Oil pan
Revision as of 21:27, 22 April 2018; view current revision
Category: Engine Lubrication System
Datsun 1200 uses a tradition wet-sump oil pan, holding about 2.5 quarts of oil. It is a sheet metal part that plays no structural function. It is a front-sump design.
Also see: Dry Sump
Oil Capacity
Datsun 1200 1971-1973
* Oil pan: 2-7/8 U.S. qts., 2-3/8 Imper. qts. (2.7 L)
* Oil filter: 1-1/8 U.S. pints, 1 Imper. pint. (0.54 L)
Others:
* A12/A14/A15 oil pan: 2.8 liter
* A14 mid-sump oil pan: 3.2 liter?
The exact amount depends on the specfic oil filter used. Nissan oil filters come in several different sizes.
* Early A-engine 1966-1973 (A10 & A12) oil pans interchange
* Late A-engine (A12/A12A/A13/A14) use the same oil pan
* B210 North America uses a unique mid-sump pan
* A15 uses a unique oil pan with bulges on the side
Late pans may be used on early engines, but not vice-versa due to a slight change in the pan rail shape.
Dipstick
See main article: Dipstick
Drain Plug
Specs
Thread Size: M16.4 x 1.33
Under-Head Length: 12.00mm
Head Size: 21mm
Head Style: Flanged Hex
11128-69200 PLUG-DRAIN $3.57 USD
* Beck/Arnly 016-0058
* Dorman 90039
* 090039, 0900391, 1112869200, 11128U8000, 365235, 65235
* Datsun Roadster 1600 R16 engine
* Datsun Roadster 2000 U20 engine
* L-series/Z-series/CA18ET/SD25 engine
* 1986-1989 Nissan D21 KA24 engine
Dust Pan
The splash pan seals the underneath of the chassis at the front of the car. Nissan calls it the Front Under Cover.
74810 BOARD-SPLASH SHIELD
62611-H1000 COVER-UNDER,FRONT
F2611-H1000 8005-8503 > 62611-H1000
62611-H1000 8504-
See Block & Pan Part Numbers
11110-H1001 ASSY-PAN OIL 1 A12 - NLA
11119-61000 SEAT-DRAIN PLUG 1 A12 - $1.67
11128-69200 PLUG-DRAIN 1 A12 - $3.57
11026-61000 GASKET-DRAIN PLUG 1 A12 - $1.60
11130-18002 SEAL-OIL OIL PAN FRONT 1 A12 - $1.29
11131-18002 SEAL-OIL OIL PAN REAR 1 A12 - NLA
11132-18001 GASKET-OIL PAN RH 1 A12 - $4.42
11133-18001 GASKET-OIL PAN LH 1 A12 - $4.08
08110-61410 BOLT M6 FIXING OIL PAN 1 12 A12 - $0.32
11025-18000 STUD-LOCATING OIL PAN GASKET 4 A12 - $0.58
08915-13610 WASHER-LOCK FIXING OIL PAN 1 16 A12 - $0.72
08911-1062A NUT M6 FIXING OIL PAN 4 A12 08911-10610 $0.10
11140-H1002 GAUGE-OIL LEVEL $7.82
Gasket
NISSAN gaskets are in 4 pieces:
* 11130-18002 SEAL-OIL OIL PAN FRONT B110 - $1.29
* 11131-18002 SEAL-OIL OIL PAN REAR B110 - NLA
* 11132-18001 GASKET-OIL PAN RH B110 - $4.42 replaced by 11132-H1000
* 11133-18001 GASKET-OIL PAN LH B110 - $4.08 replaced by 11133-H1000
Later they went to a SET:
* 11132-H5025 GASKET SET-OIL PAN
  B210/B310/B120 A12,A12A,A13,A14,A15 1973 to 1994
  includes:
  * 11130-18002 front
  * 11131-18002 rear
  * 11132-H5000 right
  * 11133-H1000 left <> 11133-18001 (change 0674)
Rockauto.com
DNJ PG604
Beck/Arnley 0340380 1971-1982 A-series engines A12/A12A/A14/A15
Victor/Reinz OS30055
* replaces 11121-H5025, 11121-H5220, 11132-H5025
Fel-Pro OS20074C-1
The Datsun Factory Service Manual says to use sealer on both sides of the oil pan gasket, "especially on the front and rear portions of the pan". I believe the original was a cork gasket.
