There is no page titled ":Back". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
Article title matches
- Back Door Part Numbers (2137 bytes)
3: [[Back Door]]
7: BACK DOOR (VAN)
8: 1 90100-H1400 ASS'Y-BACK DOOR
9: 2 90400-H1400 ASS'Y-HINGE-back door (R.H.)
10: 90401-H1400 ASS'Y-HINGE-back door (L.H.) - Back Door (2655 bytes)
22: 98041-H1400 PLATE-back door bumper [fitting in jam, to receive latch of ...
27: 73990-H1400 COVER-back door hinge (R.H.)
28: 73991-H1400 COVER-back door hinge (L.H.)
42: [[Back Door Part Numbers]]
45: 90891-H1400 WEATHERSTRIP-back door
Page text matches
- History of Datsun 1200 (16941 bytes)
81: ...troduced with higher specification trim and black back panels and a broad stripe down the side. In Janua... - Movies (20445 bytes)
80: ...to South Africa or somewhere They all pile in the back of a 1200 ute (bakkie?) and drive off ... There a...
146: <br>Comments: They're in the outback after the combivan exploded and get picked up and...
151: <br>Comments: dark blue coupe in background
157: <br>Comments: Gold Sedan in background
165: Back to the Future (1985) [http://www.imdb.com/title/t... - Magazine Articles (24401 bytes)
161: <span style="background-color:LightBlue;">Web Search:</span>{{searc...
187: ...ve.org/web/20010222203237/http://www.kiwat.com/ot/backissue/ot_03_contents.htm|Old Timer Mar 1992 No. 03...
188: ...ve.org/web/20010222203237/http://www.kiwat.com/ot/backissue/ot_05_contents.htm|Old-timer Aug 1992 No. 5}...
189: ...ve.org/web/20010222203204/http://www.kiwat.com/ot/backissue/ot_08_contents.htm|Old-timer Feb 1993 No. 8}...
190: ...ve.org/web/20010222203237/http://www.kiwat.com/ot/backissue/ot_11_contents.htm|Old-timer Aug 1993 No. 11... - Heater (11725 bytes)
147: Inlet connector fitting (back of cylinder head) Fitting thread is 3/8" BSPT
266: You can either remove the fitting from the back of the head & put a plug in there, or get heater ...
274: ... simpler way: Run a new longer hose from front to back of engine.
286: ...s the heater. Connect the long heater hose to the back of the cylinder head. - Rear Axle Swaps (24650 bytes)
110: banjo housing (no backing plates,axles or drums)
135: * [[VB310]] square-back wagon (van) uses leaf springs and so can be easil...
151: * between outer edge of leaf and backing plate: 100 mm
152: * Backing plate to outer face of drum: 65 mm
160: BW has removable back cover - Puerto Rico (4691 bytes)
7: ... G54B,NISSAN SR20DET...3/4 CHASSIS 26X10.5 IN THE BACK... AND IF YOU WANT IT A LOT OF NITROUS - Carburettor Diagnosis (3654 bytes)
64: ... out, spray with carb cleaner. Screw the main jet back in.
65: ...fasten the main jet plugs and snap the lock strap back over the nuts
69: ...emove the carburetor and clean the fuel bowl out, backflush the main jets and rinse the fuel bowl clean.... - Ignition Timing (9164 bytes)
14: # Check the gap on the plugs then put them back in. Spec is 0.028-0.032 inch for the A12. Use 0.0... - Emission Controls (28459 bytes)
329: ...s. It recirculates a small portion of the exhaust back into the combustion chamber. Although this dilute...
341: 1989 October: 3-way catalyst with feedback carburetor and O2 sensor
345: ...sage drilled lengthwise in the head from front to back, and which has cross-passages drilled to each exh...
394: * Anti-backfire valve between Carburetor air cleaner and inta... - Float Level Adjustment (1455 bytes)
30: '''Reassembly''': Put the top back on in reverse order of dis-assembly. Just tighten... - Steering wheel (10037 bytes)
14: <br>{{AlbumLinkH|Facelift_Coupe#Back_Cover|27308|brochure|168}}
74: STD/DX: screws on back side - Parts Sources (15979 bytes)
244: *: This guy goes way back with Datsun power upgrades. D.L. likes to know a ...
278: ...]. Type in your request and the wreckers will get back to you if they have the parts - Part Numbers Index (8259 bytes)
122: ...Roof Part Numbers|Roof]] PANEL, SUNVISOR & INSIDE BACK MIRROR
134: [[Back Door Part Numbers]] (WAGON) - GX-5 (8005 bytes)
80: ...ge includes unique seats. Fronts are black '''highback''' seats with black cloth inserts. Rear seat has ...
84: High Back Seats with integral head rest:
100: 88600-H2010 BACK ASS'Y-rear seat
101: 88620-H2010 TRIM ASS'Y-rear seat back
113: 88600-H2210 BACK ASS'Y-rear seat - Fuel Injection (19606 bytes)
28: * Length of regular fuel hose (from fuel rail back to Surge Tank)
161: **: Run a new low pressure hose to back of car for a fuel return line - Wiring (8463 bytes)
59: # Relocating battery to back of car. Advantages:
62: ...nose-heavy, so moving the 28-40 lb battery to the back helps. You need heavy-gauge cable, larger than st...
66: The ignition switch bolts to the back of the key cylinder. There is a rectangular wire ... - Alternator Wiring (4842 bytes)
4: B110 alternator is 35A and has plastic cover on back - Ignition Switch (12669 bytes)
1: .... For Super DX and higher grades, it bolts to the back of the key cylinder.
79: ...ch]] for this type is removable, and bolts to the back of the [[Steering Lock]]. In other words, the [[I...
104: TIP: On the back of the switch, each contact is marked ('S', 'IG',...
265: ... doesn't operate the Starter until I turn the key back and forth a few times</b>" problem?
271: ...d to the 'start' position, and it does not spring back to the 'on' position when the key is released. Th... - Changing Head Gasket (9192 bytes)
10: .... Tape and label the pushrods so you can put them back in the same holes.
58: ...bolts screw if far enough before putting the head back on.
109: ...btedly change the gap, even if you somehow get it back together without loosening them. See [[Valve Adju... - Nissan B140 (13604 bytes)
120: ...itage in the commercial vehicle market that dates back to 1932. The Nissan brand presence in the {{wikiE...
177: ...200, but with an integral pickup bed instead of a back seat (a coupe utility).
