Badges
Revision as of 06:38, 17 November 2009; view current revision
Category: Body
Datsun 1200s came with several badges (emblems). The original 1200 badges were metal, but the new ones -- genuine Nissan items -- are a high-quality plastic that looks very good. Aftermarket reproduction badges vary in quality from poor to very good.
2200.jpg Various early B110 Sunny Emblems (Japan)
Market Differences
  • Japan market 1200s used "Datsun", "S" badges and "Sunny" badges
  • Export market 1200 used "Datsun", "D" badges
917.jpg Sedan grille emblem "D"
6001.jpg Sedan grille emblem "S"
11467.jpg Late JDM Badges
2774.jpg Coupe grille "S" badge (on a Sunny Truck)
2260.jpg Coupe grille "D" badge
10578.jpg Export rear quarter "Datsun" mark
Colors
Most badges are simple silver color.
Sedan "S" and "D" emblems have red and blue bars:
11318.jpg "D" badge and early "S" Sedan badges
Coupe "S" and "D" round emblems have tricolor red, white and blue pie sections:
  • Coupe "D" badge (rear and front)
  • Coupe rear "D" badge
Trim Levels
8880.jpg Comparo
Deluxe
11377.jpg Deluxe Sedan C-pillar Emblem
This is a reproduction badge from Malaysia
13484.jpg Nissan item
758.jpg 2-dr Sedan Deluxe Emblems (USA)
737.jpg Early Sedan Deluxe Grille (Japan)
Note it doesn't use a "Deluxe" grille side emblem. All USA models are similar.
7522.jpg Late Sedan Deluxe Grille (Japan)
13057.jpg Late Sedan Deluxe Grille (Japan)
753.jpg Van Deluxe (Japan)
Grand Luxe
  • GL = Grand Luxe
  • GX = Grand Luxe, Twin Carb
1536.jpg GX-5 grille badge
964.jpg GX Coupe rear quarter badges
10248.jpg GX badges (South Africa)
963.jpg Early Coupe Grille (GL)
865.jpg Late Coupe grille (GX-5)
2968.jpg Late Coupe grille (GX-5)
752.jpg Late GX Sedan (note intricate "S" grille emblem)
457.jpg Late GL Sedan (note intricate "S" grille emblem)
1523.jpg Late GL grille emblem
1524.jpg GL Sedan Rear
750.jpg GX rear layout (Sedan)
2781.jpg Early coupe front emblems
1873.jpg Late coupe rear emblems (missing some?)
1970.jpg Late coupe front emblems
755.jpg GL Sedan rear
What is the badge under the right taillight?
Sedan
Coupe
Sunny Truck & Ute
Front
  • -7803 trucks used Sedan grille and emblems
    "D" (Export) or "S" (JDM)
  • 7804-8910 trucks used Coupe-like grille with unique rectangular center emblem "D" (Export) or "S" (JDM) with black or red background
  • 8911-1994 trucks use a square headlight grill with 'NISSAN' emblem on left side
Rear
5520.jpg non-stock Nissan sticker
2137.jpg Aftermarket "Datsun" tailgate
JDM stickers
    • -8109 Loading Capacity label
    • 8110- 'Sunny' for regular wheelbase model
    • 8110- 'Sunny LONG BODY' for long wheelbase (GB) model
    • 8110- Loading Capacity Label '?????500kg' (Maximum load capacity 500kg)
    • 8910- 'NISSAN'
    • 8110- Frigid Zone Label
Side Emblems
  • - 8102 Sunny Truck uses 'Sunny' script-type sedan side emblems through February 1981.
  • 8103-8910
    Sunny Truck uses 'SUNNY' block-type side emblems
  • 8911-up - no side emblems
B140 Bakkie
  • 2006-2007 Bakkie front with "Nissan" oval grille emblem
    NISSAN rear decal
  • 2002 model?
    • Front: "NISSAN", "1400" and "Deluxe"
    • Side: "Deluxe" and "NISSAN 1400"
  • B140 LDV 1400 Bakkie uses "NISSAN" grille letters
  • 2006 Bakkie front with "Nissan" oval grille emblem
7405.jpg 2006 Bakkie rear
1200 SSS
1200 SSS badges from Datsun New Zealand
5460.jpg 1200 SSS grille emblems
5438.jpg SSS left-side grille emblem
5305.jpg SSS badges
These 1200 SSS badges are not to be confused with similar badges from other Datsuns that are pointy on the bottom.
PB110 Sunny Excellent
The PB110 model line for the most part uses unique badging. See the "Sunny Excellent 1400" article: PB110.
The badges that appear to be the same as B110 are:
  • 'Sunny' badge
  • 'Nissan Full Auto Matic' badge
  • Steering wheel badges
Datsun 1200 S1
Datsun 1200 S1 was a Datsun of Portugal offering.
Interior
The only interior badge is the steering wheel, a small piece of aluminum trim. See the steering wheel article.
