Sedan badges
Revision as of 07:59, 25 January 2025; view current revision
Category: Body
Grille #Center Ornament
Grille #Left Side Badge (trim badge)
Side #C-pillar trim badge
Side #Rear Quarter name badge
Rear #Model badge (Datsun or Sunny)
Rear #Trim badge (Deluxe, GL or GX)
Rear #Transmission badge (Sports or Automatic)
16673.jpgAlbum 16673 16134.jpgAlbum 16134 17765.jpgAlbum 17765 9928.jpgAlbum 9928 758.jpgAlbum 758 20863.jpgAlbum 20863 20862.jpgAlbum 20862
South Africa GX badges
10248.jpgAlbum 10248
Grille
20869.jpgAlbum 20869
Center Ornament
#Early Center Ornament 62312-H1626 ('D') and 62312-H1026 ('S')
11318.jpgAlbum 11318
#1972 Center Ornament
22828.jpgAlbum 22828
Early grille center badge 62312-H1626 ('D') and 62312-H1026 ('S')
  • 1970-1973 Sedan & Van (wagon)
  • 1971-1978 Truck (ute)
11318.jpgAlbum 11318 24321.jpgAlbum 24321
19527.jpgAlbum 19527
11793_4a2f681382129.jpgPost click for topic 21120.jpgAlbum 21120
737.jpgpress photo 24563.jpgbrochure
62312-H1626
174_65b7f2b8ecb21.jpgPost 498235 174_65b7f2ce67914.jpgPost 498235
174_65b7f2ecb7f43.jpgPost 498235 174_65b7f2c5a20a1.jpgPost 498235
174_65b7f2e0133dd.jpgPost 498235 174_65b7f2d8b4d60.jpgPost 498235
Facelift grille 62312-H3125 ornament Late JDM intricate "S"
62312-H3100 cast mark
752.jpgAlbum 752 22828.jpgAlbum 22828 7522.jpgAlbum 7522 13057.jpgAlbum 13057 bfsjq597-img600x450-1293012459v70sxm12525.jpg S_badge_reverse.jpg bfsjq597-img600x450-1293012459yvrlgd12525.jpg bfsjq597-img600x450-1293012459er55u512525.jpg
457.jpgAlbum 457
retrofitted to early grille
23190.jpgAlbum 23190
Grille Left Side Badge
DX early - no trim badge on grille
DX 1972 #62330-H3125 EMBLEM SET-radiator grille "DELUXE"
GL early #62330-H2026
GL 1972 #62330-H3325 EMBLEM SET-radiator grille "GL"
GX early #62330-H2325 COUPE, SEDAN
GX 1972 #62330-H3425 EMBLEM SET-radiator grille "GX"
1972 GX5 62330-H7225 EMBLEM SET-radiator grille "GX 5 SPEED"
62330-H2325
GX early (1970-1971) COUPE, SEDAN grille badge
18053.jpgAlbum 18053
Compare to rear see-through badge
grille badge has long studs for mounting through the grille
contrast with rear sedan badge which has flush-mount pins
6420_5c245be860d51.jpgPost click for topic 6420_5c245c9d038d3.jpgPost click for topic 6420_5c245ca5bcc0b.jpgPost click for topic 6420_5c245cacd7d00.jpgPost click for topic
GX-grille-badge-2.jpg GX-grille-badge-1.jpg yunakiti-img600x450-1277628693ok47g777311.jpg yunakiti-img600x450-1277628693ybadxo77311.jpg yunakiti-img600x450-1277628693qqw7ym77311.jpg 62330-H2225.jpg 62330-H2225_reverse.jpg gx_grille_badge-1.jpg gx_grille_badge-2.jpg gx_grille_badge-3.jpg 27477.jpgAlbum 27477
If the mounting bracket is lost, a length of plumbers tape will do the job (metal strapping tape)
GX flat badge
This modern GX badge has no pins. It has a design like the early GX front trim badge (with the same black background) but is designed for stick-on applications so won't easily fit the 1200 sedan or coupe grilles. Has sticky tape on the flat back of the emblem.
27825.jpgAlbum 27825 27826.jpgAlbum 27826 27827.jpgAlbum 27827
62330-H2026
62330-H2026 EMBLEM-'GL' (early coupe + early sedan)
20864.jpgAlbum 20864 27822.jpgAlbum 27822
screw-on type (rear GL badge is push-in type)
62330-H3125
EMBLEM SET-radiator grille "DELUXE" [1972]
7522.jpgAlbum 7522 25974.jpgAlbum 25974
compare to rear badge 84823-H1000
22513.jpgAlbum 22513
62330-H3325
GL 1972 - 62330-H3325 EMBLEM SET-radiator grille "GL" (1972 sedan, coupe)
28127.jpgAlbum 28127
compare to early rectangular GL badge #62330-H2026
Grille badge has long studs for mounting through the grille.