Oil pan side rails, cork or otherwise, needs no extra sealer. What it needs is:
  1. ensure the pan flange is flat. Many have been overtightened and won't seal correctly until straightened
  2. a dab of RTV sealer on the ends where the half-round gaskets meet the rail-sides. Do not put very much on.
  3. Do not overtighten. Factory torque is really low (they are only 6mm bolts). Tighten them to spec, then go round again and retighten.
Torque spec
0.4 to 0.6 kg-m
2.9 to 4.3 ft-lb
35 to 52 inch-lb
Early Blocks
1967-1973 - front distributor engine blocks
* Front Sump (B10 and B110 may interchange)
* B110 pan is deeper
A12 VS A10
174_57a000cf5cbb0.jpgPost 480296 174_57a000efe74f3.jpgPost 480296
Newer pans from Datsun B310 will fit the older A12. When the distributor was moved back for 1974 there was a change in the pan rail shape under the oil pump area which may prevent interchangeability between older oil pans and newer engines.
11110-H1001 B110 pan (note stiffening ribs on back portion)
11110-18001 B10 pan (2.5l) - note lack of ribs + seam down the middle
1974 up Blocks
1974-up (mid-distributor) engine blocks. All the A-series pans bolt to all A-series engines, but be sure to get the matching dipstick, dipstick tube and oil pump strainer to go with the pan.
Front sump A12, A12A, A14
* 11110-H5000 OIL PAN [same as JDM B210]
Mid-sump (North American B210)
* 11110-H7201 ASSY-PAN OIL
** Replaces 11110-H7201, 11110-H6200
A15 front sump pan with bulges, will retro fit into other A-series mid-dizzy engines.
* 11110-H9700 OIL PAN [unique to A15]
Beware of using an early A-series pan on late engine.
Late pan -> all engine
Early pan -> early engines only
HB210 Pan
North American B210 engines (A13 & A14) used a mid-sump (center sump) design. The oil pickup tube has a unique part number.
9373.jpgAlbum 9373
A15 Pan
11110-H9700 A15 pan with side bulges + stiffening ridges (for quieter operation)
25715.jpgAlbum 25715
The lack of clearances bulges on the B10/B110/B210 type pans prevents use on the A15, however the presence of bulges on the A15 pan does not interfere with its use on other rear dist engines.
Pickup Tube
The oil pump pickup tube has an integrated strainer/baffle.
