60-Series Transmission Parts
Revision as of 05:59, 13 February 2016; view current revision
Category: Transmission
Parts for 60-Series Transmissions are listed below. This includes 4-speeds and 5-speeds from B210 and B310 vehicles. The only non-dogleg 5-speed that Datsun used for A-series engines is the 60A (FS5W60A). The dogleg 5-speed for A14/A15 is the 60L (FS5W60L).
Part Number Prefixes
Also see main article: Applied Model Codes
The applied model part of the Part Number indicates the original use of the part. You'll find that several parts of the 60 gearboxes were originally used by the 56 gearboxes (180 parts), but that many parts are unique (H73 parts).
* 180	B10	56-series
* H73	B210	60-series
* H90	B310	unique to F5W60L
Rebuild Kit
O'Reilly Auto Rebuild Kits
PowerTorque BK173WS w/synchros $254 USD 60A
PowerTorque BK173 w/o synchros $146 USD 60A
PowerTorque BK139 $144 USD F4W60
Timken Rebuild Kits
TRKFN320 F4W60
TRKFN330 FS5W60A
TRKFN340 FS5W60L
Bearing Kit
Synchro Kit adds includes five (5) brass BAULK RING. See Synchros
Dogleg 5-speed
FS5W60L - dogleg 5-speed
BALL BEARINGS
(1) 32203-H7300  input shaft   Type 206
(1) 32273-H7300  main shaft    Type 305
(1) 32227-H9000  main shaft    Type 205
NEEDLE ROLLER BEARINGS
(1) ? 32219-H9000 cluster shaft, front ?
(?) 32219-H9702 cluster shaft, end
SEALS
(1) 32112-H7300 O-ring input shaft
(1) 32114-Y4000 seal   input shaft
(1) C2136-H5000 seal   output shaft
Non-dogleg 5-speed
FS5W60A - non-dogleg 5-speed
BALL BEARINGS
(1) 32219-H8900  cluster shaft Type 304
(1) 32227-H9700  main shaft    Type 62/22
(1) 32219-H9700 cluster shaft
(1) 32227-H9700 output shaft, rear
SEALS
Bearing Code example: 6206N C3
6 Type = Single-Row Deep Groove Ball Bearing
2 Series = Light duty
06 Bore = 6 x 5mm = 30mm inside diameter
N  = groove
NR = groove and snap-ring
Z  or L  = shielded on one side
ZZ or LL = shielded both sides
D  or RS  = sealed on one side
DD or 2RS = sealed both sides
C3 = clearance greater than normal
post
FS5W60L
The 60L 5-speed is unique:
  • 5th gear is added to the front
  • It's a modified 4-speed. The newer 60A is a re-designed gearbox, sharing fewer parts with the 4-speed
full
Reverse GEAR/HUB on end of output shaft
(large 1st gear below, small rev/idler gears to right)
Gearset
full
32228M 32228-H9000 RING-SNAP OVERDRIVE BEARING (2)
32230  32230-H9000 GEAR ASSY-1ST
32234  32234-H9000 RETAINER SHIFTING INSERT [incorrect? looks like a washer]
32241  32241-H9001 SHAFT-MAIN
32245  32245-H9000 GEAR-REVERSE, MAIN SHAFT
32246  32246-H7300 WASHER-THRUST
32250  32250-H9000 GEAR ASSY-2ND
32253  32253-H7300 BUSH-1ST GEAR (MAIN SHAFT) (2)
32354  32354-H9000 NUT-HEX (M25 X 1.0)
32258B 32258-H9001 HUB SYNCHRONIZER-1ST & REVERSE
32260  32260-H9000 GEAR ASSY-3RD 27T
32264  32267-H7300 BEARING-(NEEDLE,) MAIN SHAFT
32264M 32264-H7300 BEARING-NEEDLE MAIN SHAFT (2)
