A12GX Part Numbers
From Datsun 1200 Club
Categories: Engine Mechanical | Hitachi Twin Carb
This article lists the parts that are unique to the GX 1200s.
Also see:
* A12GX Engine
* Hitachi Twin Carb (A12T and A14T engines)
Engine
  • 11010-H2300 BLOCK ASS'Y-cylinder
  • 10001-H2350 ENGINE ASS'Y-with clutch (High Gas)
  • 10001-H2355 ENGINE ASS'Y-with clutch (Reg Gas)
  • 10001-H2351 ENGINE ASS'Y-with clutch (????) (High Gas) op.
  • 10001-H2356 ENGINE ASS'Y-with clutch (????) (Reg Gas) op.
  • 10001-H7205 ENGINE ASS'Y-with clutch (High Gas) GX-5
  • 10001-H7255 ENGINE ASS'Y-with clutch (Reg Gas) GX-5
  • 10001-H7251 ENGINE ASS'Y-with clutch (????) (High Gas) GX-5 op.
  • 10001-H7256 ENGINE ASS'Y-with clutch (????) (Reg Gas) GX-5 op.
  • 10100-H4250 ENGINE ASS'Y-with drive plate (Reg Gas) GX-A
  • 10102-H2300 ENGINE ASS'Y-bare (High Gas)
    • 12010-18021 PISTON SET-with piston pin (std size) (High Gas)
    • 21045-H2300 PIPE-suction, water pump
    • 13001-H2300 CAMSHAFT ASS'Y
  • 10102-H2305 ENGINE ASS'Y-bare (Reg Gas)
  • 10103-H2300 ENGINE ASS'Y-short (High Gas)
  • 10103-H2305 ENGINE ASS'Y-short (Reg Gas)
  • 10101-H2325 ENGINE GASKET KIT GX
  • 10101-H2326 ENGINE GASKET KIT-(from '72-6) GX
  • 10101-H2327 ENGINE GASKET KIT-(from '73-4) GX
  • 30411-H5000 PLATE-engine rear, GX-5
  • 08110-62010 BOLT-fixing oil pan (1 of the 12 bolts is different from regular engine)
Cylinder Head and Valve Cover
  • 13264-H2300 COVER ASS'Y-valve rocker GX
  • 11041-H2300 HEAD ASS'Y-cylinder GX
    • 13201-H2300 VALVE-intake 4
    • 13203-H2300 SPRING-valve outer 8
    • 13204-H2301 SPRING-valve inner 8
    • 13204-M0820 HIGH-PERFORMANCE VALVE SPRING/INNER (8) Datsun Competition
      • same as 12109-M0820(?)
    • 13205-H2300 SEAT-valve spring 8
    • 13207-H2300 SEAL-oil valve 8
    • 13207-H2301 SEAL-oil valve (from '72-7) 8 GX
    • 13207-H2310 SEAL-oil valve (from '72-8) 8 GX
    • 13202-H2300 VALVE-exhaust 4
    • DELETE FROM GX: 13219-H1000 SHROUD-inner valve (from '73-4) 8
  • 11041-H2301 HEAD ASS'Y-cylinder (from '73-3)
  • 13212-H2310 GUIDE-valve, intake GX
  • 13213-H2310 GUIDE-valve, exhaust GX
  • 08213-82810 STUD-manifold (same as standad, but with 2 extra studs)
  • 11044-H2300 GASKET-cylinder head GX
    19107.jpgAlbum 19107
  • 11044-H2325 GASKET-cylinder head GX (from '72-6)
  • 11045-H2300 RING 'O' (from '72-6, goes with new type head gasket)
  • 11056-H2301 BOLT-cylinder head (9 total)
  • 11057-H2301 BOLT-cylinder head, center (1 total)
  • 10005-H2301 SLINGER-engine front (from '73-3)
    • [10005-H230x is in the Cherry catalog, not listed in 1200 catalog]