174_5adcfe166ccf7.jpgPost 488153
15053-18000 GASKET-OIL STRAINER (ALL) <> 15053-18010
ASSY-STRAINER OIL
15050-18001 B10.-7006 [with stay]
15050-18002 B10.7007- [with stay]
15050-H1000 B110,B210,B310 A12/A12A/A13/A14
15050-H1001 B310.A14.8110-
15050-H9701 B310.A15
All A12/A13/A14
25111.jpgAlbum 25111 25105.jpgAlbum 25105
B10 strainer has a stay that is bolted to the A10 block. The block has an angle mount, so this strainer is unique and won't fit A12
B10
15050-18001 Oil Strainer
15050-18002 Oil Strainer (from '70-July)
B110/B210/B310/B120
15050-H1000 ASSY-STRAINER OIL A12/A13/A12A -8503 + A14 -8010
15010-H1001 STRAINER ASSY-OIL A14 8011-
15050-H6200 HB210 for mid-sump oil pan
15010-H9701 STRAINER ASSY-OIL A15
15010-H9702 STRAINER ASSY-OIL A12 8504-
15053-18000 GASKET-OIL STRAINER <> 15053-18010
08110-82062 BOLT (2) [M8 thread]
08915-13810 WASHER-LOCK (2)
B110 strainer tube has no supporting stay
7044.jpgAlbum 7044
Late model pickup has reinforcing brace braised to tube
26210.jpgAlbum 26210
H97 (A15) pickup & strainer
24785.jpgAlbum click to view
A10 Engine has a supporting stay
26673.jpgAlbum 26673 26672.jpgAlbum 26672 26671.jpgAlbum 26671
オイルストレーナー
FWD Models
  • 1970-1974 Nissan E10 (Cherry)
  • 1974-1978 Nissan F10 (Cherry, Datsun F10)
  • 1978-1981 Datsun N10 (Cherry/Pulsar/310)
Cast aluminum front sump
867.jpgAlbum 867
  • 11110-M0100 JPN E10 PAN ASS'Y-oil (to '74-6)
  • 11110-M0101 JPN E10 PAN ASS'Y-oil (from '74-7)
  • 11110-M4965 F10 USA ASSY-PAN OIL 1176-
  • superceded 11110-M3000 F10 USA -1076
  • 11110-M6660 N10 USA PAN ASSY-OIL 0880-0781 A15S
  • 11110-M6660 N10 USA PAN ASSY-OIL 0881-0780 A14S
  • superseded 11110-M7000 N10 USA 0878-0780 A14S
868.jpgAlbum 868
22918.jpgAlbum 22918 22917.jpgAlbum 22917 22920.jpgAlbum 22920
オイル パン
Alloy Pans
FWD A12 part, section above
867.jpgAlbum 867 868.jpgAlbum 868
Tomei
695.JPGAlbum 695 699.jpgAlbum 699 5038.jpgAlbum 5038 Tomei01.jpgAlbum click to view
Unbranded Tomei
xOilpan01.jpg xOilPan.jpg Pan08.jpg Pan05.jpg Pan15.jpg 7974.jpgAlbum click to view
Chromed pan
1868.jpgAlbum 1868
Custom arumi pan
Modified pan for turbo (note oil return fitting)
Nissan Competition Parts
1984 Catalog
  • 99996-H1050 B210 COMPETITION OIL PAN Completely baffled with special one-way pick-up tube designed to keep competition Oil pump primed
  • 99996-H1052 1200/210 COMPETITION OIL PAN Specifications same as 99996-H1050
  • 99996-H1135 SPECIAL OIL PAN GASKET Seals better than the stock gasket and can be reused when properly installed
  • 11128-H2375 ADAPTER/OIL TEMP SENDING UNIT Will adapt a Stewart/ Warner manual oil temperature sending unit to any stock oil pan
Steel pan 99996-H1052 Front Sump
15363.jpgAlbum 15363 1141.jpgAlbum 1141 99996-H1052-1.jpg 99996-H1052-2.jpg 99996-H1052-3.jpg 99996-H1052-5.jpg 99996-H1052-6.jpg
99996-H1050 mid-sump USA HB210
99996-H1050-1.jpg 99996-H1050-2.jpg 99996-H1050-3.jpg 99996-H1050-4.jpg 99996-H1050-5.jpg 99996-H1050-6.jpg 99996-H1050-7.jpg
Alloy Pan
19891.jpgAlbum 19891
Nissan Sports Graph (Sports Options Supplement)
17278.jpgAlbum 17278
Sports Options Catalog
412.jpgAlbum 412
12 11110-H2310 PAN ASSY-Oil
13 11112-H2310   PLATE-Baffle
14 11113-H2310   VALVE ASS'Y-One Way
7999.jpgAlbum 7999 8000.jpgAlbum 8000 8001.jpgAlbum 8001 8002.jpgAlbum 8002
comment
From Factory Competition Manual comment
