Choose an aftermarket inlet manifold to fit SUs, Webers and other sidedrafts, as well as alternative manifolds for the stock carburetors.
- Aftermarket manifold finish quality can be really poor so check for flat flanges, port overlap. See Jason's Weber page
- Weber DCOE type manifolds are used by Dellorto DHLA and Mikuni/Solex PHH series
- Hitachi sidedrafts can use SU manifolds, but there are two-bolt diagonal pattern and four-bolt pattern
- Buy a complete kit -- unless you like scrounging for all the little parts
Suppliers
- EFI Hardware
- TWM
- Lynx single (PN M041) and dual (PN M042) DCOE/DHLA manifolds, dual SU manifold (M137)
- TWM Induction intakes, carbs, etc
- Ramflo
- Lynx manifolds & Kay C (KC) adapter, Ramflo filters and Weber carbs
- Ram intake downdraft manifold
- Cannon Industries, apparently no longer in business
- 5611 208th Ave S.W.
- Lynnwood, WA 98036
- Redline Auto (Australia) makes single and dual DCOE manifolds and linkage, for A12 through A15 motors.
- Same parts are available from Holley (Australia).
- Stewart Wilkins GX manifold - only $260 AUD
- eBay - search for new and used manifolds
Weber
Weber manifolds are sold by various distributors.
A12 40 DCOE X1 99003.822 $165 @ Pierce Manifolds A12 40 DCOE X2 99003.110 $250 @ Pierce Manifolds A14 40 DCOE X1 99003.821 $215 @ Pierce Manifolds![]()
Weber IDF for A12GX head
EFIHardware
840-461 Suit Twin DCOE round port
840-462 oval port
840-463 large oval port
Cannon
Cannon manifolds are very low profile, so you can fit inlet trumpets or a tall air cleaner.
821 single DCOE oval port (A14/A15)
Thickness 2-13/16 to 2-10/16 inch
822 single-DCOE round port A12 (old bolt pattern)
Lynx
- M041 MANIF DATSUN 1200 1
- ???? 2 X DCOE/DHLA
- M042 MANIF DATSUN 1200 2 X HS4 SU
- M137 MANIF DATSUN 1200 2 X HS4 SU
- GX/SSS Oval Port 2 X DCOE/DHLA
D1000
Round port, pre-emission (no provision for PCV valve) for SU or Hitachi sidedraughts.
D1200 SU
Lynx D1200 for A12 engine, twin SU HS4 pattern, round port with crossover design.
Does this exist?
These do:
Lynx M042 MANIF DATSUN 1200 2 X HS4 SU Lynx M137 MANIF DATSUN 1200 2 X HS4 SU
D1200 Single
Lynx D1200 for A12 engine, single-DCOE pattern, round port with crossover design. Has provision for Crankcase Ventilation.
Crossover puts the runners in firing order
http://www.carburetion.com/LynxManifolds.asp
PCV can be unbolted and a vacuum tap fitted (for race cars)
D1200 with oval port flange welded on (custom)
D1200 Twin
Lynx D1200 Round port for Twin Weber DCOE 40 style.
GX
Oval port twin-DCOE manifold marked 'GX'. Not for the Datsun 1200 GX carburetors, which used twin Hitachis.
- Sold by #EFIHardware and others
- Appears to be the same casting as the '#SSS' manifold
SSS
Oval port twin DCOE manifold marked 'SSS'. This is not for the Datsun 1200 SSS model which had round port heads.
Redline Australia
Redline Performance/Hardiman: http://www.redlineauto.com.au
12-18 Manifold 2 X DCOE fit Datsun A14/A15
12-3060 Manifold Datsun 1 & 1.2L 2XDCOE Weber
12-3114 MANIFOLD DATSUN 120Y 1x40DCOE WEB
Rowland
Out of South Africa, Rowland made manifolds for the A14. http://www.manifolds.co.za
M030: Nissan 1400 Twin sidedraugt * use gasket 14035-H7200
M028: Nissan 1400 36 Weber DCD down draught * use gasket 14035-H7200
Tomei
See Parts Sources#Tomei for company info.
Warneford
Single Sidedraughts
In addition to the various brands listed above, see the following for photos of manifolds:
- Single Dellorto DHLA
- Single Weber DCOE
- Single Mikuni PHH
Custom
See Main Article: Intake Manifold#Custom
Tunnel Ram manifold
EFI
For EFI manifolds, see EFI Manifold
