The Nissan E engine (PLASMA) was a major redesign of the Nissan A engine, specifically to fit Front-Wheel Drive vehicles. The first varition, E15 debuted in late 1981 for the 1982 Pulsar (N10 "Datsun 310"), replacing the A15. it has an identical bore & stroke. For 1983 the E-series replaced the A-series engines in the Sunny model series. It can be swapped into Datsun 1200 with the usual swap fabrication.
The A-engine, which debuted in 1966, has wide popularity for its good response to acceleration. The E-engine is an extensively improved version of the A-engine. To meet both the trend toward enhancement of product value and the requiements of many customers, the E-engine was adopted for exclusive use on front-wheel drive, front-engine models. The E-series engine has been designed with consideration being given to small size, high output and fuel economy. Its design and construction have made it possible to mount the engine laterally on the FF (Front-engine, Front-drive) models, in conjunction with the "newly developed" transaxle which is in-line mounted on the engine.
The E-engine provides higher power and greater torque than the A-engine. Its dynamic performance, as in standing start, passing acceleration, upgrade driving, etc. has been increased by 5 to 10%. A summary of the major improvements is as follows:
- The E-engine is approximately 10kg (22 lb) lighter than the A-engine
- An O.H.C., cross-flow engine design provides high torque as well as responsiveness to acceleration.
- The cylinder pitch is identical to that of the A-engine, which has already been proven to be both duarable and reliable
- The overall length has been shortened by 48mm (1.89 in) to accomodate the in-line transaxle design.
A15: 65 HP @ 5,200 RPM, 112 ft-lb @ 2,800 RPM E15: 67 HP @ 5,200 RPM, 116 ft-lb @ 3,200 RPM
A summary of the major features of the E-series engine is given below:
- This engine is a water-cooled, 4 cylinder, in-line type.
- High combustion efficiency and low frictional loss result in higher engine output.
- A cross-flow design has been adopted for the intake and exhaust system to provide highly efficient combustion. The intake port employs a design that increases the "swirl" effect.
- The combustion chamber features a semi-spherical shape which provides high combustion efficiency. Additionally, the spark plug is situated nea the center of the combustion chamber for added combustion efficiency.
- The valve mechanism employs an OHC design with valves placed in a "V" arrangement. The camshaft is driven by a timing belt which features quiet operation and high durability.
Sources
E-Series vehicles
JAPAN MARKET (E13, E15) B11: 8110-8701 Sunny E15 B12: 8509-9008 Sunny E13S,E15S,E15E,E15ET B12L 8608-9008 Laurel Spirit E15S,E15E M10: 8208-8701 Prairie E15S (Single carb) N12: 8205-8701 Pulsar E15S+E15E (EGI) N12: 8305-8701 Pulsar E15T N13: 8605-9008 Pulsar E13S,E15S,E15E N13P 8610-9008 Langley/ E15S,E15E VB11 8210-8701 AD Van E15S G20 8901-9011 S-Cargo E15S
USA MARKET (E15, E16) B11 0282-0882 Sentra E15S B11 0882-0187 Sentra E15S+E16S B12 0186-0790 Sentra E16S,E16I N10 1081-0682 310 E15S (1982 model year only) N12 0882-0784 Pulsar E16S N12 0283-0784 Pulsar E15ET KN13 0986-0889 Pulsar NX E16I EUROPE MARKET (E10, E15, E16) B11 EUR 0382- E15S B11 EUR 0385-0187 E16S M10 EUR 0982-0187 E15S N10 EUR 1081- E15S N10 ELH E10S N12 EUR 0482- E15S N12 EUR 0682- E15ET N12 EUR 0685- E16S N12 ELH E10S N13 ELH E10S, E13S, E15S, E16S, E16I
Block
The cylinder block employs the same half-skirt design as that used in the A-series engine to provide small size and reduce weight. It uses a new casting process and is shorter, the better to fit transversely in small engine bays.
A jackshaft is fitted to the traditional camshaft location in the block, for the sole purpose of driving the the fuel pump and oil pump.