28132.jpgAlbum 28132
Backing plate is either simple flat or the stronger ridged type
28128.jpgAlbum 28128 28129.jpgAlbum 28129 28131.jpgAlbum 28131
original white paint | with paint faded away
28130.jpgAlbum 28130 28133.jpgAlbum 28133
Cast mark "62330-H3300"
28134.jpgAlbum 28134
placed on 1972 sedan grille
1523.jpgAlbum 1523 457.jpgbrochure 28135.jpgAlbum 28135
62330-H3425
GX 1972 62330-H3425 EMBLEM SET-radiator grille "GX" SEDAN, COUPE
Grille 'GX' has long bolts and a bracket, in order bolt it to the grill. The similar rear 'GX' badge has short pins.
Late badge has narrow font (approximately 71mm wide)
25658.jpgAlbum 25658 29956.jpgAlbum 29956
compare to early 1970-1971 'GX' expanded font grille emblem
compare to rear see-through badge (short pins) and ~100mm wide
Long bolts for the grille badge
29955.jpgAlbum 29955 29957.jpgAlbum 29957
#Early GL and Late GX
16719.jpgAlbum 16719
Side
20868.jpgAlbum 20868
Rear Quarter
#76854-H1600 EMBLEM-'DATSUN' BODY SIDE Sedan, Coupe Export
#76854-H1000 EMBLEM-body side "Sunny" (early '71) Sedan, Wagon
20867.jpgAlbum 20867
Location
14093.jpgAlbum 14093 14094.jpgAlbum 14094
76854-H1000
174_5d5270a05de0e.jpgPost 492238 174_5d5270c9e99cd.jpgPost 492238
Similar:
PB110_Badges#Sunny_Quarter_Badge
9998_4d9ca51941ed4.jpgPost 362773
76854-H1600
76854-H1600 EMBLEM-'Datsun' BODY SIDE Sedan, Coupe Export
10578.jpgAlbum 10578 15745.jpgAlbum 15745
3973.jpgCoupe 20843.jpg#Sedan
'Datsun' badge has same three pins as '#Sunny' badge, so it is interchangeable
24320.jpgAlbum 24320 24323.jpgAlbum 24323
C-pillar
C-pillar Emblems: #DX, #GL, GX
20866.jpgAlbum 20866
DX: 80mm wide? , GX: 99mm wide?, GL 100mm or 109mm wide?
#76852-H1000 BADGE-"Deluxe" SEDAN-DX
20848.jpgAlbum 20848
#76852-H2001 BADGE-"GL" SEDAN-GL
23133.jpgAlbum 23133
#76852-H2300/76853-H2300 BADGE-"GX" SEDAN-GX RH & LH
5204.jpgAlbum 5204
C-pillar Badge Location
1977 GX
15399.jpgAlbum 15399
1973 DX
6576.jpgAlbum click to view
1970? press photos
751.jpgAlbum 751 5271.jpgAlbum 5271
C-pillar Badge 2-dr Sedan
The C-pillar badges seem to have been put in two different places on the 2-door sedan:
* 1970-1971 - down low
* l972-1973 - a bit higher up
The rear fenders are the same part number, so that's not the difference.
1970 DX Press Photo - below the corner
748.jpgAlbum 748
1971 - below the corner
1973 at the corner
76852-H1000
13484.jpgAlbum 13484 20848.jpgAlbum 20848 24325.jpgAlbum 24325 24324.jpgAlbum 24324
Portugal version
26892.jpgAlbum 26892
76852-H2001
23133.jpgAlbum 23133 28120.jpgAlbum 28120 28121.jpgAlbum 28121 28122.jpgAlbum 28122
76852-H2300
29762.jpgAlbum 29762
76852-H2300 BADGE-"GX" (R.H.) SEDAN-GX
76853-H2300 BADGE-"GX" (L.H.) SEDAN-GX
18264.jpgAlbum 18264 5204.jpgAlbum 5204 15399.jpgAlbum 15399
Right-side and left-side versions
29760.jpgAlbum 29760 29761.jpgAlbum 29761
Three fasteners
29763.jpgAlbum 29763
Rear
#Model
#Trim
#Transmission
20870.jpgAlbum 20870 14189.jpgAlbum 14189 750.jpgAlbum 750 25995.jpgAlbum 25995
Model
  • Japan domestic models had 'Sunny' badges as they were sold by Sunny Shop
  • Export models had 'Datsun' badges
20894.jpgAlbum 20894
Left Rear Sunny - UK???
