B110 was fitted with seat belts. Belts differ by country. Two-point or three-point (with shoulder strap) belts were fitted.
Belts come in 2-point and 3-point versions, with 3-point ELR an option for late Sunny Truck
Seat Accessories Part Numbers
OPTIONS * Rear belts had retractable OPTION * Rear belts had a rare 3-point OPTION * Rear headrests
Australia
STD
Australia has ADRs to cover the installation of safety belts. This means starting with 1969 models, you cannot replace bad used belts with good used belts.
Get new belts from:
- Rare Spares
- Generic seat belts, Repco, etc.
- Klippan AU$85 and AU$120
- 1512 (retractable to suit 1200)
- K7099 (150mm drop links to suit 1200)
- K4264 - designed for 73 Holden, but fit 1200 well enough
The Klippan retractable units are compact and won't foul on most seats.
http://www.autolivaftermarket.com/
The 120Y recommendations are the same for 1200 Sedan.
Results for Nissan 120Y 1974-78 Make Nissan Model 120Y Config 4/DR SEDAN Year 1974-78 Details B210 1.2L Front Left Front Centre Front Right K1517 N/A K1517 Rear Left Rear Centre Rear Right K1635S K1637 K1635S
They can be bought through Repco. Get your old ones out and measure the length.
Variations
Early USA models came with either 2-point (lap-belt only) or 3-point (lap + shoulder) belts. Both front and rear belts are standard equipment.
- All 1972 models use 3-point belts
- From 0172, retractor system was used front and rear
- Rear set had 2-point belts
- Rear Optional was 3-point belts (not available with retractor type)
- 86810: shoulder belt
- 86820: 2 point
- 86830: 3 point (set? Or RH?)
- 86880: 3 point LH
- 88820: rear
B110
Front
Front USA (sedan & coupe use the same belts) 86830-H1000 3 POINT TYPE (2) 86830-H1001 3 POINT TYPE (2) 0871- $62.28 86830-H4600 3 POINT TYPE (AUTO LOCK R (2) 0172- $141.47 NOTE: 86830 comprises 2-point lap belt + shoulder belt
USA retractor belt (with detachable shoulder belt not shown)
Front JAPAN * 86820-H1001 BELT SET-safety (2 point) -0871, PB110 * 86820-H1001 BELT SET-safety (2 point) 0871- 3 point set (includes detachable shoulder belt) * 86830-H1000 BELT SET-safety GX 1972 (also PB110 option) * 86830-H1001 BELT SET-safety GX 1972
Shoulder belt 86810-H1000 BELT ASS'Y-shoulder, front seat (for 3 point) OPTION -0871![]()
86810-H1001 BELT ASS'Y-shoulder, front seat (for 3 point) OPTION 0871-
Unknown retractor shoulder belts installed in B110
full
Rear
Rear Seat Sedan, Van * 88830-H1000 SET-SAFTY BELT REAR SEAT 3 POINT TYPE USA OPTION * 88830-H1001 SET-SAFTY BELT REAR SEAT 3 POINT TYPE USA OPTION 0871- $71.11 * 88820-H1000 BELT SET-reat seat OPTION -0871 * 88820-H1001 BELT SET-reat seat OPTION 0871- JDM * 88820-H4600 SET-SAFETY BELT REAR SEAT 2 POINT TYPE 0171- USA (retractor type) Sedan, Coupe NLA * 88810-H1000 ASS'Y SHOULDER, safety belt OPTION USA * 88810-H1001 ASS'Y SHOULDER, safety belt OPTION JDM, USA 7108-
Rear Seat Coupe * 88820-H1800 BELT SET-reat seat OPTION [3 point], PB110 OPTION * 88830-H1801 SET-SAFTY BELT REAR SEAT 3 POINT TYPE JUSA Coupe 0871- * 88820-H1800 SET-SAFETY BELT REAR SEAT 2 POINT TYPE USA,JAP.OP Coupe * 88820-H1801 SET-SAFETY BELT REAR SEAT 2 POINT TYPE USA,JAP.OP Coupe 0871-* 88810-H1000 ASS'Y SHOULDER, safety belt OPTION USA * 88810-H1001 ASS'Y SHOULDER, safety belt OPTION JDM, USA 0871-
Seat Belt Warning System
USA models have a warning system. If the seat is occupied, the weight switch sounds a buzzer unless the belt is fastened. For details, see Seat Belt Warning System.
Swaps
The key to a great seat belt swap for B110 is finding a low profile rectractor that fits below the seat.
Late B210
1978 B210 (USA) dual-retractor design 3-point belt. It bolts to stock B110 bolt holes.
- Lower retractor blocks seat from fully moving back
- B210 Belt buckle is modern semi-rigid design that works stock B110 belts. But it is on the short side for B110.
620
1977 Datsun 620 pickup is a one-piece shoulder & seat belt, that bolts to stock B110 mount holes.
- Works like a modern belt, very nice
- Belt buckle is bit long. But works.