32601B 32601-H9001 HUB SYNCHRONIZER-2ND & 3RD
32602  32602-32200 SPRING-SHIFTING INSERT (SYNCHRONIZER INSERT) 3
32603  32603-18000 RING-SYNCHRONIZER (4)
32604  32604-H9000 RING-BAULK (4)
32606  32606-18000 SLEEVE-COUPLING (2)
32608  32608-H9000 INSERT-SHIFTING (9)
32609  32609-18000 INSERT-SHIFTING (6)
32273  32273-H7300 BEARING-(BALL,) MAIN SHAFT
32275  32227-H9000 BEARING-MAIN SHAFT
full
32200  32200-H7300 GEAR ASSY-MAIN DRIVE
32203  32203-H7300 BEARING-MAIN DRIVE
32203E 32214-H7300 RING-MAIN BEARING (2)
32204  32204 Select one RING-SNAP MAIN DRIVE GEAR
32205  32209-H7300 SPACER-BEARING MAIN DRIVE GEAR
32210  32210-H9000 GEAR-COUNTER ASSY
32219  32219-H9000 BEARING-COUNTER SHAFT [Also F460A 7812-]
32219M 32219-H9010 BEARING-COUNTER SHAFT
32220  32220-H9000 GEAR-REVERSE COUNTER
32221M RING-SNAP COUNTER SHAFT select one
       32222-H9003 SELECT T=1.3
       32222-H9004 SELECT T=1.4
32224  32224 Select one WASHER-THRUST COUNTER SHAFT FRONT
32225  32284-H9000 WASHER-THRUST COUNTER SHAFT REAR
32263  32263 RING-SNAP Select one
32272  32272-H7300 BEARING-PILOT MAIN SHAFT (3)
32281  32281-H9000 SHAFT-REVERSE IDLER
32281G 32292-14600 PIN-RETAINING [Also F560A]
32282  32282-H9000 GEAR-REVERSE IDLER
32283  32272-H7300 BEARING-REVERSE IDLER GEAR (2)
32285M 32285-H9000 SPACER-REVERSE IDLER GEAR
32285N 32284-N9000 WASHER-THRUST REVERSE IDLER (2)
32340  32340-H9000 GEAR ASSY-OVERDRIVE
32350  32345-H9000 BEARING-OVERDRIVE GEAR (NEEDLE MAIN SHAFT)
32605B 32601-H9000-HUB SYNCHRONIZER-4TH & 5TH [FS5W60L, 60A]
Bearings
RockAuto.com
BALL BEARING - input shaft (main drive)
62x30x11 mm Type 206
* 32203-H7300
BALL BEARING - counter shaft, rear
20x52x15 mm Type 304
* 32219-H8900
BALL BEARING - MAIN SHAFT, MID
* 32273-H7300
BALL BEARING - MAIN SHAFT END
* 32227-H9000
ENCLOSED BEARING - counter shaft, front
* 32219-H9702 [32219]
NEEDLE CAGE - pilot bearing
* 32272-H7300
32264M BEARING-NEEDLE MAIN SHAFT $38.43 USD
* 32264-H7300
 Rear 60A
 National B1616
 * Cone Bore: 25.400mm, 1.00 inch
 * Outside Diameter: 31.750mm, 1.250 inch
 * Width: 25.400mm, 1.00 inch
NEEDLE CAGE -  output shaft, rear
32350 BEARING-overdrive gear
* 32345-H9000 60L 5-speed
* 32345-H9702 60A
32283  32289-H9701 > 32289-H9700 BEARING-REVERSE IDLER GEAR $28.60 USD
* 60L 5-SPEED (2)
* 60A 5-SPEED (1)
60L 5-speed Bearings/Bushings
32272-H7300
NEEDLE CAGE bearing
* 32272-G3201 > 32272-H7300
18x24x17 mm needle roller bearing
* Nissan 32272-H7300 BEARING-PILOT 32272-G3201 $26.02 USD > 32272-14600
* Koyo RS18/17P
APPLICATIONS
* FS5W60L (1) pilot bearing (2) reverse idler gear
* FS5W60A input shaft pilot bearing
* F4W60L pilot bearing
32267-H7300
32264-H7300
32264-H7300 BEARING-NEEDLE MAIN SHAFT $38.43 USD
APPLICATIONS
* FS5W60L main shaft (2)
* FS5W60A main shaft (2)
32219-H9700
* Nissan 32219-H9702 > 32219-H9700 BEARING-COUNTER SHAFT, FRONT $22 USD
