Lighting System
Revision as of 06:55, 5 September 2018; view current revision
Lamps, lights. Parking lights, running lights. Whatever you call them, Datsun 1200s have them.
Headlights
Datsun 1200 uses the standard 7-inch round sealed beam headlamp. And changed to large Square healights in 1990.
Side Lamps
Side lamps come in two sizes: small and large. Side lamps are larger on North American models, also the fenders come with a larger hole to match. Euro/Asia guards/wings can be used on America 1200s, if the hole is enlarged.
North America - Large running lights (markers)
Other regions - Small turn signal lights (indicators)
Front Lights
Parking lights/Running lights and turn-signal lamps (blinkers) are provided by the front combination lamp. All 1200 body style use the same Assembly (Coupe/Sedan/Van/Truck).
Europe | Japan
Rear Lights
Running lights, brake lamps (stop lights) and turn-signal lamps (blinkers) are provided by the rear combination lamp.
Japan/USA/ZA: red-red-white
AUS/Europe: orange-red-white
Sedan | Coupe | Truck | Van
Rear License Plate Lamp
Each body style (sedan, coupe, wagon) uses a different kind of number plate lamp. Truck uses the coupe type. The type of lamp corresponds with the bumper type.
Coupe/Truck under bumper | Sedan in bumper | Van above plate
Sedan side-lit
Customized Lights
Square headlights - See Custom Rectangular Headlight Grilles
824.jpgAlbum 824
Quad headlights - See Grille#Customized_Grilles
5668.jpgAlbum 5668
Clear lamp lenses
1850.jpgAlbum 1850 1849.jpgAlbum 1849 2137.jpgAlbum 2137 9306.jpgAlbum 9306 1948.jpgAlbum 1948
All-red rears with White-outside rears
1417.jpgAlbum 1417
Coupe rear lights on Sedan
3815.gifAlbum 3815
Supra lights on Coupe:
2869.jpgAlbum 2869 5606.jpgAlbum 5606
Driving Lights
side markers, front combination lamp, rear combination lamp
Fog Lamps
Fog Lights were an Option.
Main: Fog Lamps
Operation
Headlight Switch
Turn Signal Switch
Interior Lamps
Main: Room Lamp
Replacing Procedure
  1972 USA owner's manual (see pages 36-38):   th_00_cover.jpg
  headlights:
  front & rear:
  license lamp & side lamps:
Dash Lamps
The instrument meter cluster uses seven lamps which fit in the seven black holders (Wedge Lock lamps - twist lock)
Troubleshooting
Lamp Specifications
Main: Bulbs