- Rectractor blocks seat from moving fully back. But has unique swing design so fits better than Late B210 belts.
1977 Datsun 620 Pickup belts (USA) in Datsun 1200
B210 belts bolt into B110. PB210 uses same belts.
Front * 86820-H5000 2-point -7503 * 86830-H5000 3-point -7503 GX * 86830-H7400 ELR 3-pt 7504- Sedan, Coupe 76- Van (Takata) * 86830-N6610 NLR w/shoulder 7504- Van * 86830-H7800 ELR 76- Van (Fuji)
Shoulder Belt * 86810-H5000
Rear Sedan, Coupe * 88820-H5000 -7503 * 88820-H7400 7504- (Takata) * 88820-H6600 OPTION van * 88820-H6601 OPTION van 0475- (Fuji) * 88820-H6602 Van (Takata)
Australia
Coupe Rear shoulder belt
Sedan Rear shoulder belt
North America
Aside from fabric type and regional requirements, the basic difference is:
- 2-dr vs 4-dr
All are retractor type. All are 3-point, early uses separate shoulder belt, later uses integrated shoulder belt.
4-dr
- 86830-H6200 POLYESTER(NSK) -0274
- 86830-H6210 NYLON (TAKAT)(USA) 1073-0275
- 86830-H6205 NYLON (NSK) (USA) 0374-0275
- 86830-H6206 NYLON (NSK) (USA) 0375-
- 86830-H6211 NYLON (TAKAT)(USA) 0375-
- 86830-H6205 NYLON (NSK) (CAN) 0374-0775
- 86830-H6206 NYLON (NSK) (CAN) 0875-
- 86830-H6210 NYLON (TAKAT) (CAN) 1073-0775
- 86830-H6211 NYLON (TAKAT) (CAN) 0875-
2-dr California
- 86830-H6900 POLYESTER (NSK) -0274
- 86830-H6905 NYLON (NSK) (USA) 0374-0275
- 86830-H6906 NYLON (NSK) (USA) 0375-
- 86830-H7301 NYLON (NSK) (CAL) 0974-0275
- 86830-H7302 NYLON (NSK) (CAL) 0375-0775
- 86830-H6905 NYLON (NSK) (CAN) 0374-0775
- 86830-H6906 NYLON (NSK) (CAL,CAN) 0875-
- 86830-H6910 NYLON (TAKAT) (USA) 1073-0275
- 86830-H6911 NYLON (TAKAT) (USA) 0375-0776
- 86830-H7311 NYLON (TAKAT) (CAL) 0974-0275
- 86830-H7312 NYLON (TAKAT) (CAL) 0375-0775
- 86830-H6910 NYLON (TAKAT) (CAN) 1073-0775
- 86830-H6911 NYLON (TAKAT) (CAL,CAN) 0875-0776
- 86830-H6920 NYLON (TAKAT) 0876-
Rear
- 88820-H6200 SET-SAFETY BELT REAR SEAT (rectractor type, 2 point) USA -1177 $67.89
- 88820-H6205 SET-SAFETY BELT REAR SEAT (rectractor type, 2 point) USA 1277-
B120
BELT-SHOULDER, FRONT
- 86810-H7400 7510-7803 BLACK
- 86810-G1060 7804-8910 DARK BROWN
2 POINT
BELT SET-FRONT SEAT, 2 POINT
- 86820-H7401 7510-7803 BLACK
- 86820-G1260 7804-8910 DARK BROWN
3 POINT Non retracting
BELT SET-FRONT SEAT, 3 POINT (separate shoulder belt)
3 POINT Retracting
These retractors bolt to the B-pillar and should fit B110 sedan, coupe and van -- although it may limit seat travel. With 2-door models it may interfere slightly with rear-seat access.
1978-1994 specs * Meets JDIS D4604 IIIB ELR-VW * Model: TK-521-G422 * TAKATA CORPORATION * 4525, K2133 * H2701, 108TI, 81R
BELT SET-FRONT SEAT, 3 POINT (integrated shoulder belt) DARK BROWN * 83830-G1070 ELR DARK BROWN 7804-8109 (option) BROWN * 83830-G1071 ELR 8110-8611 (option) * 83830-G1900 ELR 8611-8910 (standard equipment) GRAY * 83830-95W00 ELR 8910- * 83830-95W03 ELR タカタ 8910-
B310
Rear * 88820-H8500 Black $46.27
B310 front seat belts have a retractor mechanism that fits inside the B-pillar. So they do not fit B110.
B110 Vs B310
PB110
Sunny Excellent seat belts look the same as regular B110.
Mounting
Change May 1972
Coupe
Aussie front top mount point
full
Japan mount point is above the glass -- much higher.
Modified top mount location - matches late USA point
full
Sedan
Japan - above the glass
Revised (late) USA Front mount point - 2 door
Rear retractable belts