    • 10005-H2300 SLINGER-engine front
Comparison of Cylinder Heads
  • 11041-H2300,11041-H2301,11041-H2302 HEAD ASSY-CYLINDER A12 GX B110
  • 11041-H5702 HEAD ASS'Y-cylinder A12T B210
  • 11041-M0801 HEAD ASSY-CYLINDER A12T E10
  • 11041-M2460 HEAD ASSY-CYLINDER A14T B210, F10
Manifold
8995.jpgAlbum 8995
Comments/Comparisons:
14003-H2330 MANIFOLD-intake B110 A12 GX & E10 A12T
* 1974 Nissan Cherry catalog lists 14003-H5731 for A12T engine
08213-82810 STUD-carburetor fixing 4
* same as manifold-to-head studs
Nissan Competition
Source: 1984 Nissan Competition Catalog
  • 16010-H2336 38MM SU CARB (FRONT)
  • 16010-H2337 38MM SU CARB (REAR)
  • 14003-H2330 GX INTAKE MANIFOLD
  • 11826-H2300 BLOCK TO MANIFOLD HOSE
  • 14035-H2300 MANIFOLD GASKET
  • 14033-H2300 GX HEAT SHIELD
  • 16031-H2300 OVERFLOW TUBE/FRONT
  • 16031-H2301 OVERFLOW TUBE/REAR
  • 16174-H2300 INSULATOR (2)
  • 16175-A5100 INSULATOR GASKET (2)
  • 16361-H2300 THROTTLE SHAFT ASSY
  • 16376-H2300 ACCELERTOR CABLE BRACKET
  • 17523-H2302 FUEL TUBE
  • 18410-H2302 CHOKE CABLE
Carburetor
Datsun 1200 GX used a matched pair of 38mm sidedrafts, referred to as front and rear carburetors.
Choke Linkage
See also: Choke Cable
  • 18410-H2301 WIRE COMP,-choke control GX
    18410-H2302 WIRE COMP,-choke control (from '72-12) GX
    • 24250-89929 GROMMET
  • 18415-H2300 KNOB ASS'Y-choke control
    18415-H1000 KNOB ASS'Y-choke control (from '72-12)
Air Cleaner
14541.jpgAlbum 14541
  • 1 16500-H2300 CLEANER ASS'Y-air (for twin)
  • 2 16526-H2300 COVER ASS'Y-upper
  • 3 16536-H2300 PACKING
  • 4 16546-H2300 ELEMENT ASS'Y-paper
  • 5 16528-H2300 COVER ASS'Y-lower
  • 6 16536-H2300 PACKING
  • 7 16523-12200 GASKET (carburetor to air cleaner) 2
  • 8 16548-22000 PACKING
  • 9 16568-08000 PACKING
  • 10 16516-H2300 BOLT ASS'Y-center 2
  • 11 08120-81662 BOLT (fixing air cleaner to carburetor) 4
  • 12 11828-H2300 HOSE-air cleaner to pipe connector
  • 13 16572-H1000 CLAMP-hose
    16572-10801 CLAMP-hose
AIR CLEANER (HOT AIR TYPE) - Optional
  • 16500-H2310 CLEANER ASS'Y-air
  • 14 16590-H2310 COVER-manifold
  • 15 16530-H2310 DUCT-cover to air cleaner
  • 16 14896-C0600 BAND-hose
Fuel Piping
See also: Fuel Piping
14542.jpgAlbum 14542
  • 17501-H7210 TUBE-fuel (fuel tank to engine) Coupe GX-5
  • 14 17523-H2302 TUBE-fuel pump to carburetor
  • 15 17106-H2300 CLAMP-fuel tube
  • 16 17107-H2300 CLAMP-fuel tube
  • 17 17108-H2300 CLAMP-fuel tube
  • 18 08740-08020 HOSE-fuel (l=80mm) 3
  • 19 08723-11400 CLAMP-hose 6
Fuel Pump
See also: Fuel Pump
  • 17010-H2302 PUMP ASS'Y-fuel GX
  • 17010-H2303 PUMP ASS'Y-fuel (ISO hose) (from '71-11) GX