* enclosed needle roller bearing
* NTN 7E-BKS-20X32X20-4 181410 DRAWN CUP NRB CLOSED END (CAGE TYPE needle)
APPLICATIONS
* FS5W60A
* FS5W60L
32203-H7300
62x30x11 mm
* Nissan 32203-H7300 BEARING-MAIN DRIVE $31.78 USA
* Timken 206L
* SUZUKI 08163-62063
* SKF 6206ZNRJ
* Nachi 6206N C3
SPECS
* Inside Diameter: 30 mm, 1.1811 in
* Outside Diameter: 62 mm, 2.4409 in
* Width: 16 mm, 0.6299 in
* C3:radial clearance greater than Normal
APPLICATIONS:
* FS5W60L 5-speed input shaft
* FS5W60A 5-speed input shaft
32219-H7300
32219-H7300 BALL BEARING-COUNTER SHAFT
Type 304WB
Replaced by 32219-H8900
APPLICATIONS
* FS5W50A
* F4W60L -8010
32219-H8900
* Nissan 32219-H8900 BEARING-COUNTER SHAFT, REAR $95.28 USD
* Nachi 6304N
* Timken 304WB
* National 304
* Nachi 6304N CE 150525
* NTN 6304N
SPECS
* Bore  20mm, 0.787"
* OD    52mm, 2.047"
* Width 15mm, 0.591"
APPLICATIONS
* FS5W60L
* FS5W60A
* F4W60L
32273-H7300
BALL BEARING - Main Shaft (Output shaft, middle)
25x62x17 Type 305
* Nissan 32273-H7300 BEARING-(BALL,) MAIN SHAFT, MID
* NSK 6305NR
* SKF 43305C
* Nachi 6305 N C3 150314
* Timken 305L
APPLICATIONS
* FS5W60L
* FS5W60A
* F4W60
* F4W56A
32227-H9000
BALL BEARING - Main Shaft end
25x52x15 Type 205
* Nissan 32227-H9000 BEARING-(BALL,) MAIN SHAFT END
* Timken 205S
* Nachi 6205
APPLICATIONS
* FS5W60L
FS5W60A
60A 5-speed Gearset
full
Input shaft, Counter shaft, Reverse/Idle shaft
full
Output shaft
full
1st, 1-2 hub, 2nd
Reverse/Idler Gears
th_60a-reverse.jpg th_60a-reverse-1.jpg th_60a-reverse-2.jpg th_60a-rev-1.jpg th_60a-rev-2.jpg
5th gear bolted to end of cluster shaft
Cluster shaft and free-gears (1st, 2nd, 3rd)
32604-H9700 Synchro BAULK RING & matching gear surface
th_case-1.jpg th_case-2.jpg th_case-3.jpg th_case-a.jpg th_case-b.jpg th_casec.jpg
Input Shaft Bearing
BALL BEARING-MAIN DRIVE (Input shaft)
30x62x16 Type 206
* 32203-H7300
Reverse/Idler Bearing
This bearing fits into the extension housing.
32319-0H700 > 32231-E9000 BEARING-REVERSE IDLER GEAR FS5W60A [32283N] $15.83 USD
16x22x16
* NTN HK1616
* Needle Roller Bearing, Caged Drawn Cup
APPLICATIONS
* FS5W60A reverse/idler
* 71-Series Transmission cluster shaft
Output Shaft Bearing
BALL BEARING - MAIN SHAFT (Output shaft, mid)
25x62x17
BALL BEARING - MAIN SHAFT (Output shaft, rear)
22x50x14
* Nissan 32227-H9700 [32275]
NEEDLE BEARING - PILOT (input shaft)
18x24x17 mm
* 32272-H7300
NEEDLE BEARING - MAIN SHAFT
* Nissan 32264-H7300 (2) [32264M]
* 32267-H7300 (2) [32264]
NEEDLE BEARING - OVERDRIVE GEAR (input shaft, 5th gear)
* Nissan 32345-H9702 [32350]
32227-H9700
22x50x14
* Nachi 62/22XA1 140827 (22x50x14 ball bearing)
Cluster Bearings
60A 5-speed COUNTER Bearings/Bushings
32219 BEARING-COUNTER SHAFT
* 32219-H9700
32219M BALL BEARING-COUNTER SHAFT
* 32219-H7300
32224 WASHER-THRUST COUNTER SHAFT FRONT
* SELECT USE T=2.30 - T=2.25
32283 BEARING-REVERSE IDLER GEAR