84822-H1000
Sunny 1200 - Right Rear
23991.jpgAlbum 23991
84822-H1600
84822-H1600 EMBLEM-'DATSUN 1200' TRUNK LID SEDAN
18640.gifAlbum 18640
Datsun 1200 - Right Rear signature
21715.jpgAlbum 21715 15650.jpgAlbum 15650 16745.jpgAlbum 16745 19425.jpgAlbum 19425 24319.jpgAlbum 24319 12129.jpgAlbum 12129 datsun_1200_emblem_1_73.jpg 18640.gifAlbum 18640
9998_4d9ce1b0c1d77.jpgPost 362773 9998_4d9ce1c1e0afe.jpgPost 362773 9998_4d9ce1cb3f975.jpgPost 362773 9998_4d9ce1d957c51.jpgPost 362773 9998_4d9ce1e3104c6.jpgPost 362773 9998_4d9ce1ec91375.jpgPost 362773
Trim
Left Rear
Deluxe #84823-H1000 Left Rear
GL early #84823-H2001 Left Rear
GL 1972 #84823-H3300 Left Rear
non-1200 GL
GX #84823-H2300 Left Rear
GX 5-Speed 84823-H7200
Deluxe Rear
Deluxe 84823-H1000 Left Rear sedan attaches to boot lid
Deluxe_trunk_badge_B110.jpg 26891.jpgAlbum 26891
differs from similar looking front facelift badge
* #DELUXE grille badge: long studs for mounting through grille
*  DELUXE trunk badge: small pins for surface mount
21439.jpgAlbum 21439 16172.jpgAlbum 16172 14817.jpgAlbum 14817 24335.jpgAlbum 24335
GL Rear 1970-1971
GL early 84823-H2001 Left Rear sedan & coupe
25776.jpgAlbum 25776 25777.jpgAlbum 25777 25660.jpgAlbum 25660 20864.jpgAlbum 20864 174_5d79542f7af02.jpgPost 492571
GL Rear 1972
GL 1972 84823-H3300 Left Rear Facelift sedan & coupe
174_5d775d43af58d.jpgPost 492555 174_5d7954674ae37.jpgPost 492571
174_5b348e2e94666.jpgPost 488731
GX Rear
Rear GX "see-through" script. Used in Japan and South Africa markets.
174_5d756dcaab01a.jpgPost 492517 174_5d756dd73c003.jpgPost click for topic
84823-H2300 trim badge GX MARK 'GX'
* 1970-1972 Japan
* 1974-1976 South Africa
Used by coupe on Right Side
174_5d74ccd7de40e.jpgPost 492514 11785.jpgAlbum 11785
Used by sedan on Left Side
17111.jpgAlbum 17111 2305.jpgAlbum 2305 25662.jpgAlbum 25662 174_5d756dc157e69.jpgPost 492517
compare to #front GX badge which is not see-through but has a solid background attached
approximately 10cm wide
9930.jpgAlbum 9930 174_5d756dac67030.jpgPost 492517
Make your own GX badge
23911.jpgAlbum 23911 23912.jpgAlbum 23912 23913.jpgAlbum 23913 23914.jpgAlbum 23914
Transmission
  • 3-speed cars did not have a gearbox badge
  • 4-speed cars were badged "Sports"
Sports
79200-H1020 MARK-"Sports" sedan 4-speed
79200-H1060 MARK-"Sports", with sealing washer
"Sports" badge - 4-speed Center Rear (left of license plate)
sports_badge.jpg 20865.jpgAlbum 20865 27820.jpgAlbum 27820
"Sports" 4-speed - to right of license plate - 1972 GL Sedan rear
25977.jpgAlbum 25977 755.jpgAlbum 755
Automatic
#79200-H1020 Early "Full Automatic"
79200-H2820 Late "Full Matic" from '71 April (also used by coupe), 79200-H3200 1972
fullmatic.jpgAlbum click to view 26202.jpgAlbum 26202
N22 Coupe badge on sedan ('Nissan Automatic')
26079.jpgAlbum 26079
79200-H1020
Used on sedan
174_5d744a228ad84.jpgPost 492502 9784.jpgAlbum 9784
Used on early Coupe