  • 21060-A4600 FAN-cooling
Engine Electrical
HITACHI
  • 22100-H2300 DISTRIBUTOR ASS'Y-(D407-54) (High Gas)
    • 22110-14600 SPRING SET-governor (High Gas)
    • 22132-14605 CAM-ASS'Y (High Gas)
    • DELETE (?) 22301-H1000 CONTROL ASS'Y-vacuum (except GX-H)
  • 22100-18006 DISTRIBUTOR ASS'Y-(D412-53K) (Reg Gas)
    • 22110-18001 SPRING SET-governor (Reg Gas)
    • 22132-18005 CAM-ASS'Y (Reg Gas)
MITSUBISHI
  • 22100-H18016 DISTRIBUTOR ASS'Y-(TVA-4F2L) (Reg Gas)
    • 22127-18010 SPRING-governor (Reg Gas) 2
  • 22318-E3001 TUBE-distributor vacuum advance (l = 480 mm)
  • GX RESISTOR IGNITION COIL
  • 22401-A4616 PLUG-spark (N.G.K.=BP6ES) 4 [regular A12 is BP5ES]
  • 22401-A4705 PLUG-spark (??=L45PW) 4 (Hitachi)
Transmission
NOTE: CLUTCH for GX is same with regular models
GX-5
  • 32010-H7251 TRANSMISSION ASS'Y (17/5) GX-5 [ F5C56A ]
    11322-H7201 MEMBER-engine mounting, rear (from '72-10)
    • 11323-H7200 STOPPER-engine mounting, rear
    • 24033-H7200 CABLE-reverse lamp switch GX-5
Misc
  • 24103-H7200 [Wiring] HARNESS-instrument GX-5
  • 24043-H2025 CABLE SET-clock (for console box)
  • 24043-H2001 CABLE-clock, front
  • 24044-H2000 CABLE-clock, rear
See Also:
  • 26350-89906 BUZZER-back warning GX-5
  • 26351-H7200 BRACKET-buzzer GX-5
  • 08513-51012 SCREW-stopping (for buzzer bracket) GX-5
  • 26380-H2300 ARM ASS'Y-wiper 2
    • 26381-H2300 NUT-wiper arm 2
  • 28360-H2300 BLADE ASS'Y-wiper 2
  • 26370-A4001 BLADE ASS'Y-wiper 2 GX-5 (op. on all other models)
  • 54611-H2300 BAR-torsion, front stabilizer [antiswaybar]
    • 54617-H2300 BUSHING-stabilizer
  • 40315-H1900 CAP-road wheel [hubcap]
GX and GL use a different wheel than STD and DX. Slightly different to fit over disc brakes?
  • 46280-H7201 TUBE ASS'Y-brake master cylinder to rear brake hose GX-5
    46280-H7201 TUBE ASS'Y-brake master cylinder to rear brake hose (from '73-5) GX-5
Exhaust Piping
See also: A12GX_Exhaust
  • 20010-H2301 TUBE ASS'Y-exhaust, front - GX 4-speed
  • 20010-H3400 TUBE ASS'Y-exhaust, front - GXA (GX Automatic)
  • 20010-H7200 TUBE ASS'Y-exhaust, front - GX-5
  • 20603-H2300 GASKET-exhaust tube - GX and GX-5
  • 20602-27700 NUT-fixing, tube end - GX-5
  • 08915-13810 WASTHER-spring lock (3) - GX-5
  • 20321-H2500 FINISHER-exhaust - GL, GX [chrome extension]
Radiator
See also: Radiator
  • 21400-H2300 RADIATOR ASS'Y
  • 21506-H2301 HOSE ASS'Y-radiator, lower
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=A12GX_Part_Numbers"
This page has been accessed 30,642 times. This page was last modified 20:01, 26 April 2023. Content is available under Datsun 1200 Club.
