-H8500 Sedan, Coupe -8010
  • 11010-H9463 Van 8011-8109, 8110-
  • All use 11110-H5000 PAN ASSY-OIL
  • All use 13035-H1000 or 13035-H1010 COVER-timing chain
H50
H10 A12 B110 etc.
H72 A14 B210 etc. rear wheel drive
M72 A14 N10 Front wheel drive
H85 - B310 A12
H86 - A12A/A13
#M79 - A12
A12
No drain plug (undrilled boss)
Single drain plug
Dual drain plugs (M22? casting number)
G32?
New A12 has offset center core plug (same as original A12), but with two drain plug bosses.
A14 has re-spaced center core plug and single drain plug boss
M2 Block
A12 block with a large 'M2' cast mark on left side
L-series, Z-series, KA-series and A-series were all available with blocks marked M2. Apparently M2 indicates a factory replacement block.
Also cast 'M22' in the usual place, and cast 'A12' above the fuel pump boss
A12 M2 block
* Late model design (A Engine Redesign)
* Twin drain plugs on left side
* Late model scalloped crankshaft
* reportedly has small 25mm welch plugs on left side
M79
* single drain plug casting
* dual drain plug casting
full
full
full
1974 A13
USA model B210 came with unique pre-A14 tall block engine. B210 USA uses Mid Sump oil pan.
    • 11110-H6200 ASSY-PAN OIL
    • 11110-H7200 ASSY-PAN OIL FOR SERVICE
    • 11110-H7201 ASSY-PAN OIL FOR SERVICE
    • Uses 13035-H1000 Timing Chain Cover
A14
USA B210
11010-H7200 B210 USA
* B210 USA uses Mid Sump oil pan
* 11110-H6200 ASSY-PAN OIL -0275
* 11110-H7200 ASSY-PAN OIL 0375-0875
* 11110-H7201 ASSY-PAN OIL 0975-
* Uses 13035-H1000 Timing Chain Cover
North American B310
11010-H7200 -0779 USA, -1179 CAN
11010-H9905, 11010-H9900 0879- USA
11010-H9115 1279-0780 CAN
* 11110-H5000 OIL PAN [same as JDM B210 A12/A14]
H72 Casting mark with "29027A03" cast mark
G34 casting
* A14/A15 block
th_u29192282higkz26-img600x450-1222754743jupnux96499.jpg th_u29192282higkz26-img600x450-1222754743gds1vs96499.jpg with "C028X" mark
H72 with "28X23A01" cast mark
A15
North America B310
* 11010-H9700 -0779 [different from A14]
* 11010-H9905 0879- [Shared with A14]
** 11110-H9700 OIL PAN [unique to A15]
Nissan Competition
* 11010-H9700 A14/A15 BARE BLOCK 76mm/2.99" bore size
G34 Casting
G34 cast mark, also "8" and "238193"
A12A
75mm/2.95" bore size
North America B310
  • 11010-H8500 CAN 1278-0779
  • 11010-H8502 CAN
  • 11010-H9001 CAN 0879-
  • 11010-H9960 USA 0879-
    • 11110-H5000 OIL PAN
