The 63a transmission is a large strong transmission, and was made in a version to fit the A14 engine. It was adapted by Nissan to fill a marketing need in USA for a 5-speed (to compete with the Corolla SR-5) and so the existing 63A for the L-series L14 was modified to fit the small A-series A14 engine. This has two special significances:
- It is strong, suitable for overbored, supercharged or turbocharged A-series engines
- Its successor, the 60-Series Transmission 5-speed is much lighter and so a better fit for A14 and A15 naturally aspirated engines. The 60 is also smaller than 63 and so a better fit in Datsun 1200s.
For an overview of 5-speeds in general, see:
5-Speeds Comparisons, Ratio info, etc.
Datsun gearboxes are numbered by the distance between the centres of the countershaft and the main shaft. The 63-series has 63 mm between the shaft centres, so can fit larger, stronger gears than the smaller 60-series and 56-series boxes.
The "A" indicates the transmission revision, not the engine type it fits.
? my casting has a 63A#1 cast were there different versions?
63A #1 63A #2 63A #3
63A Dogleg shift-pattern 5 speed overdrive 5th gear 0.86:1 Slave cylinder is on the left side Uses AT prop shaft
The 63A came in two versions:
- 63A to fit L-series engine
- 63A to fit A-series engine
So check the bellhousing bolt pattern.
Debut dates for The 63A 5-speed variants:
- 1973 for L14 PB210 JDM
- 02 1976 for L14 B211 JDM
- 02 1976 for A14 B211 JDM
- 04 1976 for A14 B210 USA
Top: 63 'big boy'
Bottom: 60 series
The 63 transmission came with A14-powered B210 (HB210 and HLB210). It was not used by Nissan Competition for racing. Instead the 56-series was recommended for the small cars, and the 71 for the larger cars.
The 1977-1978 USA got B210s with factory 5-speed transmissions. Here's an advertisement for one:
MPG Champion - Datsun B210
This is the FS5W63A "dogleg" trans. Note the casting line around the center section on the otherwise smooth housing.
63A
Sources
The 63-series 5-speed for Nissan A Engine came in 1976-1/2 to 1978 Datsun B210 with A14 engine. USA and Japan markets had such cars.
63A for A-series Engine 1976-1978 HB210 with A14 engine
L-series FS5W63A transmissions came in these cars:
63A for L-series Engine & Z-series Engine B210 A14 USA JDM B211 L16S JDM PB210 L14 JDM S10 L20B USA S110 Z18 JDM PA10 Stanza L16 AUS
See main article: 5-Speeds
Clutch
63-series take the L-series type input shaft, but small-diameter (standard diameter) A-series size clutch disk. The 63A was first available in USA in April 1976, and only in Coupe.
- 30100-K0500 ASSY-DISC,CLUTCH 5-SPEED(COUPE) B210 USA, JDM $66.07 USD
- superceded 30100-H5801
- 30210-N1600 ASSY-COVER,CLUTCH 5-SPEED(COUPE) B210
http://www.rockauto.com/catalog/x,carcode,1210813,parttype,1996,partGroup,15
Specifications:
- 180mm Diameter (7-1/8") -- same as smaller transmissions (it fits the standard A12 or A14 flywheels)
- 24 Splines [56-series and 60-series use 18 splines]
63-Series 5-speed Swap Notes
Also see: Transmission Interchange
It's easy to get the 63 in if your 1200 was originally an automatic with a wider transmission tunnel. Use the auto tranny mount and make an adapter plate that will move the mounts to the right spot.
For manual 1200, remove the factory mounting bosses from the tunnel, and fabricate new ones:
Note that the factory crossmember mounting brackets have been removed from inside the tunnel. This custom crossmember bolts to the floor.
Get a Datsun 810 speedometer cable, it's about 150 mm longer.
Driveshaft
You'll need a Propeller Shaft from an AT equipped 1200 as it uses the same output shaft.
- B110 Auto shaft: 1349 mm (53-1/8")
- B210 Auto shaft: 1345 mm (end-to-end)
Tunnel Mounts Removal
Discussion: Tunnel mount removal?
