The Core Support & Front Apron (valence panel) form the front of the car body.
| Contents |
Apron
The front-most finisher panel is the valence (apron).
The Front Combination Lamps bolt to it, and also the bottom part of the fenders bolt to it.
H10 sedan type with no grille tabs H18 coupe type with tabs for plastic grille
ASSY-PANEL APRON FRONT 62612-H1000 Sedan + Truck to 7803 [62610] $112 USD 62610-H1800 Coupe + Truck 7803-8910 $130 USD 62610-H1800 Truck 8910- except SB.DX 62612-H1000 Truck 8910- LB + SB.DX
The apron panel upper edge has plastic grille lower brackets ... or none at all for early sedan/van/ute.
The upright slots in the apron are for the Bumper Stays to fit through
Core Support
The main front body panel is the Core Support, so named because it supports the radiator core. This panel forms the front of the Engine Bay. The grille is fastened to the support.
Connected parts: * Horn & Horn relay * Radiator
Note: The core support assembly includes the stay and rail, which were also sold seperarately.
ASS'Y-SUPPORT, radiator core 62500-H1000 Stainless grille type (sedan/van/early-ute) 62500-H1800 Plastic grille type (coupe/mid-ute) 62500-95W00 Square headlight type (late-ute)
There is also a cooling hole cover assembly, which covers the aircon hole in the core support:
62524-H1000 PLATE-closing rod (optional) 62524-H1000 COVER ASSY-COOLING HOLE Truck F/COLD ZONE
Radiator dimensions & High-tone horn mounting
Sedan & Wagon
All Sedan & Van, including 1972 facelift. Also for early ute.
62500-H1000 ASS'Y-SUPPORT, radiator core NLA.(USA) * 62512-H1000 RAIL-support, radiator core, upper [62511] NLA.(USA) * 62522-H1001 STAY-hood catch [62515] NLA.(USA)
Coupe
Coupe and mid-model utes.
62500-H1800 ASSY-SUPPORT RADIATOR CORE NLA.(USA) * 62510-H1800 RAIL-SUPPORT RADIATOR CORE UPPER NLA.(USA) * 62522-H1001 STAY-hood catch
Sunny Truck
Early (to March 1978) * Same as Sedan/Van Mid-model (April 1978 to October 1989) * same as Coupe Late-model (from October 1989) 62500-95W00 SUPPORT ASSY-RADIATOR CORE 8910- * 62510-G1265 SUPPORT-RADIATOR CORE, UPPER * 62522-H1001 STAY-HOOD LOCK
B140 replacement
-  The core support rail stay is the same for all models:
- 62522-H1001 STAY-HOOD CATCH (all models)
- sold separately but included with the Core Support assembly.
-  The other parts differ by the grille used. The core support has brackets for one of these:
- Sedan Grille (core-mounted brackets)
- Plastic round-light grille (narrow spaced brackets)
- Plastic square-light grille (wide spaced brackets)
- The core support rail has either wide or narrow plastic grille upper brackets ... or none at all for early sedan/van/ute.
- The core support contains headlamp fittings for either sedan, coupe, or square-eye. Sedan/van and early utes Cores (H1000) have brackets for the grille.