* 60L 5-SPEED (2)
* 60A 5-SPEED (1)
32287 WASHER-THRUST REVERSE IDLER
32265-18000
* F4W56
* FS5W60A
Shift Control
Jam gears, shifter won't move: A broken roll pin on the 5/R shift fork can cause the 5/R rod to be sloppy enough to allow the shifter striking rod to slip between the gap to 5/R with out first returning the 4/3 rod back to Neutral. post
Brackets & Fork Rod form interlocks
2-1 Fork Rod 32809M 32801-H9700 ROD-FORK 3RD & 4TH
4-3 Bracket         32813-H9700 BRACKET-SHIFT ROD A
5-R Bracket         32382-H9700 BRACKET-REVERSE & OVERDRIVE
F4W60L
Ratios
rally cross of F4W60L Gear ratio
* 1st: 3.19
* 2nd: 2.38
* 3rd: 1.89
* 4th: 1.00
F4W60 gears - B210 USA CATALOG
32200-H7300 ASSY-GEAR MAIN DRIVE 20T
32210-H7300 GEAR-COUNTER 31-27-20-15T
32220-H7300 GEAR-REVERSE COUNTER 14T
32230-H7300 ASSY-GEAR 1ST SPEED 34T
32250-H7300 ASSY-GEAR 2ND SPEED 28T
32260-H7300 ASSY-GEAR 3RD SPEED 24T
32280-H7300 ASSY-GEAR REVERSE IDLER 22T
32245-H7300 GEAR-REVERSE MAIN SHAFT 34T
Main Drive Gear
32200  32200-H7300 GEAR ASSY-MAIN DRIVE 20T [F4W60L,FS5W60L]
32203E 32214-H7300 RING-MAIN BEARING [all 60]
32205  32209-H7300 SPACER-BEARING MAIN DRIVE GEAR [all 60]
Counter Gear
00922-12000 RING
32210  32210-H7300 GEAR ASSY-COUNTER
32219M BEARING-COUNTER SHAFT
       32219-H7300 -8010
       32219-H8900 8110-
32220  32220-H7300 GEAR-REVERSE COUNTER 14T
       SELECT USE
Reverse Idle Gear
00022-11800 RING (2)
32281-H7300 SHAFT-REVERSE IDLER
32282-H7300 GEAR-REVERSE IDLER
Main Shaft
32230  32230-H7300 GEAR ASSY-1ST 34T
32241  32241-H7300 SHAFT-MAIN
32241H 32204-18000 RING-SNAP
32245  32245-H7300 GEAR-REVERSE MAIN SHAFT
32246  32246-H7300 WASHER THRUST
32246M 32205-H7300 WASHER-THRUST MAIN SHAFT
32250  32250-H7300 GEAR ASSY-2ND 28T
32253  32253-H7300 BUSH-1ST GEAR [all 60]
32260  32260-H7300 GEAR ASST-3RD 24T
32263  RING SNAP select one
32264M 32264-H7300 BEARING-MAIN SHAFT (2)
32273  32273-H7300 BEARING-MAIN SHAFT
32601A 32601-H7300 HUB-SYNCHRONIZER 1ST & 2ND [all 60]
32603  32603-18000 RING-SYNCHRONIZER (6) [56,60]
32604  32604-H9000 RING-BAULK (4) [56, 60L]
32605A 32601-H7301 HUB-SYNCHRONIZER
32606  32606-18000 SLEEVE-COUPLING (2) [56,60]
32609  32609-18000 INSERT-SHIFTING (6) [56,60L]
Seals
Front Cover O-ring and Seal
  • The three welch plugs are not normally replaced or even removed
Front Cover O-ring
32112M  32112-H7300 RING-O FRONT COVER
APPLICATIONS:
* F4W60
* F5W60L
* F6W60A
* NOTE: 56-series differs
Front Cover Seal
Front Cover Oil Seal for Aichi R4W60L/W60 4-speed, W60L/W60A 5-speed, RS5W60R 5-speed
Nissan 32114-Y4000
* A12/A14/A15,KA20DE/KA24E/KA24DE,TD23/TD25/TD27,NA20
* RD28,RB20,L18/LD20/L20,H20,Z18/Z20,VG20/VG30,FJ20,CA18
* 60-series, 71-series 71B/71C
Specs
* shaft size: 30 mm
* bore size: 45 mm
* seal outer diameter: 45.2 mm
* seal width: 8 mm
* Polyacrylate or Nitrile
RockAuto
