R31
Revision as of 22:55, 1 January 2015; view current revision
Category: Nissan Vehicles
Nissan Skyline model R31 was built in Japan 8508-9005. It was fitted with a Four Cylinder CA engine, or six-cylinder RB engines, or a Diesel. Australia-built R31 1986-1990 was sold as Skyline (six-cylinder) or Pintara (four-cylinder). Some parts can be used, or modified for use, on a Datsun 1200.
[hide]
Engine
JAPAN
F CA18S
H RB20E/RB20ET SOHC
R RB20DE/RB20DET DOHC
S RD28 diesel
AUSTRALIA
R31 Skyline: Holden RB30E
R31 Pintara: CA20E (NAPSX)
SOUTH AFRICA built
CA20S
RB20E
RB30E
Wheels
R31 Pintara 15x6 rims
R31 Skyline 14" steelies. See Skyline R31 spare steel wheels
Front Brakes
R31 featured 4-bolt x 114.3 PCD wheels.
250 mm
Standard wheel on both R30 and R31 is 14". Shouldn't be any problem running 14" wheels over these brakes. A few 13" alloys will fit, though no steel 13" will fit, even with grinding.
Though these are relatively small brakes, they are vented so will stand up to repeated braking, or mountain driving. Also see S13 Brakes for another 250mm brake swap.
R31 on B10
250 mm diameter, 22 mm thick
40207-41L25 HUB & ROTOR [integral hub] <> 40207-41L27
* R31 except 4K+K(RB20DT)
* R31 4K.RB20DT [4-door hardtop]
* C32 Laurel 8410-8610 ALL
* C32 Laurel CA18#+RB20E VG20ET+RD28
* F31 Leopard some
274 mm
The massive R31 separate-rotor 274 mm brakes require a 15" wheel. Stock was 6x15".
274 mm diameter
40206-59S01 ROTOR-DISC BRAKE, FRONT <> 40206-59S02
* R31 except (K+4K).RB20DT
* C32 RB20DET *VG20ET ANTI-SKID
* F31 VG30D.ULTIMA
* Infiniti M30 1989-1993
Strut
R31 uses a standard Nissan 2.0" strut, so will bolt to the usual SAP. However you NEED to buy/fabricate a spacer with shear ring as the locating nub is a different size.
R31 Handbrake Lever
R31 Handbrake Lever in 1200
Diff
JAPAN R31
H190: CA18S Sedan, Hardtop, Wagon
CA200: Wagon RB20T [4.11, 8601-]
R200: RB20, RD28 Sedan, Hardtop [IRS]
AUS R31 Borg Warner
* 9-bolt octagonal cover
* has rear disc brakes with finned calipers
BW78: Pintara, 25-spline axles
BW78: Skyline, 28-spline axles
AUS
There is some confusion as the Japan-built R31 used a similar looking diff, the CA200. Aussie R31 used the BW78.
CA200: 8-bolt cover
BW78: 9-bolt cover
See main article: Borg Warner 78
Rear Discs - see R31 Rear Disc Brake Swap
Swaps - see BW78 Rear Axle Swap
CA200
JAPAN R31 Wagon with RB20T SOHC Turbo 1986-1990
* (build dates 8601-9005)
CA200: Wagon RB20T [4.11 (CA41), 8601-]
* Drum brakes
* 5-link with coil springs
* 4-lug, 28-spline(?) axles
CASE-DIFFERENTIAL
* 2-pinion
* M12 ring gear bolts
* Fits: CA41,CA43,CA46,CA48,RC35,RC37,RC39,RC41,RC43,RC46
38421-12S00 8601-8708
38420-P9400 8708 <2> 38420-12S10
CA41 37/9=4.111
38100-F3400 8601-8604
38100-F3401 8604- $677 USD
SHAFT ASSY-REAR AXLE
38162-42L00
* R31 with CA18S
* R31 Wagon
* C32 some
* GC22 Vanette 8605 2WD
DRUM-BRAKE,REAR
43206-U4800
43010 CASE ASSY-REAR AXLE
43005-84S55 HOUSING W/GEAR <2> 43005-84S56
38423 GEAR-SIDE
38423-C6100
* (G)C22,D22,E23,E24,F22,F23,R31,WD21,160,250,
Alternative for swaps: GC22 Vanette - CA200 w/LSD
Gearbox
Japan-built R31 used FS5W71C 5-speed transmission.
32707-58S10 Sleeve, Speedometer Pinion 19T for CA18
* same as C22 with A12 engine
Speedometer cable with the larger end will work for Datsun 1200. 810 (200B) cable will work.
