The B110 chassis number is stamped on the cowl and on the engine-compartment plate.
See Nissan chassis codes for explanation of model numbers.
Engine numbers should match the Plate. Engine numbers are here (right side of block, near back just under cylinder head):
See main article: Engine ID Mark
1980-up ID Plate
See main article: VIN
Oct 1980 (Japan) and 1981 Model year (USA) changed to a more detailed plate:
L-: L-level emissions (1981 Oct - 1989 Oct) G: Long Wheelbase Model: B122 Sunny Truck T: 4-speed Color: 002 White トリム Trim: C Engine: A12 gasoline engine S: Single carburetor Axle: HC41 H165 4.10 ratio Plant 4: Aichi Machine
Australia
Caution Plate コーション プレート
Japan badges list:
- Horsepower: 68 PS
- Torque: 5.6 Newton Meters
- Horsepower: 83 PS
- Torque: 7.1 Newton Meters
B120
Torque 8.4.That can't be right!
GB122
Thailand
New Zealand
Nissan Motor Distributors (N.Z.) Ltd.
In addition to regular Nissan plates, Land Transport NZ (formerly Land Transport Safety Authority) may add a "Low Volume Vehicle Certification Plate":
Brought to you by the Low Volume Vehicle Technical Association
South Africa
USA & Canada
1971 quench chamber cylinder head
69 HP:
1972-1973 open chamber cylinder head
68 HP:
USA Ratings:
- Horsepower: 68 or 69 SAE
- Torque: Not listed
For an explanation of SAE and why some are 68, others are 69, see: Performance.
Also see:
FMVSS Build Plate
In addition to the Nissan chassis numbers, USA models have an FMVSS build plate:
Color Number
For details, see: Colors
Custom Plates
Serial Numbers
JDM Catalog 11/1971
- Sedan: From B110-226985
- Coupe: From B110-877228
Maybe this is the serial numbers where 3N71B automatic was first introduced. Translation is difficult
USA Catalog
- U = United States models
- N = Canada models. Also some U models were sold in Canada.
- A = Automatic transmission-equipped models
Reference: Datsun 1200 USA & Canada Parts Catalog Model B110 Series (C-0030U), 4th Overall Revision, December 1973
- KLB110TU
- KLB110TN
- KLB110AU
Z | From (L)B110-764205 | From Apr-71 |
Z | From LB110-640001 | From Jan-72 |
Z | From LB110-477893 | From Jun-72 |
F | From (L)B110-877228 | From Apr-71 |
F | From (L)B110-940001 | From Jan-72 |
F | From LB110-975540 | From Jul-72 |
[I'm guessing the "Z" means the Zama plant, and "F" means the Fuji Heavy Industries plant. This fits because only some Coupe models were marked F, while all sedans were built at the Zama plant.]
- LB110TRU
- LB110TRN
- LB110ARU
Z | From (L)B110-247023 | From Apr-71 |
Z | From (L)LB110-341001 | From Jan-72 |
Vehicle Identification Number
Starting in 1980, Datsuns were marked with an international-standard 17-digit VIN number.
Engine
See Engine ID Mark
Transmission
Manual transmission number