The rear engine mount (gearbox mount) brackets are spot-welded on. Don't drill them right out. There is a special spot weld removal drill bit. Go to Mitre 10 or a decent Hardware they will have them. Grab a wire wheel or coarse sand paper sand around the mounts so you expose the spot welds a bit better and then carefully drill with the bit it will leave little lumps and you can file or coarse sand them down smooth. The last thing i would want is more holes in the body and floor -- they are thin enough already.
The only problem is that the spot weld drill bit insanely high-priced.
Gear Ratios
| Gear | F5C56A GX5 | F5C56A Opt. 1 | F5C56A Opt.2 | Overdrive 5 | Overdrive 5 | FS5W60A A14 | FS5W60A A15 | FS5W63A A14 |
| 1st | 3.757 | 3.757 | 2.676 | 3.513 | 3.513 | 3.513 | 3.513 | 3.382 |
| 2nd | 2.374 | 2.374 | 1.691 | 2.17 | 2.17 | 2.17 | 2.17 | 2.013 |
| 3rd | 1.659 | 1.659 | 1.398 | 1.378 | 1.378 | 1.378 | 1.32 | 1.312 |
| 4th | 1.254 | 1.291 | 1.181 | 1 | 1 | 1 | 1 | 1 |
| 5th | 1 | 1 | 1 | 0.875 | 0.825 | 0.821 | 0.821 | 0.854 |
| Rev | 4.04 | 4.04 | 2.877 | 3.764 | 3.764 | 3.764 | 3.764 | 3.57 |
| Note | Stock B110 & B210 GX-5 | wide ratio PN 32010-H7251P | close ratio PN 32010-H7220N | ? | ? | 1980 NA shop manual | 1980 NA Shop manual | 1978 NA Shop manual |
Also see: 4-speed gear ratios at end of article 5-Speeds
Switches
Reverse Switch: 32005-K1000, 32005-K102A $36 USD Neutral Switch: 32006-N5800, 32006-N5810, 32006-N5814 $20 USD Top: 32006-K2000, 32006-K2004 $21 USD Top: 32006-K2400, 32006-K2464 $24 USD
Top-detecting switch is used for cutting spark advance. It was used on some, but not all models.
For A-series Engine (FS5W63A)
- 32101-H7320 Transmission Case, 1976-1978 5-speed B210 Coupe
- 32130-N5809 Rear ASSY-EXTENSION, 1976-1978 5-speed B210 Coupe
For L-series Engine (FS5W63A)
- 32101-N6810 Transmission Case, S10 (formerly 32101-N6800)
- 32130-N6809 Rear ASSY-EXTENSION, S10
- 32101-N6810 Transmission Case, 1977-0679 A10 (formerly 32101-N6800)
- 32101-W0411 Transmission Case, 0779-up A10
- 32130-N6809 Rear ASSY-EXTENSION, -0679 A10 USA
- 32130-N9009 Rear ASSY-EXTENSION, -0679 A10 Canada
- 32130-W7100 Rear ASSY-EXTENSION, 0779- A10 USA
B211 JDM 32010-H7510 TRANSMISSION ASSY A14 32010-N7400 TRANSMISSION ASSY L16S 32703-N9016 PINION-SPEEDOMETER 16T L16S 32703-N9018 PINION-SPEEDOMETER 18T A14 32703-N9019 PINION-SPEEDOMETER 19T A14 32707-14600 SLEEVE-SPEEDOMETER * 32708-18000 WASHER-SPEEDOMETER PINION * 32709-14600 RING-O * 32873-14600 PIN-RETAINER SPEEDOMETER 32718-14600 PLATE-LOCK
Case
The case contains the bell housing and cover the first half of the gearset.
