<-- Back to: Lighting System
Datsun 1200 uses the standard 7-inch round sealed beam headlamp. 12V large round headlights from *any* car will fit circa 1956-1986.
Also See
* Headlight Aiming * Headlight Wiring * Lighting System for specifications * Headlight Part Numbers * Relay Adding a relay for more performance * High Power Headlamps Aftermarket high-power off road headlights * Converting to Round Headlights * Converting to Square Headlights * Grille
Grille & Headlight conversions
Datsun 1200 uses the standard 7-inch round sealed beam headlamp. 12V large round headlights from *any* car will fit circa 1956-1986. Original equipment was Koito, Ichiko (IKI), Toshiba or GE.
NOTE: Large round (7") headlights from *any* car will fit the Datsun 1200.
B110, B210, and round-headlight B310 all use the same parts.
26017-89910 RING-RETAINING KOITO -8910 26017-14801 RING-retaining IKI -8910 * B110, B120, B210, B310, F10, S10 08310-40812 Rim-retaining screw * B110 (6), B310.square-eye (8), A10.square-eye (16), 610, 710 Sedan (12)
NISSAN PART NUMBERS 26705 7" head lamp 26701 5.25" head lamp inner 26702 5.25" head lamp outer
Europe
H4 is high-intensity lamp, not a regular headlamp. Not legal in many countries for highway use.
The headlight type matter for the country driving type. Whether you have an LHD or RHD car, you mut use the same headlight to match the road. For example, in France they drive on the right -- typically (but not always) using LHD cars.
Sealed Beam Headlamp Unit, domed glass
A with front position lamp/city light/standing lamp/side light/parking lamp
C/R low/dip + high/main e.g. Tungsten HCR low/dip + high/main High power e.g. Halogen DCR low/dip + high/main Gas Discharge/HID
left-drive countries (marked with arrow) * typically they use RHD vehicles 26705-89991 KOITO Marked E6 D18452, A E6, I6RE Lucas SB7014RHD 12 volt 60/45W 7603 A
right-drive countries Lucas SB7014LHD 12 volt 65/55W may be marked E11 or other circle-E mark
RHD vs LHD
The left side and right side headlamps are the same - each car uses two of the same headlights. However, RHD (right hand drive) pattern is reversed from LHD - the lens pattern and high cutout is on opposite sides. If you fit RHD headlights in a LHD country or vice versa, it will blind oncoming traffic. So when importing cars, change the headlights to the locally approved type. Or you could fit tape to the lights as is done for visiting cars in Europe.
Rectangular Head Lamp
Square Headlights were IKI supplied. B122 starting in October 1989 uses square headlights as did B140 in 1990.
NOTE: These appear to be same as B310 square headlights with buckets swapped left/right. But the adjuster screws and grommets are different.
Australia
Headlight Globe Assembly Round 7" (178mm) 12V * 50/40W original specification * 60/45W * 75/50W SB7019 or BSB7 sealed beam * 110/95W Hansa FH6014 - LHD?
Semi-sealed Beam with park light opening * 200mm x 142mm Large Rectangular Sealed Beam * 85/65W Hansa EL07817
North America
USA requires a LHD light dispersion pattern. Use of JDM headlights will blind oncoming drivers.
VENDOR: RockAuto.com Product: headlight bulbs for Datsun 1200☁
CAUTION: Any headlight marked "DOT Approved" is bogus.
7" round sealed beams are type 6012/6014 for a two-headlight system (a single large round lamp on each side of the car). These are "dual beam" lights (two-filament), encompassing both regular and high-beam in the same sealed beam unit (sealed so the reflector will not tarnish). Recommended is type H6024, which is a direct-replacement but higher power (65W/35W) bulb. About $13 on Amazon.com
Head Lamp LHD - North America specification 26705-89905 UNIT-SEALED BEAM (KOITO) 26705-89925 UNIT-SEALED BEAM (ICHIKO) <> 26705-04201
These are type 6012/6014 for a two-headlight system (a single large round headlight on each side of the car). These are "dual beam" lights (two-filament), encompassing both regular and high-beam in the same light.
Note that the original specification 6012 headlamp is only 50W/40W. You can substitute the brighter 6014 which is 60W/50W. Type 6015 is a longer-life bulb, but more expensive.
1972 USA Owners manual (Page 36 ... ):
Specification
Alternatively, and recommended, H6024 (65W/35W) is a halogen replacement. Halogen is a brighter light, and now available in shades of blue, gold, white. Street-legal in USA.
