Core Support and Apron
From Datsun 1200 Club
Category: Body
<-- back to Body
The core support panel & front apron form the front of the car body.
19570.jpgAlbum 19570
Apron
The front-most finisher panel is the apron, also known as the valance panel.
22521.jpgAlbum 22521
The Front Combination Lamps bolt to it (small openings), and also the bottom part of the fenders bolt to it. The large openings are for airflow to the radiator and slots for the bumper stays.
H10 sedan type with no grille tabs
H18 coupe type with tabs for plastic grille
ASSY-PANEL APRON FRONT
62612-H1000 Sedan + Truck to 7803 [62610] $112 USD
62610-H1800 Coupe + Truck 7803-8910 $130 USD
62610-H1800 Truck 8910- except SB.DX
62612-H1000 Truck 8910- LB + SB.DX
Type H18 apron upper edge has brackets for the plastic grille (Coupe and late truck)
21713.jpgAlbum 21713
Type H10 has no brackets at all for the stainless grille (early sedan/van/ute). Apparently H10 was replaced by H18 on the production line at some point, perhaps 1972 as these are seen in countless sedans.
The upright slots in the apron are for the Bumper Stays to fit through
19563.jpgAlbum 19563 19564.jpgAlbum 19564
Early 1200s (1970-1971) have small bumper stay slots
10217.jpgAlbum 10217 7926.jpgAlbum 7926
1200s from 1972 have taller bumper stay openings
2774.jpgAlbum 2774 2442.jpgAlbum 2442
Compare to PB110 apron 62610-H2500
174_65af5a08757a1.jpgUpload click to view
The lower two bolts of the fender attach to the apron
30189.jpgAlbum 30189
30190.jpgAlbum 30190 30188.jpgAlbum 30188
Core Support
The main front body panel is the Core Support, so named because it supports the radiator core. This panel forms the front of the Engine Bay. The grille is fastened to the support.
Connected parts:
* Horn & Horn relay
* Radiator
Web Search: フロントパネル ラジエーターサポート
Note: The core support assembly includes the stay and rail, which were also sold seperarately.
ASS'Y-SUPPORT, radiator core
62500-H1000 Stainless grille type (sedan/van/early-ute)
62500-H1800 Plastic grille type (coupe/mid-ute)
62500-95W00 Square headlight type (late-ute)
There is also a cooling hole cover assembly, which covers the aircon hole in the core support:
62524-H1000 PLATE-closing rod (optional)
62524-H1000 COVER ASSY-COOLING HOLE Truck F/COLD ZONE
4668.jpgAlbum 4668 9365.jpgAlbum 9365 7417.jpgAlbum 7417 11938.jpgAlbum 11938 25124.jpgAlbum 25124
Radiator dimensions & High-tone horn mounting
23781.jpgAlbum 23781 174_5bfddb9f966ac.jpgPost 490013
Compare: B210
1957.jpgAlbum 1957
Sedan & Wagon
All Sedan & Van, including 1972 facelift. Also for early ute.
62500-H1000 ASS'Y-SUPPORT, radiator core NLA.(USA)
* 62512-H1000 RAIL-support, radiator core, upper [62511] NLA.(USA)
* 62522-H1001 STAY-hood catch [62515] NLA.(USA)
Wagon (van)
13022_4e3e72fa769c3.jpgPost 378850
Coupe
Coupe and mid-model utes.
62500-H1800 ASSY-SUPPORT RADIATOR CORE NLA.(USA)
* 62510-H1800 RAIL-SUPPORT RADIATOR CORE UPPER NLA.(USA)
Sunny Truck
Early (to March 1978)
* Same as Sedan/Van
Mid-model (April 1978 to October 1989)
* same as Coupe
Late-model (from October 1989)
62500-95W00 SUPPORT ASSY-RADIATOR CORE 8910-
* 62510-G1265 SUPPORT-RADIATOR CORE, UPPER
* 62522-H1001 STAY-HOOD LOCK
B140 replacement
174_5bfddbc0165d8.jpgPost 323956
  • The core support rail stay is the same for all models:
    62522-H1001 STAY-HOOD CATCH (all models)
    sold separately but included with the Core Support assembly.
  • The other parts differ by the grille used. The core support has brackets for one of these:
    1. Sedan Grille (core-mounted brackets)
    19558.jpgAlbum 19558
    1. Plastic round-light grille (narrow spaced brackets)
    1. Plastic square-light grille (wide spaced brackets)
  • The core support rail has either wide or narrow plastic grille upper brackets ...
    No brackets at all for sedan/van/early ute
    30187.jpgAlbum 30187
    For square headlight grille
    31413.jpgAlbum 31413
    ラジエーターアッパーサポート コアサポート
  • The core support contains headlamp fittings for either sedan, coupe, or square-eye. Sedan/van and early utes Cores (H1000) have brackets for the grille.
コアサポート
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Core_Support_and_Apron"
This page has been accessed 10,919 times. This page was last modified 08:11, 30 November 2025. Content is available under Datsun 1200 Club.