TCM 30X45X 10TC-BX
National 1981
Timken 1981
Fits:
* Nissan 32113-Y4000, 32114-20100, 32114-Y4000
* 8942152200
* 8943270620, 8943270621, 8943348450, 8943895931
* 9004310029, 9004311141, 9031130010, 9031130014
* 9031130115, 94215220, 94327062
* Ford EBTZ7052D
* Toyota W55 transmission
* Isuzu 8943270620 camshaft seal
Output Shaft
32150-H7300 4-speed 8110-
4-speed & 5-speed RockAuto.com
* Nissan C2136-H8900 > 32136-H8900 $10.00 USD
* Nissan C2136-H5000 > 32136-H5000 OIL SEAL-REAR EXTENSION $23.87 USD
* Timken 2016
* SKF 11619 (also says it replaces 32136-G1001)
FITS
* 56A,60A,60L
SPECS
* Material        Nitrile
* Shaft Size      1.181" 30mm
* Housing Bore    1.772" 45mm
* Outer Diameter  1.78"  45.2mm
* Flange Diameter 2.441" 62mm
* Width           0.591" 15mm
32263
* 32268-H9000 RING-SNAP SELECT T=1.60
* 32268-H9001 RING-SNAP SELECT T=1.65
* 32268-H9002 RING-SNAP SELECT T=1.70
32204
RING-SNAP MAIN DRIVE GEAR Select only one
* 32204-H7300 RING-SNAP MAIN DRIVE GEAR SELECT T=1.34-1.40
* 32204-H7301 RING-SNAP MAIN DRIVE GEAR SELECT T=1.40-1.46
* 32204-H7302 RING-SNAP MAIN DRIVE GEAR SELECT T=1.46-1.52
* 32204-H7303 RING-SNAP MAIN DRIVE GEAR SELECT T=1.52-1.58
* 32204-H7304 RING-SNAP MAIN DRIVE GEAR SELECT T=1.58-1.64
* 32204-H7305 RING-SNAP MAIN DRIVE GEAR SELECT T=1.64-1.70
* 32204-H7306 RING-SNAP MAIN DRIVE GEAR SELECT T=1.70-1.76
Thrust Washers
32287  32265-18000 WASHER-THRUST REVERSE IDLER [center]
32318  32287-H9700 WASHER-THRUST [REVERSE IDLER, rear]
32285N 32283-H9700 WASHER-THRUST REVERSE IDLER [front]
Used by all 60-series gearboxes
       SELECT USE
       32224-H7200 T=2.30-2.35
       32224-H7201 T=2.35-2.40
       32224-H7202 T=2.40-2.45
       32224-H7203 T=2.45-2.50
       32224-H7204 T=2.50-2.55
       32224-H7205 T=2.55-2.60
       32224-H7206 T=2.25-2.30
       32224-H7207 T=2.20-2.25
Sandwich Plate
32137-H7300 F4 -8010
32137-H7301 F4 8011-
32137-H9000 60L
32137-H9700 60A
With mainshaft center bearing dropped in place + reverse/idler shaft fitted
60A
Case Comparo
B210 F4W60A
* 32100-H7300 ASSY-CASE,TRANSMISSION B210 F4W60A 0974-0776
* 32100-H7302 ASSY-CASE,TRANSMISSION B210 F4W60A 0876-0377
* 32100-H8902 ASSY-CASE,TRANSMISSION B210 F4W60A 0477-
B310 F4W60
* 32100-H8902 CASE COMP-TRANSMISSION B310 F4W60 CANADA
* 32100-H8903 CASE COMP-TRANSMISSION B310 F4W60 0879- USA
* 32100-H9301 CASE COMP-TRANSMISSION B310 F4W60 0879- USA (supercedes 32100-H8903)
B310 FS5W60A
* 32100-H9001 CASE COMP-TRANSMISSION B310 FS5W60A -0779 [FS5W60L, dogleg]
* 32100-H9300 CASE COMP-TRANSMISSION B310 FS5W60A 0879- CAN (supercedes 32100-H9001)
* 32100-H9301 CASE COMP-TRANSMISSION B310 FS5W60A 0879- FED, CAL (supercedes 32100-H9001)
Extension Housing
32160- many EXTENSION ASSY-REAR
Factory Service Manual says:
If rear extension bushing is worn or cracked, replace it as an assembly of bushing and rear extension