The brighter 6014 is as inexpensive as $3. See RockAuto headlights for Datsun 1200
| Type | Spec. | Comments |
| 6012 | 50/40 watt | Original spec. |
| 6014 | 60/50 watt | replaces 6012 |
| 6015 | 60/50 watt | long-life |
| H6014 | 60/50 watt | Halogen |
| H6024 | 65/35 watt | Halogen |
| H6024 XV | 65/55 watt | Extra-bright, long life |
| H6024LED | Wagner TruView Plus LED | Extra-bright, whiter, long life |
| NHLED7ROUND | GE NightHawk LED | Plastic lens |
26010-H6200 HEAD LAMP RH (GE #6014) B210 USA COUPE 26060-H6200 HEAD LAMP LH (GE #6014) B210 USA COUPE 26075-88839 UNIT-SEALED BEAM GE 6014 (2) USA COUPE 26010-H1900 HEAD LAMP RH ICHIKO B210 USA SEDAN 26060-H1900 HEAD LAMP LH ICHIKO B210 USA SEDAN 26010-132T0 HEAD LAMP TOSHIBA (2) <> 26010-89925 26010-N5800 HEAD LAMP RH ICHIKO USA B310 26060-N5800 HEAD LAMP LH ICHIKO USA B310 26010-89935 HEAD LAMP RH TOSHIBA USA B310 (2)
Markings
USA bulbs may be marked 'USA' and 'DOT'
2D1 - Type 6014/H6014/6015/H6017
Brightness
Instead of limiting the brightness (candlepower) or flux (lumens), FMVSS limits the power.FMVSS 108
S7.3.5 Type D headlighting system. (a) A Type D headlighting system consists of two Type 2D1 headlamps ...
(b) The maximum wattage at 12.8 volts (design voltage): 65 watts on upper beam, and 55 watts on lower beam.
LUMENS per SAE-J1383 2D1 lower: 1320 maximum 2D1 upper: 800 minimum 9004 65/45W 1316/800 H1 55W 1550 H2 55W 1450 H4 60/55W 1650/1000
As can be seen, H4 type 60/55W bulb meet the spec: more than 800 upper beam, less than 1320 lower beam. Sealed beams are also commonly available; 65/55 (H6024 Xenon) and 60/50 (H6014). Although it seems Sylvania has down-graded the H6024XV to 60/40 (maybe due to overheated wiring)?
6014 NAPA LMP 60/50W (Incadescent/non-Halogen) Approx. Max Candle Power * Primary 32000 * Secondary 25000
H6024 (Halogen) 138/60 cp (high/low beam) 1735/754 lumens H6024 Philips/Wagner * 35,000/27,000cp
High-power Headlamps
H4 euro-type, Halogen, etc that require upgraded wiring.
NOTE: LED headlights can be brighter without using higher power and so work with the stock wiring.
Koito brand H4 headlamps, from original equipment supplier for Datsun 1200. Power Up - Wo!
H4 headlamps are apparently legal for use on USA roads -- if the bulbs are 60/55W (this is to prevent blinding oncoming drivers). In other words, about the same brightness as H6014/H6024 Halogen sealed beams. Higher watt H4 bulbs are for off-road use only. Higher watt bulbs require higher-wattage capable wiring (factory wiring was designed for 50/40W headlamps).
H4 crystal headlight lenses with white LED insets.
HID lamps put out up to 1600 lumens -- far more than round sealed beams -- but with a wide dispersal pattern and a sharp vertical cut-off. So they light up the road surface more, but don't light UP the horizon.
For H4 lights, the stock Datsun 1200 headlight connectors are large enough gauge. Only replace if corroded.
For most H4 lights, the stock Datsun 1200 wiring is large enough (12 gauge for high beams). However to prevent fuse problems, use a wiring relay.
H4 Globes 48881BL Narva H4 12v 60/55w globe - S9.00ea 12342PRB1 Phillips H4 60/55w globe - $9.45ea 12342BVB1 Phillips H4 60/55w bluevision 4000K - $25.00ea 12342XPS2 Phillips H4 60/55w x-treme power - $79.95pr 12342CVB1 Phillips H4 60/55w crystral vision gl - $42.00ea
H4 loom 49894 Narva H4 Connector - $3.65 * only needed if stock connectors are corroded
Custom
non-standard head lamp arrangement (aero, 4-bulb, etc.)
Philips CrystalVision bulbs -- for that "xenon-looking" light
Square headlights - See Custom Rectangular Headlight Grilles
Quad headlights - See Grille#Customized_Grilles
Adjusters
Dorman 42182 Adjuster (nut & screw) Dorman Help! 42182C![]()
26022-M4900 ASSY-SCREW,ADJUST * B110, N10, 620, 810, A10.round-eye, F10, S10
Adjuster Assembly includes:
* 26022-H1000 ADJUST SCREW ICHIKO $2.65
* 26023-H1000 NUT ICHIKO [nylon block]
OR
* 26022-H1010 ADJUST SCREW KOITO
* 26023-H1000 ADJUST SCREW
* 26023-H1010 SCREW MOUNTING (NUT) KOITO
It seems nuts & screws interchange?
26024-H1010 SPRING KOITO <> 26024-H1011 26024-58000 SPRING ICHIKO NLA <> 26024-H1000 * 410, B110, B210, B310.round-eye, S10
