Throttle Cable
(Redirected from Accelerator)
Categories: Hitachi 306 Carburetor | Fuel System | Hitachi Twin Carb
Datsun 1200 uses a throttle cable with twisted-braid steel core. A cable is superior to linkage for smooth throttle action. RHD and LHD differ by length.
19261.jpgAlbum 19261
Ends
Both RHD and LHD use the same clip on the interior to fix the cable to the Accelerator Pedal.
Throttle Cable ball-end fits into slot on end of Accelerator Pedal. Usually a clip goes over the cable ball-end. But as long as the cable is properly adjusted you can drive it for years without the clip in place.
25874.jpgAlbum 25874
18036-18000 SPRING-CLAMP ACCELERATOR WIRE
* push-on clip fixes cable to accelerator pedal
25878.jpgAlbum 25878
Ferrule end (that clamps to the carburetor)
* 8mm diameter x 21mm long ALL
30416.jpgAlbum 30416
Cable
Since the carburetor is always on the same side, yet the pedals are on different sides of the car for RHD and LHD models, the accelerator cable length differs.
 RHD  85cm
 LHD  40cm
When replacing, adjust cable for 1mm play at the carburetor cable clamp.
Left-Hand Drive
B110
A8200-G1300 ASSY-WIRE ACCELERATOR [40 cm length] $7.30 USD
* Superceded old part number 18200-H1600
B210: 18200-H7200 ASSY-WIRE ACCELERATOR A14 FED(GFU) From 12/76 $20.81 USD
B210: 18200-H6102 ASSY-WIRE ACCELERATOR $19.08 USD
* Superceded 18200-H6100
B110 type (ball-end) vs B310 type (eyelet-end)
15318.jpgAlbum 15318
Length measured firewall to end of cable ferrule
* B110: 40 cm long ball-end
* B210: 43.5 cm long ball-end
* B310: 40 cm long eyelet-end
Right-Hand Drive
Web Search:サニー B110アクセルワイヤー
18200-H1000 WIRE ASS'Y-accelerator B110 [85 cm length, tube 72cm]
* 18211-18001 RING-wire clamp
18200-G1601 ASSY-WIRE ACCELERATOR B120 -8910
18201-95W00 ASSY-WIRE ACCELERATOR B120 8910- 91cm
* 24222-89901 CLIP-WIRE, ACCELERATOR 9810-
18100-H1000
30415.jpgAlbum 30415
Other Part Numbers
RHD
18200-18000 WIRE ASS'Y-accelerator B10 superseded
18200-18001 WIRE ASS'Y-accelerator B10 replaces 18200-18000
18200-27700 WIRE ASS'Y-accelerator B10 replaces 18200-18001
18200-H5000 WIRE ASS'Y-ACCELERATOR B210 early
 * SBK SA-0227
18200-H5005 WIRE ASS'Y-ACCELERATOR B210 early GL op. and late B210
 * SBK SA-A225
18200-H5205 WIRE ASS'Y-ACCELERATOR B210 GX A12T
18200-H7510 WIRE ASS'Y-ACCELERATOR B210 A14T
18200-H7900 WIRE ASS'Y-ACCELERATOR B210 L16
18201-H8501 WIRE ASS'Y-ACCELERATOR B310
 * SBK SA-0229
18201-H8502 WIRE ASS'Y-ACCELERATOR B310 NLA
 * SBK SA-A220
18201-H9205 WIRE ASS'Y-ACCELERATOR B310 A14E, A15E
LHD
B210 18200-H7200 GFU
 * SBK EA-0224
B210 18200-H6100 <> 18200-H6102
 * SBK EA-0227, SBK EA-0228
 * PIONEER CA8610
   Overall length: 22"
   Mounting Length: 16"
 * BECK/ARNLEY 0950400
18201-H8802 USA/CAN WIRE ASSY-ACCEL Rockauto $11
 * PIONEER CA8825
   Overall Length 20.9" ?
   Mounting Length 16.1" ?
 * BECK/ARNLEY 0950403
 * TSK/Nippon Cable System 4PA1004
 * SBK EA-0229
18201-H9106 KFU
18201-H9160 CAL.MAN 0879-
 * PIONEER CA8826
Sunny Wire Co. for 1959-1963 Datsun 310 - NOT for Sunny B310
車名    car name    DATSUN
部品番号  part number 310
品名    part name   ACCEL
GX Cable Routing
GX uses same cable as others RHD Datsun 1200s.
8355.jpgAlbum 8355 14540.jpgAlbum 14540
Weber DGV Cable
174_500335e2a5b3e.jpgUpload click to view
Sidedraft Cable
Also see:
* Weber_DCOE_carburetor#Linkage
* Mikuni_PHH#Linkage
* Dellorto DHLA
556.gifAlbum 556 1113.jpgAlbum 1113 1114.jpgAlbum 1114 1115.jpgAlbum 1115 3422.jpgAlbum 3422 3461.jpgAlbum 3461 3503.jpgAlbum 3503 5212.jpgAlbum 5212 6581.jpgAlbum 6581 8988.jpgAlbum 8988 9463.jpgAlbum 9463 11368.jpgAlbum 11368 11497.jpgAlbum 11497 11506.jpgAlbum 11506
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Throttle_Cable"
This page has been accessed 35,513 times. This page was last modified 21:52, 7 June 2025. Content is available under Datsun 1200 Club.