Nissan USA and Nissan Japan are out of these parts. Some of them can be purchased from:
  • Sunny Truck Shop
  • Matsuoka M
  • Yokohama South
See: Parts Sources
Front
Radiator grille - Center emblem
  • 62312-H1626 EMBLEM SET-ORNAMENT radiator grille "D" Sedan Export
  • 62312-H1026 EMBLEM SET-ORNAMENT radiator grille "S" early Sedan, Wagon
  • 62312-H3125 ORNAMENT KIT-radiator grille late Sedan, Van
  • 62312-H1826 SET-ORNAMENT radiator grille "D" Coupe Export
  • 62312-H1825 SET-ORNAMENT radiator grille "S" early Coupe
  • 62312-H4025 ORNAMENT-rad, radiator grille late Coupe
Radiator grille - side emblem (early)
Sedan Radiator Grille changed to fancy style for 1973(?) model year.
  • 62330-H2026 SET-EMBLEM, radiator grille "GL" Sedan, Coupe early
  • 62330-H2325 SET-EMBLEM, radiator grille "GX" Sedan (early), Coupe (early, late)
radiator grille - side emblem (late)
Sedan Radiator Grille changed to fancy style for 1972 JDM Facelift.
  • 62330-H3125 EMBLEM SET-radiator grille "Deluxe" Sedan-DX
  • 62330-H3325 EMBLEM SET-radiator grille "GL" Sedan, Coupe late
  • 62330-H3425 EMBLEM SET-radiator grille "GX" Sedan
  • 62330-H7225 EMBLEM SET-radiator grille "GX 5 SPEED" Sedan, Coupe
Side
Body Side C-Pillar
  • 76852-H1000 BADGE-"Deluxe" SEDAN-DX
  • 76852-H2001 BADGE-"GL" SEDAN-GL
  • 76852-H2300 BADGE-"GX" (R.H.) SEDAN-GX
  • 76853-H2300 BADGE-"GX" (L.H.) SEDAN-GX
Body Side Rear Fender
Rear quarter-panel mounted:
  • 78841-H1800 EMBLEM-"Sunny" (early '71) Coupe
  • 78841-H1850 EMBLEM-"Sunny" (W/Sealing washer) Coupe
  • 78842-H1800 EMBLEM-"Coupe" (early '71)
  • 78842-H1850 EMBLEM-"Coupe" (W/Sealing washer)
  • 78842-H2201 EMBLEM-"Coupe GL" (early '71)
  • 78842-H2251 EMBLEM-"Coupe GL" (W/Sealing washer)
  • 78842-H2400 EMBLEM-"Coupe GX" (early '71)
  • 78842-H2450 EMBLEM-"Coupe GX" (W/Sealing washer)
  • 76854-H1000 EMBLEM-body side "Sunny" (early '71) Sedan, Wagon
  • 76854-H1050 EMBLEM-body side "Sunny" (w/sealing washer) Sedan, Van-P, Van-DX
  • 76854-H1600 EMBLEM-'DATSUN' BODY SIDE Sedan, Coupe Export
Rear
Trunk Lid Fitting (right)
Mounted on right side of trunk lid:
  • 84822-H1000 EMBLEM-trunk lid "Sunny 1200" Sedan, Van-DX
  • 84822-H1600 EMBLEM-'DATSUN 1200' TRUNK LID (cursive) Sedan Export
  • 84822-H1806 EMBLEM-'DATSUN 1200' TRUNK LID (non-cursive) COUPE Export
  • 84822-H1856 EMBLEM-'DATSUN 1200' TRUNK LID (non-cursive) COUPE Export (supercedes H1806)
Trunk Lid Fitting (left)
Mounted on left side of trunk lid:
  • 84823-H1000 EMBLEM-"DELUXE" Sedan, Van-DX, Van-P
  • 84823-H2001 MARK-"GL" Sedan, Coupe early
  • 84823-H3300 MARK-"GL" Sedan, Coupe late
  • 84823-H2300 MARK-"GX" Sedan, Coupe
  • 84823-H7200 EMBLEM-"GX-5 SPEED" Sedan, Coupe
  • 96905-18100 LABEL-loading capacity (Van, lower left)
Rear Badge (Center)
  • 79202-H1825 SET-ORNAMENT REAR PANEL COUPE "S" early
  • 79202-H4025 SET-ORNAMENT REAR PANEL COUPE "S" late
  • 79202-H1826 SET-ORNAMENT REAR PANEL COUPE "D" Export
Rear Badge (Transmission Mark)
These are mounted to the left of the number plate:
  • 79200-H1010 MARK-"Sports" Sedan-ST,Sedan-DT,Sedan-GT, Van-DX T
  • 79200-H1060 MARK-"Sports" (w/sealing washer) Sedan-ST,Sedan-DT,Sedan-GT
  • 79200-H1020 MARK-"Nissan Full Automatic" early Sedan, Coupe (left trunk lid)
  • 79200-H2820 MARK-"NISSAN FULL AUTO MATIC" (From '71-Apr.) Sedan, Coupe (left trunk lid)
  • 79200-H3200 MARK-"NISSAN FULL AUTO MATIC" late Sedan
These are mounted on left side of trunk lid:
  • 79855-N2200 MARK-"NISSAN AUTOMATIC" SEDAN, COUPE (left trunk lid) Export
Location Unknown
  • 96907-G1100 LABEL-4 speed Van-Std T, Van-P T
Badge Fitting
  • Sedan rear quarter
Part Sources
Nissan USA and Nissan Japan are out of badges. Nissan Australia apparently still has some.
All the usual places, plus:
