Some 1980-1982 Datsuns in Asia markets came with an OEM (factory) EFI system. Nissan called it "EGI" -- Electronic Gasoline Injection (日産 EGI). This is the "rare as" A14E Injection motor. At 92 horsepower it was far superior to the carbureted 80 hp A14/A15, in fact this was the most powerful A engine offered by Nissan, with more horsepower than the twin-carb GX Engine.
quote:
a friend of mine has a system that came on the A14 in the M10 Pulsars (very first ones). The set up he got came from Singapore
The A14E engine came in:
- 1979-1981 Langley (N10 Pulsar) -- Asian markets
- 1978-up Feb - Sunny 1400SGX-E Coupe -- Asian markets
A14E was available until October 1980. It was replaced by A15E in November 1980.
Quite a large horsepower difference:
- A14E: 92 PS @ 6400 rpm, 11.7 kg-m @ 3600 rpm
- A14: 80 PS @ 6000 rpm, 10.2 kg-m @ 3600 rpm
SSS as I remember at one stage they had import carbie A15 engines for round $600 and injected A14 and A15 for around $800
Reportedly, Nepean Sports classics in Castlereagh NSW was selling import motors. carlos' son ran one. These are fairly sought after by the rally guys as the narrow runners provide torque and the length also good top end, too small for a big A15 though.
These possibly came in later model Nissan Vanettes, the reason they seem rare is both my manifolds broke across the bottom of no's 1 & 2 inlet runner. Plus it suffers from reversion with a big cam.
These were also available in asian markets (Japan, Singapore, etc).
quote:
- A14 EGI = HB310 (1978-1980) Type-GX & SGX
- A15 EGI = PB310 (1980-1981) Type-GX & SGX
As for the name in Japan, Nissan calls EGI and Toyota EFI.
Although the EGI system should excel Carburettors in the performance, old EGI is inferior to Carburettors.
Discussions:
As you can see here, the setup is nearly identical to 1980 200SX EFI system:
- This car is missing the air induction piping that goes across the radiator (see 200SX EFI for layout and diagrams)
B310 Factory Setup
Performance
This factory Nissan setup was designed for typical mass-market street performance. It is not a racing system. Expect better low-speed horsepower performance than a stock DCH306 carburetor (due to the longer runners), AND increased peak horsepower.
However, in a heavily modified engine, carburetion has more potential:
Quote
A factory EFI setup imported from Japan was tried, and found to be much smoother, but ... restrictive above 6000rpm when used with the [racing] cam.
Manifolds
Exhaust
The exhaust manifolds have not heat riser valve, and do not fasten to the bottom of the intake manifold -- like the A12GX manifold.
A14E has a free-flowing single outlet exhaust manifold:
Certain other late model A-series engines are similar, but the A14E manifold is unique.
A15E has a twin-outlet exhaust which looks nearly identical to A12GX Engine
- 14035-H9201 GASKET-MANIFOLD TO CYLINDER HEAD
- 14003-H9200 MANIFOLD-INTAKE A14E
- 14003-H9254 MANIFOLD-INTAKE A15E
- 14004-H9200 MANIFOLD-EXHAUST A14E
- Single outlet (A14-style, uses regular A14 Exhaust piping)
- 14004-H9260 MANIFOLD-EXHAUST A15E
- Dual outlet (A12GX-style)
- 20711-H9200 GASKET-EXHAUST
- 20020-H9200 TUBE ASSY-EXHAUST FRONT [to convertor] NICHIRA A15E F5
- 20020-H9210 TUBE ASSY-EXHAUST FRONT [to convertor] NICHIRA A15E F4
- 20602-F1700 NUT [for pipe to manifold] (3)
Intake
Port size
- 27x32 mm with injection cutout of extending up to 40mm
- compare to standard A14: 28x34
- Port sizes on the same manifold vary a bit
- 14035-H9201 GASKET-MANIFOLD TO CYLINDER HEAD A14E, A15E
- has notches at the top for the injectors
Be sure to port match, as ports can vary.
Black shows the gasket opening.
On the bottom of the intake manifold is the water hose. It connects to the front block water tube.
Water hose is "E" in this photo
- 14052-H9200 HOSE-WATER
- 08723-12000 CLAMP (2)
Throttle Body
- 16118-H9200 CHAMBER ASSY-THROTTLE A14E -7909 (to Sep. 1979)
- 16118-H9201 CHAMBER ASSY-THROTTLE A14E 7909- (from 9 1979)
- 16118-H9260 CHAMBER ASSY-THROTTLE A15E
- 16122-N1400 BOLT-CHAMBER A14E (4)
- 08915-13800 WASHER (4)
- 16175-H9200 GASKET-THROTTLE RETURN [Throttle body]
- 22620-W7060 SENSOR ASSY-ACCELE [throttle angle sensor]
- 08310-40814 SCREW (2)
Much larger than stock, a CA20 throttle body will bolt on:
- 16484-H9200 VALVE-SERVO
- 22156-85056 WASHER-SPRING
- 16485-U9800 SCREW
- 16599-N3600 CAP-CONNECTOR
- 16160-H9200 SPRING-THROTTLE RETURN
- 16182-H7820 DASHPOT ASSY TO 8004
- 16258-H9200 BRACKET-DASHPOT
- 16376-H9200 BRACKET-ACCEL CABLE
- 08360-61214 SCREW
Idle Air Bypass
Nissan calls this the Air Regulator. It adjusts the idle speed.
- 22660-H9205 REGULATOR-AIR ASSY
- 08710-61622 BOLT (2)
- 14060-H9200 HOSE-3 WAY CONNECTOR TO AIR REGULATOR
- 16439-N4202 CLAMP-HOSE
- 08723-12000 CLAMP
- 14061-H9200 HOSE-AIR REGULATOR TO CONNECTOR
- 08723-12000 CLAMP
- 14875-A7700 CONNECTOR-VACUUM HOSE
Injectors
The dropping resistor is located in the left hood ledge area forward of the strut of the B310.
- 22698-N4202 RESISTOR-DROPPING $60.65 USD
- 01451-00171 SCREW (2)
Control
The ECU is located in the left kick panel area of the B310.
- 22611-H9202 UNIT ASSY-CONTROL A14E
- superceded 22611-H9201
- 22611-H9265 UNIT ASSY-CONTROL A15E
EGR
EGR passage is a large area on the bottom side of the inlet runners.
- 14720-H9200 GASKET-EGR PASSAGE