Cylinder Head
11041 CYLINDER HEAD
E15ET 17M EUR/JPN/USA
E16I 61A ELH/USA
E16 33M EUR/USA
E16S 73A ELH
E15E 15M JPN
E15S 11M EUR/JPN/USA
21M USA
31M USA also E16S
25M EUR
52A JPN VAN 8805-
63A ERL
E13S 05M EUR
01M JPN
50A JPN VAN 8805-
60A ERL late
E10S 41M EUR
62A ERL late
11041 CYLINDER HEAD
11041-60A00
* ERL.N13.E13S
11041-62A00
* ERL.N13.E10S
11041-63A00
* ERL.N13.E15S
11041-73A00
* ERL.N13.E16S
11041-61A00
* ERL.N13.E16I
* USA.KN13.E16I
11041-01M06/11041-01M05/11041-01M03/11041-01M02
* JPN.B11.E13S
* JPN.VB11.E13S.-8805
* JPN.N12.E13S
11041-50A00
* JPN.VB11.E13S.8805-
11041-52A00
* JPN.VB11.E15S.8805-
11041-41M00/11041-41M05
* ELH.N10.E10S
* ELH.N12.E10S
11041-05M04/11041-05M03/11041-05M02/11401-05M01/11041-05M00
* ELH.B11.E13S
* ELH.N12.E13S
11041-11M09/11041-11M08/11041-11M07/11041-11M06/11041-11M04/11041-11M03/11041-11M02/11041-11M00
* ELH.N10.E13S,E15S
* ELH.B11.E15S.*SWE,SWI
* ELH.M10.E15S.*SWE,SWI AIR POLLUTION MEASURE
* ELH.N12.E15S.*SWE,SWI
* JPN.VB11.E15S.-8805
* JPN.B11.E15S
* JPN.N12.E15S
* JPN.M10.E15S
11041-25M04/11041-25M03/11041-25M02/11041-25M01
* ELH.B11.E15S+*SWE,SWI
* ELH.M10.E15S**
* ELH.N12.E15S
11041-33M11
* ELH.B11.E16S
* ELH.N12.E16S
* USA.B11.E16S.0685-
* USA.N12.E16S.CAL.0185-
11041-17M03/11041-17M02/11041-17M02/11041-17M01/11041-17M00
* ELH.N12.E15ET
* JPN.B11.E15ET
* JPN.N12.E15ET
* USA.N12.E15ET
11041-21M00/11041-21M02/11041-21M03
* USA.N10.E15
* USA.B11.E15S
11041-31M03/11041-31M02/11041-31M01/11041-31M00
* USA.B11.E15S.-0685
* USA.B11.E16S.-0685
* USA.N12.E16S
11041-15M03/11041-15M02/11041-15M01/11041-15M00
* JPN.B11.E15E
* JPN.N12.E15E
Valves
7mm (.2746") valve stems * E10 35+29 length:~119 (same head diameters as A12) * E13 37+30 length:~118 (also USA.E15S, some EUR.E15S) * E16 37+30 length:~116 * E15 41+31 length:~120 (also early EUR.E15S+late-E16)
AMC applied model codes * E15 41+31 length:~120 15M/25M/53A/63A * E13 37+30 length:~118 05M * E16 37+30 length:~116 31M/61A * E10 35+29 length:~119 41M
13201 INLET VALVE 13201-15M00/13201-25M00 119.6 x 40.6 mm (4.71" x 1.6") * ELH.B11.E15S * ELH.M10.E15S * ELH.N12.E15S+E15ET * ERL.N13.E15S+E16S.0686- * USA.N12.E15ET 13201-31M00 116.7 x 37 mm (4.594" x 1.456") * ELH.B11.E16S * ELH.B12.E16I * ELH.N12.E16S * ELH.N13.E16I * USA.N12.E16 * USA.B11.E16I 13201-01M00/13201-05M00 118.6 x 37 mm (4.67" x 1.46") * USA.B11.E15S * USA.N10.E15S * ELH.B11.E13S+(OPT.E15S.SWE+SWI) * ELH.M10.(OPT.E15S.SWE+SWI) * ELH.N10.E13S+E15S * ELH.N12.E13S+(OPT.E15S.SWE+SWI) 13201-41M00/13201-41M01 119.1 x 35 mm * ELH.N10.E10S * ELH.N12.E10S * ELH.N13.E10S
13202 EXHAUST VALVE 13202-15M00/13201-25M00/13202-53A00/13202-63A00 119.9 x 31 mm (4.72" x 1.22") * ELH.B11.E15S+(OPT.E15S.SWE+SWI) * ELH.B12.E15S+E16S * ELH.M10.E15S * ELH.N13.E15S+E16S * USA.N12.E15ET 13202-31M00/13202-61A00 116.1 x 30 mm (4.570" x 1.183") * ELH.B11.E16S * ELH.B12.E16I * ELH.N12.E16S * ELH.N13.E16I * USA.N12.E16S * USA.KN13.E16 * USA.B11.E16I 13202-05M00 118.1 x 30 mm (4.648" x 1.185") * ELH.B11.E13S+(OPT.E15S.SWE+SWI) * ELH.M10.(OPT.E15S.SWE+SWI) * ELH.N10.E13S+E15S * ELH.N12.E13S+(OPT.E15S.SWE+SWI) * ELH.N13.E13S * USA.B11.E15S.1982-1983 * USA.N10.E15S 13202-41M00 118.6 x 29 mm * ELH.N10.E10S * ELH.N12.E10S * ELH.N13.E10S
Head Gasket
01M/31M/33M/58M E13/E15/E16 41M/62A E10
11044 GASKET-CYLINDER HEAD
E13,E15,E16,E15ET 11044-01M00 (REINZ) <> 11044-01M10/11044-01M02/11044-01M11 (ISHINO) <> 11044-33M11 <> 11044-33M12 <> 11044-58M00 <> 11044-31M00 <> 11044-33M10
E10 11044-41M00/11044-41M10 (REINZ) <> 11044-41M03/11044-41M11 (ISHINO) <> 11044-41M12 <> 11044-62A00
Fitting to A-series Block
The E-series engine is tricky to mount in a 1200 as the mount locations differ. So why not put the SOHC head on the A-series block? A14/A15 and E15 use the same bore size (76mm).
Need to figure out a belt drive.
The bolt holes all match except one at the back is out by about 2mm.
Intake Manifold
14033 GASKET-INTAKE MANIFOLD
14035-11M25/14035-11M26 oval port <> A4035-11M2E * E15S/E16S/E16I/E15ET
14035-01M25 <> A4035-01M2E * E10S+E13S
Exhaust Manifold
14036M GASKET-EXHAUST MANIFOLD, A
14036-01M25 E10S,E13S,E15S,E16S
14036-15M25 E15E,E15ET,E16I + some E15S,E16S + late E10S * USA: 1986-1987
Also See