S10: 32101-N6810 CASE-TRANSMISSION L20B USA * superceded 32101-N6800 B210: 32101-H7320 CASE-TRANSMISSION USA B211: 32101-N6700 CASE ASSY-TRANSMISSION A14S JDM B211: 32101-N6800 CASE ASSY-TRANSMISSION L16S JDM PB210: 32101-N9001 CASE-transmission L14 (from '74-9) JDM * replaced 32101-N9000 (to '74-8)
B211 JDM 30501-K0400 SLEEVE-CLUTCH RELEASE L16S 30501-K0400 SLEEVE-CLUTCH RELEASE A14 30531-B5050 LEVER-WITHDRAWAL L16S 30531-K0550 LEVER-WITHDRAWAL a14 30534-E9000 SPRING-RETAINER WITHDRAWAL LEVER 30537-21010 PIN-BALL WITHDRAWAL LEVER 32005-21000 SWITCH ASSY-REVERSE LAMP 32113-N2101 SEAL-OIL FRONT COVER 32130-N6809 EXTENSION ASSY-REAR 38322-H7200 BREATHER 24210-89922 CLIP 32133-18000 PIN-DOWEL REAR EXTENSION 32135-28600 COVER-DUST SLEEVE YOKE 32136-U0100 SEAL-OIL REAR EXTENSION 32137-N9000 PLATE-ADAPTER 32121-N9000 RETAINER-BEARING
Gearset
From 1978 B210 parts catalog (Japan Market version)
- 32604-P0100 RING-BAULK (5) FS5W63A 5-speed JDM B210
- Same number listed in USA catalog
B211 JDM 32200-N6700 GEAR ASSY-MAIN DRIVE A14 32200-21100 GEAR ASSY-MAIN DRIVE L16S 32203-N9000 BEARING-MAIN DRIVE RING-SNAP MAIN GEAR DRIVE * 32204-08000 SELECT T=1.49-1.55 * 32204-08001 SELECT T=1.55-1.62 * 32204-08002 SELECT T=1.62-1.68 * 32204-08003 SELECT T=1.68-1.74 * 32204-08004 SELECT T=1.74-1.80 * 32204-16500 SELECT T=1.80-1.86 * 32204-16501 SELECT T=1.86-1.92 32205-08002 SPACER-BEARING MAIN DRIVE RETAINER 32210-N7400 GEAR ASSY-COUNTER L16S 32210-N9000 GEAR ASSY-COUNTER A14 32223-N9000 BEARING-COUNTER SHAFT 32220-N9000 GEAR-REVERSE COUNTER 15T RING-SNAP COUNTER SHAFT * 32222-N9000 SELECT T=1.65 * 32222-N9001 SELECT T=1.45 * 32222-N9000 SELECT T=1.85 WASHER-THRUST COUNTER SHAFT FRONT * 32225-N9000 SELECT T=1.350 * 32225-N9001 SELECT T=1.375 * 32225-N9002 SELECT T=1.400 * 32225-N9003 SELECT T=1.425 * 32225-N9004 SELECT T=1.450 * 32225-N9005 SELECT T=1.475 * 32225-N9006 SELECT T=1.500 * 32225-N9007 SELECT T=1.525 * 32225-N9008 SELECT T=1.550 * 32225-N9009 SELECT T=1.575 * 32225-N9010 SELECT T=1.600 * 32225-N9011 SELECT T=1.625 * 32225-N9012 SELECT T=1.650 * 32225-N9013 SELECT T=1.675 * 32225-N9014 SELECT T=1.700 * 32225-N9015 SELECT T=1.725 * 32225-N9016 SELECT T=1.750 * 32225-N9017 SELECT T=1.775 32221-N9000 WASHER-THRUST COUNTER SHAFT REAR RING-SNAP OVER DRIVE BEARING * 32228-20100 SELECT T=1.1 * 32228-20101 SELECT T=1.2 * 32228-20102 SELECT T=1.3 * 32228-20103 SELECT T=1.4 32230-N9000 GEAR ASSY-1ST 36T 32234-?6900 RING-SNAP SHIFTING INSERT SHAFT-MAIN * 32241-N7400 L16S * 32241-N9000 A14 32354-A7400 NUT-MAIN SHAFT 32720-14600 BALL-STEEL 32720-36900 BALL-STEEL 32245-N9000 GEAR-REVERSE MAIN SHAFT
